SrVirtual 3 Posted June 1, 2024 Posted June 1, 2024 Hello, how are you doing? I have a problem: the profile picture is not displayed when I start my account, exactly when it asks me for the PIN, there is not the profile picture that I have for my account. It should look like this in the following image But now after the most recent update it looks like this It should be noted that the image is not only visible in this area, in the other areas and settings everything looks fine... Please help with this case. It doesn't matter if I need to modify a file programmatically
Happy2Play 9798 Posted June 1, 2024 Posted June 1, 2024 Yes I see the same behavior change from 4.8.7.0 to 4.8.8.0.
SrVirtual 3 Posted June 1, 2024 Author Posted June 1, 2024 Can we fix it?? I think the tag that calls that image is missing, but I don't know what the file is
Happy2Play 9798 Posted June 1, 2024 Posted June 1, 2024 14 minutes ago, SrVirtual said: Can we fix it?? I think the tag that calls that image is missing, but I don't know what the file is Not currently seeing where the issue/change is but I suspect will require another update.
Happy2Play 9798 Posted June 1, 2024 Posted June 1, 2024 Not that I know anything about the change but looks like the issue is in the changes to emby-itemscontainer.js as copy previous js to update shows image but do not know what all the changes do. @Luke
Luke 42184 Posted June 1, 2024 Posted June 1, 2024 HI, yes this has already been resolved but the fix didn't make it into 4.8.8, so it will be in 4.8.9. Thanks. 1
