reas11 2 Posted June 1, 2024 Posted June 1, 2024 Hi there, CCWGTV is currently playing TrueHD files at 2.0 PCM. I would like to force it to transcode TrueHD to a supported 5.1 format instead. Does anyone know if this is possible? Thanks
ebr 16337 Posted June 2, 2024 Posted June 2, 2024 Hi. Which app? The Emby for Android TV app has an option for "Audio Output". You will want to select "Convert incompatible audio to DD" for that.
