kira yamato 22 Posted August 5, 2024 Author Posted August 5, 2024 39 minutes ago, Luke said: Have you considered using a ddns? No. i use both emby and plex but plex always work fine with the same network setting ,So Emby should also be work right?
kira yamato 22 Posted August 19, 2024 Author Posted August 19, 2024 (edited) On 8/5/2024 at 9:34 AM, Luke said: Have you considered using a ddns? After server public ip rotate, ipad emby cannot remote login again but this time its show correct wan ip match with public ip. but its say cannot reach server and when i change connection from my home wifi to 5G it can login easily??? But emby(ipad) work with this wifi before. Hope u can help to find the real problem. Noted:this home wifi(not server side) work fine with emby for android tv and other site Edited August 19, 2024 by kira yamato
Luke 42239 Posted September 7, 2024 Posted September 7, 2024 On 8/4/2024 at 11:20 PM, kira yamato said: No. i use both emby and plex but plex always work fine with the same network setting ,So Emby should also be work right? The difference is that plex stores information about your server on their servers. This allows Plex apps to stay informed of the public address change. But from a privacy standpoint, do you really want that? That's why you could do this all on your own with a ddns....then your Emby apps could connect to your Emby Server using the ddns address.
kira yamato 22 Posted September 7, 2024 Author Posted September 7, 2024 (edited) 37 minutes ago, Luke said: The difference is that plex stores information about your server on their servers. This allows Plex apps to stay informed of the public address change. But from a privacy standpoint, do you really want that? That's why you could do this all on your own with a ddns....then your Emby apps could connect to your Emby Server using the ddns address. its not about the structure of emby network but its is the problem within ios emby app because in the same time and same wifi emby in android tv always work, and when use wifi with ipad its work for some time but work fine after use 5G not wifi. Edited September 7, 2024 by kira yamato
kira yamato 22 Posted October 1, 2024 Author Posted October 1, 2024 Its happened again after restart my router and public ip has changed my iphone with 5g connection cannot login ,after sign in with emby connect it bring me to this screen when choose my server name its show unable to reach server. And after choose login with emby again it loading and bring me to the same screen . Add server also not work with (wan)public ip or in home ip from emby dashboard
kira yamato 22 Posted October 1, 2024 Author Posted October 1, 2024 On 9/7/2024 at 11:27 PM, Luke said: The difference is that plex stores information about your server on their servers. This allows Plex apps to stay informed of the public address change. But from a privacy standpoint, do you really want that? That's why you could do this all on your own with a ddns....then your Emby apps could connect to your Emby Server using the ddns address. Update, i found some bug .Now i cannot remote login again after restart router .first i cannot remote login this is the screen after that i keeping click my server name and its show the new bottom bar after that i keep click “home” at bottom bar and then its bring me to my server but without top right user setting and then i can play video as normal but .i cannot find authenticated activitywith any ip show in activities list, after that i use internal wifi login to check with last activities. (time that i start to play20:06-20:11) and (20:13 i use internal wifi login to check log) noted emby server v.4.8.10.0 ios18 emby v.2.2.29
Luke 42239 Posted October 1, 2024 Posted October 1, 2024 Hi, there is no authenticated event unless it was a new sign in.
kira yamato 22 Posted October 1, 2024 Author Posted October 1, 2024 9 minutes ago, Luke said: Hi, there is no authenticated event unless it was a new sign in. yes it is new sign in because i still cannot use auto remote login with 5g
Luke 42239 Posted October 10, 2024 Posted October 10, 2024 On 10/1/2024 at 10:03 AM, kira yamato said: yes it is new sign in because i still cannot use auto remote login with 5g Hi, did you figure this out? Are you still having an issue with this?
kira yamato 22 Posted October 10, 2024 Author Posted October 10, 2024 3 hours ago, Luke said: Hi, did you figure this out? Are you still having an issue with this? yes ,i still cannot remote login with normal auto login. android tv never have login issue, i assume the problem came from app emby ios/ipados not server or network problem.
kira yamato 22 Posted October 11, 2024 Author Posted October 11, 2024 On 10/10/2024 at 10:20 AM, Luke said: Hi, did you figure this out? Are you still having an issue with this? After Update emby ios to v.2.2.31, i cannot use this method to access emby server anymore. Now it 100% cannot remote login to my server.
Luke 42239 Posted October 14, 2024 Posted October 14, 2024 On 10/11/2024 at 5:48 AM, kira yamato said: After Update emby ios to v.2.2.31, i cannot use this method to access emby server anymore. Now it 100% cannot remote login to my server. What exactly happens when you try?
kira yamato 22 Posted October 14, 2024 Author Posted October 14, 2024 3 hours ago, Luke said: What exactly happens when you try? most of the time its stuck with this page then when i select sign in emby connect it. keep bring me to this page again and again. this happen after changing public ip from router ,many restart server or pc doesn’t help .but now i can remote login with no problem without do anything special with same public ip ,that i cannot reach server for 3-4day ago.
Thidsa 44 Posted October 23, 2024 Posted October 23, 2024 My daugther has this problem after .2.2.31 on ios and macos. Has worked before just fine. She hasnt been using emby in a couple of weeks i think, so didnt noticed this until yesterday. Via browser both works just fine. Just tried with a vpn to here and then it works in the apps. App remote from 5g or her wired network gets her same error as @ROOKIE Unable to reach
Luke 42239 Posted November 21, 2024 Posted November 21, 2024 On 10/23/2024 at 6:27 AM, Thidsa said: My daugther has this problem after .2.2.31 on ios and macos. Has worked before just fine. She hasnt been using emby in a couple of weeks i think, so didnt noticed this until yesterday. Via browser both works just fine. Just tried with a vpn to here and then it works in the apps. App remote from 5g or her wired network gets her same error as @ROOKIE Unable to reach Have you been able to get connected from the Emby app?
kira yamato 22 Posted November 22, 2024 Author Posted November 22, 2024 15 hours ago, Luke said: Have you been able to get connected from the Emby app? I still encounter these issues. I try to connect Emby on my iPhone using 5G, but it fails to connect to the server. As a result, I share my iPhone’s hotspot with my iPad, but my iPad is still able to connect to Emby.
Thidsa 44 Posted November 22, 2024 Posted November 22, 2024 21 hours ago, Luke said: Have you been able to get connected from the Emby app? No not from remote after 2.2.31
kira yamato 22 Posted January 2, 2025 Author Posted January 2, 2025 2 hours ago, Luke said: Hi, have you been able to get connected? I just tried with version 2.2.33. I am still unable to find a server via 5G to log in to a server on an iOS device. Android tv can remote log in without a problem.
kira yamato 22 Posted January 9, 2025 Author Posted January 9, 2025 9 hours ago, Luke said: HI, can you try again with 2.2.34? I tried it , it works for now. I will let you know if it cannot connect again or not. Thank you for your help. 1
visproduction 335 Posted January 15, 2025 Posted January 15, 2025 Suspect iPhone MacOS browser may autocomplete or some other cache related issue stopping an direct IP address access. Try clearing the cache of the browser. Make sure you are entering the IP address in the URL address area and not in a search. Try opening an incognito browser and rentering the Ip address in the top URL address area. See: https://apple.stackexchange.com/questions/466423/safari-says-ip-address-isnt-valid-but-other-browsers-can-access-it Hope that helps.
kira yamato 22 Posted January 15, 2025 Author Posted January 15, 2025 On 1/9/2025 at 1:45 AM, Luke said: HI, can you try again with 2.2.34? After using version 2.2.34, it cannot find the server again.(Manual add server ip tried)
