metropical 38 Posted June 2, 2024 Posted June 2, 2024 dashboard/devices. I see there is a multi-select for removal. May I suggest "check all" and then uncheck what you want to keep. I show 279 devices of which 5 is all I need to see. Certainly not a front burner ask.
Solution Neminem 1623 Posted June 2, 2024 Solution Posted June 2, 2024 Mark 1st hold shift scroll to last and mark all
