maryann54 0 Posted November 10, 2014 Posted November 10, 2014 i am trying to install media browser on windows laptop but keep getting the following message === Verbose logging started: 11/9/2014 22:35:03 Build type: SHIP UNICODE 5.00.7601.00 Calling process: c:\daf45604ed9e19e765be7e\Setup.exe ===MSI (c) (AC:14) [22:35:03:921]: Resetting cached policy valuesMSI (c) (AC:14) [22:35:03:921]: Machine policy value 'Debug' is 0MSI (c) (AC:14) [22:35:03:921]: ******* RunEngine: ******* Product: c:\daf45604ed9e19e765be7e\vc_red.msi ******* Action: ******* CommandLine: **********MSI (c) (AC:14) [22:35:03:926]: Client-side and UI is none or basic: Running entire install on the server.MSI (c) (AC:14) [22:35:03:926]: Grabbed execution mutex.MSI (c) (AC:14) [22:35:03:956]: Cloaking enabled.MSI (c) (AC:14) [22:35:03:956]: Attempting to enable all disabled privileges before calling Install on ServerMSI (c) (AC:14) [22:35:03:980]: Incrementing counter to disable shutdown. Counter after increment: 0MSI (s) (B0:00) [22:35:04:025]: Running installation inside multi-package transaction c:\daf45604ed9e19e765be7e\vc_red.msiMSI (s) (B0:00) [22:35:04:025]: Grabbed execution mutex.MSI (s) (B0:BC) [22:35:04:031]: Resetting cached policy valuesMSI (s) (B0:BC) [22:35:04:031]: Machine policy value 'Debug' is 0MSI (s) (B0:BC) [22:35:04:031]: ******* RunEngine: ******* Product: c:\daf45604ed9e19e765be7e\vc_red.msi ******* Action: ******* CommandLine: **********MSI (s) (B0:BC) [22:35:04:034]: Machine policy value 'DisableUserInstalls' is 0MSI (s) (B0:BC) [22:35:04:105]: SRSetRestorePoint skipped for this transaction.MSI (s) (B0:BC) [22:35:04:128]: File will have security applied from OpCode.MSI (s) (B0:BC) [22:35:04:171]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'c:\daf45604ed9e19e765be7e\vc_red.msi' against software restriction policyMSI (s) (B0:BC) [22:35:04:193]: SOFTWARE RESTRICTION POLICY: c:\daf45604ed9e19e765be7e\vc_red.msi has a digital signatureMSI (s) (B0:BC) [22:35:04:306]: SOFTWARE RESTRICTION POLICY: c:\daf45604ed9e19e765be7e\vc_red.msi is permitted to run at the 'unrestricted' authorization level.MSI (s) (B0:BC) [22:35:04:306]: End dialog not enabledMSI (s) (B0:BC) [22:35:04:306]: Original package ==> c:\daf45604ed9e19e765be7e\vc_red.msiMSI (s) (B0:BC) [22:35:04:306]: Package we're running from ==> c:\Windows\Installer\197ce6e.msiMSI (s) (B0:BC) [22:35:04:316]: APPCOMPAT: Compatibility mode property overrides found.MSI (s) (B0:BC) [22:35:04:317]: APPCOMPAT: looking for appcompat database entry with ProductCode '{F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}'.MSI (s) (B0:BC) [22:35:04:318]: APPCOMPAT: no matching ProductCode found in database.MSI (s) (B0:BC) [22:35:04:391]: MSCOREE not loaded loading copy from system32MSI (s) (B0:BC) [22:35:04:421]: Machine policy value 'TransformsSecure' is 0MSI (s) (B0:BC) [22:35:04:421]: User policy value 'TransformsAtSource' is 0MSI (s) (B0:BC) [22:35:04:422]: Machine policy value 'DisablePatch' is 0MSI (s) (B0:BC) [22:35:04:422]: Machine policy value 'AllowLockdownPatch' is 0MSI (s) (B0:BC) [22:35:04:422]: Machine policy value 'DisableLUAPatching' is 0MSI (s) (B0:BC) [22:35:04:423]: Machine policy value 'DisableFlyWeightPatching' is 0MSI (s) (B0:BC) [22:35:04:426]: APPCOMPAT: looking for appcompat database entry with ProductCode '{F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}'.MSI (s) (B0:BC) [22:35:04:426]: APPCOMPAT: no matching ProductCode found in database.MSI (s) (B0:BC) [22:35:04:426]: Transforms are not secure.MSI (s) (B0:BC) [22:35:04:426]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\maryann\AppData\Local\Temp\Microsoft Visual C++ 2010 x86 Redistributable Setup_20141109_223434128-MSI_vc_red.msi.txt'.MSI (s) (B0:BC) [22:35:04:427]: Command Line: EXTUI=1 CURRENTDIRECTORY=c:\daf45604ed9e19e765be7e CLIENTUILEVEL=3 MSICLIENTUSESEXTERNALUI=1 CLIENTPROCESSID=2732 MSI (s) (B0:BC) [22:35:04:427]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{461C455E-DA40-49B3-871B-14308CC7CEFF}'.MSI (s) (B0:BC) [22:35:04:427]: Product Code passed to Engine.Initialize: ''MSI (s) (B0:BC) [22:35:04:427]: Product Code from property table before transforms: '{F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}'MSI (s) (B0:BC) [22:35:04:427]: Product Code from property table after transforms: '{F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}'MSI (s) (B0:BC) [22:35:04:427]: Product not registered: beginning first-time installMSI (s) (B0:BC) [22:35:04:427]: PROPERTY CHANGE: Modifying ALLUSERS property. Its current value is '2'. Its new value: '1'.MSI (s) (B0:BC) [22:35:04:427]: Product {F0C3E5D1-1ADE-321E-8167-68EF0DE699A5} is not managed.MSI (s) (B0:BC) [22:35:04:428]: MSI_LUA: Credential prompt not required, user is an adminMSI (s) (B0:BC) [22:35:04:428]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.MSI (s) (B0:BC) [22:35:04:429]: Entering CMsiConfigurationManager::SetLastUsedSource.MSI (s) (B0:BC) [22:35:04:431]: User policy value 'SearchOrder' is 'nmu'MSI (s) (B0:BC) [22:35:04:431]: Adding new sources is allowed.MSI (s) (B0:BC) [22:35:04:431]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.MSI (s) (B0:BC) [22:35:04:432]: Package name extracted from package path: 'vc_red.msi'MSI (s) (B0:BC) [22:35:04:434]: Package to be registered: 'vc_red.msi'MSI (s) (B0:BC) [22:35:04:437]: Note: 1: 2262 2: AdminProperties 3: -2147287038 MSI (s) (B0:BC) [22:35:04:437]: Machine policy value 'DisableMsi' is 0MSI (s) (B0:BC) [22:35:04:437]: Machine policy value 'AlwaysInstallElevated' is 0MSI (s) (B0:BC) [22:35:04:437]: User policy value 'AlwaysInstallElevated' is 0MSI (s) (B0:BC) [22:35:04:438]: Product installation will be elevated because user is admin and product is being installed per-machine.MSI (s) (B0:BC) [22:35:04:438]: Running product '{F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}' with elevated privileges: Product is assigned.MSI (s) (B0:BC) [22:35:04:438]: PROPERTY CHANGE: Adding EXTUI property. Its value is '1'.MSI (s) (B0:BC) [22:35:04:438]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'c:\daf45604ed9e19e765be7e'.MSI (s) (B0:BC) [22:35:04:438]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '3'.MSI (s) (B0:BC) [22:35:04:438]: PROPERTY CHANGE: Adding MSICLIENTUSESEXTERNALUI property. Its value is '1'.MSI (s) (B0:BC) [22:35:04:438]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '2732'.MSI (s) (B0:BC) [22:35:04:438]: Machine policy value 'DisableAutomaticApplicationShutdown' is 0MSI (s) (B0:BC) [22:35:04:443]: PROPERTY CHANGE: Adding MsiRestartManagerSessionKey property. Its value is '349acf2f933871468019bc85aa5d3603'.MSI (s) (B0:BC) [22:35:04:444]: RESTART MANAGER: Session opened.MSI (s) (B0:BC) [22:35:04:444]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.MSI (s) (B0:BC) [22:35:04:444]: TRANSFORMS property is now: MSI (s) (B0:BC) [22:35:04:444]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.MSI (s) (B0:BC) [22:35:04:453]: SHELL32::SHGetFolderPath returned: C:\Users\maryann\AppData\RoamingMSI (s) (B0:BC) [22:35:04:460]: SHELL32::SHGetFolderPath returned: C:\Users\maryann\FavoritesMSI (s) (B0:BC) [22:35:04:473]: SHELL32::SHGetFolderPath returned: C:\Users\maryann\AppData\Roaming\Microsoft\Windows\Network ShortcutsMSI (s) (B0:BC) [22:35:04:478]: SHELL32::SHGetFolderPath returned: C:\Users\maryann\DocumentsMSI (s) (B0:BC) [22:35:04:483]: SHELL32::SHGetFolderPath returned: C:\Users\maryann\AppData\Roaming\Microsoft\Windows\Printer ShortcutsMSI (s) (B0:BC) [22:35:04:488]: SHELL32::SHGetFolderPath returned: C:\Users\maryann\AppData\Roaming\Microsoft\Windows\RecentMSI (s) (B0:BC) [22:35:04:493]: SHELL32::SHGetFolderPath returned: C:\Users\maryann\AppData\Roaming\Microsoft\Windows\SendToMSI (s) (B0:BC) [22:35:04:498]: SHELL32::SHGetFolderPath returned: C:\Users\maryann\AppData\Roaming\Microsoft\Windows\TemplatesMSI (s) (B0:BC) [22:35:04:498]: SHELL32::SHGetFolderPath returned: C:\ProgramDataMSI (s) (B0:BC) [22:35:04:503]: SHELL32::SHGetFolderPath returned: C:\Users\maryann\AppData\LocalMSI (s) (B0:BC) [22:35:04:508]: SHELL32::SHGetFolderPath returned: C:\Users\maryann\PicturesMSI (s) (B0:BC) [22:35:04:518]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative ToolsMSI (s) (B0:BC) [22:35:04:523]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\StartupMSI (s) (B0:BC) [22:35:04:528]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\ProgramsMSI (s) (B0:BC) [22:35:04:532]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start MenuMSI (s) (B0:BC) [22:35:04:537]: SHELL32::SHGetFolderPath returned: C:\Users\Public\DesktopMSI (s) (B0:BC) [22:35:04:547]: SHELL32::SHGetFolderPath returned: C:\Users\maryann\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative ToolsMSI (s) (B0:BC) [22:35:04:552]: SHELL32::SHGetFolderPath returned: C:\Users\maryann\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\StartupMSI (s) (B0:BC) [22:35:04:557]: SHELL32::SHGetFolderPath returned: C:\Users\maryann\AppData\Roaming\Microsoft\Windows\Start Menu\ProgramsMSI (s) (B0:BC) [22:35:04:562]: SHELL32::SHGetFolderPath returned: C:\Users\maryann\AppData\Roaming\Microsoft\Windows\Start MenuMSI (s) (B0:BC) [22:35:04:567]: SHELL32::SHGetFolderPath returned: C:\Users\maryann\DesktopMSI (s) (B0:BC) [22:35:04:576]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\TemplatesMSI (s) (B0:BC) [22:35:04:578]: SHELL32::SHGetFolderPath returned: C:\Windows\FontsMSI (s) (B0:BC) [22:35:04:586]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16 MSI (s) (B0:BC) [22:35:04:632]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.MSI (s) (B0:BC) [22:35:04:632]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.MSI (s) (B0:BC) [22:35:04:632]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.MSI (s) (B0:BC) [22:35:04:632]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2 MSI (s) (B0:BC) [22:35:04:633]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'maryann'.MSI (s) (B0:BC) [22:35:04:633]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2 MSI (s) (B0:BC) [22:35:04:633]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'c:\Windows\Installer\197ce6e.msi'.MSI (s) (B0:BC) [22:35:04:633]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'c:\daf45604ed9e19e765be7e\vc_red.msi'.MSI (s) (B0:BC) [22:35:04:633]: Machine policy value 'MsiDisableEmbeddedUI' is 0MSI (s) (B0:BC) [22:35:04:633]: EEUI - Disabling MsiEmbeddedUI due to existing external or embedded UIMSI (s) (B0:BC) [22:35:04:633]: EEUI - Disabling MsiEmbeddedUI for service because it's not a quiet/basic installMSI (s) (B0:BC) [22:35:04:634]: Note: 1: 2205 2: 3: PatchPackage MSI (s) (B0:BC) [22:35:04:634]: Machine policy value 'DisableRollback' is 0MSI (s) (B0:BC) [22:35:04:634]: User policy value 'DisableRollback' is 0MSI (s) (B0:BC) [22:35:04:635]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.MSI (s) (B0:BC) [22:35:04:635]: PROPERTY CHANGE: Adding MsiUISourceResOnly property. Its value is '1'.=== Logging started: 11/9/2014 22:35:04 ===MSI (s) (B0:BC) [22:35:04:636]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.MSI (s) (B0:BC) [22:35:04:636]: Doing action: INSTALLMSI (s) (B0:BC) [22:35:04:636]: Note: 1: 2205 2: 3: ActionText Action start 22:35:04: INSTALL.MSI (s) (B0:BC) [22:35:04:637]: Running ExecuteSequenceMSI (s) (B0:BC) [22:35:04:638]: Skipping action: DDSE_CA_Uninstall_InstallExecuteSequenceStarts_x86 (condition is false)MSI (s) (B0:BC) [22:35:04:638]: Doing action: FindRelatedProductsMSI (s) (B0:BC) [22:35:04:638]: Note: 1: 2205 2: 3: ActionText Action start 22:35:04: FindRelatedProducts.MSI (s) (B0:BC) [22:35:04:642]: PROPERTY CHANGE: Adding UPGRADEVCREDIST property. Its value is '{196BB40D-1578-3D01-B289-BEFC77A11A1E}'.MSI (s) (B0:BC) [22:35:04:644]: Skipping action: CA_BlockOlderVCREDISTInstall_x86 (condition is false)MSI (s) (B0:BC) [22:35:04:644]: Doing action: LaunchConditionsMSI (s) (B0:BC) [22:35:04:644]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:04: FindRelatedProducts. Return value 1.MSI (s) (B0:BC) [22:35:04:647]: Note: 1: 2205 2: 3: LaunchCondition MSI (s) (B0:BC) [22:35:04:647]: Note: 1: 2228 2: 3: LaunchCondition 4: SELECT `Condition`, `Description` FROM `LaunchCondition` Action start 22:35:04: LaunchConditions.MSI (s) (B0:BC) [22:35:04:648]: Doing action: CA_SetRTM_ProductName_x86_enuMSI (s) (B0:BC) [22:35:04:648]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:04: LaunchConditions. Return value 0.MSI (s) (B0:BC) [22:35:04:649]: PROPERTY CHANGE: Adding RTM_ProductName property. Its value is 'Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219'.Action start 22:35:04: CA_SetRTM_ProductName_x86_enu.MSI (s) (B0:BC) [22:35:04:650]: Doing action: AppSearchMSI (s) (B0:BC) [22:35:04:650]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:04: CA_SetRTM_ProductName_x86_enu. Return value 1.Action start 22:35:04: AppSearch.MSI (s) (B0:BC) [22:35:04:654]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (B0:BC) [22:35:04:654]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Full\0 3: 2 MSI (s) (B0:BC) [22:35:04:655]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (B0:BC) [22:35:04:655]: PROPERTY CHANGE: Adding REDISTFOUNDVER property. Its value is '#1'.MSI (s) (B0:BC) [22:35:04:656]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (B0:BC) [22:35:04:656]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Visual JSharp Setup\Redist\v4.0.30319 3: 2 MSI (s) (B0:BC) [22:35:04:657]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (B0:BC) [22:35:04:657]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4.0.30319 3: 2 MSI (s) (B0:BC) [22:35:04:658]: Note: 1: 2262 2: Signature 3: -2147287038 MSI (s) (B0:BC) [22:35:04:659]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4.0.30319\0 3: 2 MSI (s) (B0:BC) [22:35:04:659]: Skipping action: CCPSearch (condition is false)MSI (s) (B0:BC) [22:35:04:659]: Skipping action: RMCCPSearch (condition is false)MSI (s) (B0:BC) [22:35:04:659]: Doing action: ValidateProductIDMSI (s) (B0:BC) [22:35:04:659]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:04: AppSearch. Return value 1.Action start 22:35:04: ValidateProductID.MSI (s) (B0:BC) [22:35:04:661]: Doing action: CA_AdminToolsFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8MSI (s) (B0:BC) [22:35:04:661]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:04: ValidateProductID. Return value 1.MSI (s) (B0:BC) [22:35:04:663]: PROPERTY CHANGE: Adding AdminToolsFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\'.Action start 22:35:04: CA_AdminToolsFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8.MSI (s) (B0:BC) [22:35:04:664]: Doing action: CA_AppDataFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8MSI (s) (B0:BC) [22:35:04:664]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:04: CA_AdminToolsFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8. Return value 1.MSI (s) (B0:BC) [22:35:04:666]: PROPERTY CHANGE: Adding AppDataFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 property. Its value is 'C:\Users\maryann\AppData\Roaming\'.Action start 22:35:04: CA_AppDataFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8.MSI (s) (B0:BC) [22:35:04:666]: Doing action: CA_CommonAppDataFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8MSI (s) (B0:BC) [22:35:04:666]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:04: CA_AppDataFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8. Return value 1.MSI (s) (B0:BC) [22:35:04:668]: PROPERTY CHANGE: Adding CommonAppDataFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 property. Its value is 'C:\ProgramData\'.Action start 22:35:04: CA_CommonAppDataFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8.MSI (s) (B0:BC) [22:35:04:668]: Doing action: CA_CommonFilesFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8MSI (s) (B0:BC) [22:35:04:668]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:04: CA_CommonAppDataFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8. Return value 1.MSI (s) (B0:BC) [22:35:04:670]: PROPERTY CHANGE: Adding CommonFilesFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 property. Its value is 'C:\Program Files\Common Files\'.Action start 22:35:04: CA_CommonFilesFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8.MSI (s) (B0:BC) [22:35:04:670]: Doing action: CA_DesktopFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8MSI (s) (B0:BC) [22:35:04:670]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:04: CA_CommonFilesFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8. Return value 1.MSI (s) (B0:BC) [22:35:04:672]: PROPERTY CHANGE: Adding DesktopFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 property. Its value is 'C:\Users\Public\Desktop\'.Action start 22:35:04: CA_DesktopFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8.MSI (s) (B0:BC) [22:35:04:672]: Doing action: CA_ProgramFilesFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8MSI (s) (B0:BC) [22:35:04:672]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:04: CA_DesktopFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8. Return value 1.MSI (s) (B0:BC) [22:35:04:674]: PROPERTY CHANGE: Adding ProgramFilesFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 property. Its value is 'C:\Program Files\'.Action start 22:35:04: CA_ProgramFilesFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8.MSI (s) (B0:BC) [22:35:04:674]: Doing action: CA_ProgramFilesFolder2_x86.3643236F_FC70_11D3_A536_0090278A1BB8MSI (s) (B0:BC) [22:35:04:674]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:04: CA_ProgramFilesFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8. Return value 1.MSI (s) (B0:BC) [22:35:04:676]: PROPERTY CHANGE: Adding ProgramFilesFolder2_x86.3643236F_FC70_11D3_A536_0090278A1BB8 property. Its value is 'C:\Program Files\'.Action start 22:35:04: CA_ProgramFilesFolder2_x86.3643236F_FC70_11D3_A536_0090278A1BB8.MSI (s) (B0:BC) [22:35:04:676]: Doing action: CA_ProgramMenuFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8MSI (s) (B0:BC) [22:35:04:676]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:04: CA_ProgramFilesFolder2_x86.3643236F_FC70_11D3_A536_0090278A1BB8. Return value 1.MSI (s) (B0:BC) [22:35:04:678]: PROPERTY CHANGE: Adding ProgramMenuFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\'.Action start 22:35:04: CA_ProgramMenuFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8.MSI (s) (B0:BC) [22:35:04:679]: Doing action: CA_StartMenuFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8MSI (s) (B0:BC) [22:35:04:679]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:04: CA_ProgramMenuFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8. Return value 1.MSI (s) (B0:BC) [22:35:04:681]: PROPERTY CHANGE: Adding StartMenuFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\'.Action start 22:35:04: CA_StartMenuFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8.MSI (s) (B0:BC) [22:35:04:681]: Doing action: CA_System16Folder_x86.3643236F_FC70_11D3_A536_0090278A1BB8MSI (s) (B0:BC) [22:35:04:681]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:04: CA_StartMenuFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8. Return value 1.MSI (s) (B0:BC) [22:35:04:683]: PROPERTY CHANGE: Adding System16Folder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 property. Its value is 'C:\Windows\system\'.Action start 22:35:04: CA_System16Folder_x86.3643236F_FC70_11D3_A536_0090278A1BB8.MSI (s) (B0:BC) [22:35:04:683]: Doing action: CA_System64Folder_x86.3643236F_FC70_11D3_A536_0090278A1BB8MSI (s) (B0:BC) [22:35:04:684]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:04: CA_System16Folder_x86.3643236F_FC70_11D3_A536_0090278A1BB8. Return value 1.Action start 22:35:04: CA_System64Folder_x86.3643236F_FC70_11D3_A536_0090278A1BB8.MSI (s) (B0:BC) [22:35:04:686]: Doing action: CA_SystemFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8MSI (s) (B0:BC) [22:35:04:686]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:04: CA_System64Folder_x86.3643236F_FC70_11D3_A536_0090278A1BB8. Return value 1.MSI (s) (B0:BC) [22:35:04:687]: PROPERTY CHANGE: Adding SystemFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 property. Its value is 'C:\Windows\system32\'.Action start 22:35:04: CA_SystemFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8.MSI (s) (B0:BC) [22:35:04:688]: Doing action: CA_SystemFolder_x86_VCMSI (s) (B0:BC) [22:35:04:688]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:04: CA_SystemFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8. Return value 1.MSI (s) (B0:BC) [22:35:04:689]: PROPERTY CHANGE: Adding SystemFolder_x86_VC property. Its value is 'C:\Windows\system32\'.Action start 22:35:04: CA_SystemFolder_x86_VC.MSI (s) (B0:BC) [22:35:04:690]: Doing action: CA_TempFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8MSI (s) (B0:BC) [22:35:04:690]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:04: CA_SystemFolder_x86_VC. Return value 1.MSI (s) (B0:BC) [22:35:04:691]: PROPERTY CHANGE: Adding TempFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 property. Its value is 'C:\Users\maryann\AppData\Local\Temp\'.Action start 22:35:04: CA_TempFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8.MSI (s) (B0:BC) [22:35:04:692]: Doing action: CA_WindowsFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8MSI (s) (B0:BC) [22:35:04:692]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:04: CA_TempFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8. Return value 1.MSI (s) (B0:BC) [22:35:04:693]: PROPERTY CHANGE: Adding WindowsFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 property. Its value is 'C:\Windows\'.Action start 22:35:04: CA_WindowsFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8.MSI (s) (B0:BC) [22:35:04:694]: Doing action: CA_WindowsFolder_x86_VCMSI (s) (B0:BC) [22:35:04:694]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:04: CA_WindowsFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8. Return value 1.MSI (s) (B0:BC) [22:35:04:696]: PROPERTY CHANGE: Adding WindowsFolder_x86_VC property. Its value is 'C:\Windows\'.Action start 22:35:04: CA_WindowsFolder_x86_VC.MSI (s) (B0:BC) [22:35:04:696]: Doing action: CA_WindowsVolume_x86.3643236F_FC70_11D3_A536_0090278A1BB8MSI (s) (B0:BC) [22:35:04:696]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:04: CA_WindowsFolder_x86_VC. Return value 1.MSI (s) (B0:BC) [22:35:04:698]: PROPERTY CHANGE: Adding WindowsVolume_x86.3643236F_FC70_11D3_A536_0090278A1BB8 property. Its value is 'c:\'.Action start 22:35:04: CA_WindowsVolume_x86.3643236F_FC70_11D3_A536_0090278A1BB8.MSI (s) (B0:BC) [22:35:04:698]: Skipping action: DDSE_CA_Uninstall_CostInitializePre_x86 (condition is false)MSI (s) (B0:BC) [22:35:04:698]: Doing action: CostInitializeMSI (s) (B0:BC) [22:35:04:698]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:04: CA_WindowsVolume_x86.3643236F_FC70_11D3_A536_0090278A1BB8. Return value 1.MSI (s) (B0:BC) [22:35:04:701]: Machine policy value 'MaxPatchCacheSize' is 10MSI (s) (B0:BC) [22:35:04:765]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'c:\'.MSI (s) (B0:BC) [22:35:04:766]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.MSI (s) (B0:BC) [22:35:04:767]: Note: 1: 2205 2: 3: Patch MSI (s) (B0:BC) [22:35:04:767]: Note: 1: 2205 2: 3: PatchPackage MSI (s) (B0:BC) [22:35:04:767]: Note: 1: 2205 2: 3: MsiPatchHeaders MSI (s) (B0:BC) [22:35:04:767]: Note: 1: 2205 2: 3: __MsiPatchFileList MSI (s) (B0:BC) [22:35:04:767]: Note: 1: 2205 2: 3: PatchPackage MSI (s) (B0:BC) [22:35:04:767]: Note: 1: 2228 2: 3: PatchPackage 4: SELECT `DiskId`, `PatchId`, `LastSequence` FROM `Media`, `PatchPackage` WHERE `Media`.`DiskId`=`PatchPackage`.`Media_` ORDER BY `DiskId` MSI (s) (B0:BC) [22:35:04:768]: Note: 1: 2205 2: 3: Patch Action start 22:35:04: CostInitialize.MSI (s) (B0:BC) [22:35:04:769]: Skipping action: DDSE_CA_Uninstall_CostInitializePost_x86 (condition is false)MSI (s) (B0:BC) [22:35:04:769]: Doing action: FileCostMSI (s) (B0:BC) [22:35:04:769]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:04: CostInitialize. Return value 1.MSI (s) (B0:BC) [22:35:04:771]: Note: 1: 2205 2: 3: MsiAssembly MSI (s) (B0:BC) [22:35:04:772]: Note: 1: 2205 2: 3: Class MSI (s) (B0:BC) [22:35:04:772]: Note: 1: 2205 2: 3: Extension MSI (s) (B0:BC) [22:35:04:772]: Note: 1: 2205 2: 3: TypeLib Action start 22:35:04: FileCost.MSI (s) (B0:BC) [22:35:04:773]: Skipping action: DDSE_CA_Uninstall_CostFinalizePre_x86 (condition is false)MSI (s) (B0:BC) [22:35:04:773]: Doing action: CostFinalizeMSI (s) (B0:BC) [22:35:04:773]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:04: FileCost. Return value 1.MSI (s) (B0:BC) [22:35:04:777]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.MSI (s) (B0:BC) [22:35:04:777]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.MSI (s) (B0:BC) [22:35:04:777]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.MSI (s) (B0:BC) [22:35:04:777]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.MSI (s) (B0:BC) [22:35:04:777]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.MSI (s) (B0:BC) [22:35:04:777]: Note: 1: 2205 2: 3: Patch MSI (s) (B0:BC) [22:35:04:778]: Note: 1: 2205 2: 3: Condition MSI (s) (B0:BC) [22:35:04:779]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'c:\'.MSI (s) (B0:BC) [22:35:04:780]: PROPERTY CHANGE: Modifying WindowsFolder property. Its current value is 'C:\Windows\'. Its new value: 'c:\Windows\'.MSI (s) (B0:BC) [22:35:04:780]: PROPERTY CHANGE: Adding DR_54322.3643236F_FC70_11D3_A536_0090278A1BB8 property. Its value is 'c:\'.MSI (s) (B0:BC) [22:35:04:780]: PROPERTY CHANGE: Adding CSetupMM_URT_x86.3643236F_FC70_11D3_A536_0090278A1BB8 property. Its value is 'c:\'.MSI (s) (B0:BC) [22:35:04:781]: PROPERTY CHANGE: Modifying WindowsFolder_x86_VC property. Its current value is 'C:\Windows\'. Its new value: 'c:\Windows\'.MSI (s) (B0:BC) [22:35:04:781]: PROPERTY CHANGE: Modifying SystemFolder_x86_VC property. Its current value is 'C:\Windows\system32\'. Its new value: 'c:\Windows\system32\'.MSI (s) (B0:BC) [22:35:04:782]: PROPERTY CHANGE: Modifying ProgramFilesFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 property. Its current value is 'C:\Program Files\'. Its new value: 'c:\Program Files\'.MSI (s) (B0:BC) [22:35:04:782]: PROPERTY CHANGE: Adding VS7.3643236F_FC70_11D3_A536_0090278A1BB8 property. Its value is 'c:\Program Files\Microsoft Visual Studio 10.0\'.MSI (s) (B0:BC) [22:35:04:782]: PROPERTY CHANGE: Modifying CommonFilesFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 property. Its current value is 'C:\Program Files\Common Files\'. Its new value: 'c:\Program Files\Common Files\'.MSI (s) (B0:BC) [22:35:04:783]: PROPERTY CHANGE: Adding MSShared_x86.3643236F_FC70_11D3_A536_0090278A1BB8 property. Its value is 'c:\Program Files\Common Files\Microsoft Shared\'.MSI (s) (B0:BC) [22:35:04:783]: PROPERTY CHANGE: Adding VCMsM.3643236F_FC70_11D3_A536_0090278A1BB8 property. Its value is 'c:\Program Files\Common Files\Microsoft Shared\VC\'.MSI (s) (B0:BC) [22:35:04:783]: Target path resolution complete. Dumping Directory table...MSI (s) (B0:BC) [22:35:04:783]: Note: target paths subject to change (via custom actions or browsing)MSI (s) (B0:BC) [22:35:04:783]: Dir (target): Key: TARGETDIR , Object: c:\MSI (s) (B0:BC) [22:35:04:783]: Dir (target): Key: WindowsFolder , Object: c:\Windows\MSI (s) (B0:BC) [22:35:04:783]: Dir (target): Key: DR_54322.3643236F_FC70_11D3_A536_0090278A1BB8 , Object: c:\MSI (s) (B0:BC) [22:35:04:783]: Dir (target): Key: CSetupMM_URT_x86.3643236F_FC70_11D3_A536_0090278A1BB8 , Object: c:\MSI (s) (B0:BC) [22:35:04:783]: Dir (target): Key: WindowsFolder_x86_VC , Object: c:\Windows\MSI (s) (B0:BC) [22:35:04:783]: Dir (target): Key: SystemFolder_x86_VC , Object: c:\Windows\system32\MSI (s) (B0:BC) [22:35:04:783]: Dir (target): Key: ProgramFilesFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 , Object: c:\Program Files\MSI (s) (B0:BC) [22:35:04:783]: Dir (target): Key: VS7.3643236F_FC70_11D3_A536_0090278A1BB8 , Object: c:\Program Files\Microsoft Visual Studio 10.0\MSI (s) (B0:BC) [22:35:04:783]: Dir (target): Key: CommonFilesFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 , Object: c:\Program Files\Common Files\MSI (s) (B0:BC) [22:35:04:783]: Dir (target): Key: MSShared_x86.3643236F_FC70_11D3_A536_0090278A1BB8 , Object: c:\Program Files\Common Files\Microsoft Shared\MSI (s) (B0:BC) [22:35:04:783]: Dir (target): Key: VCMsM.3643236F_FC70_11D3_A536_0090278A1BB8 , Object: c:\Program Files\Common Files\Microsoft Shared\VC\MSI (s) (B0:BC) [22:35:04:784]: Note: 1: 2205 2: 3: MsiAssembly MSI (s) (B0:BC) [22:35:04:784]: Note: 1: 2228 2: 3: MsiAssembly 4: SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`, `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ? Action start 22:35:04: CostFinalize.MSI (s) (B0:BC) [22:35:05:007]: Disallowing installation of component: {529D0A60-398C-38A2-97EF-82FAFA798A06} since the same component with higher versioned keyfile existsMSI (s) (B0:BC) [22:35:05:020]: Skipping action: DDSE_CA_Uninstall_CostFinalizePost_x86 (condition is false)MSI (s) (B0:BC) [22:35:05:020]: Doing action: SetODBCFoldersMSI (s) (B0:BC) [22:35:05:020]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:05: CostFinalize. Return value 1.MSI (s) (B0:BC) [22:35:05:023]: Note: 1: 2205 2: 3: ODBCDriver MSI (s) (B0:BC) [22:35:05:023]: Note: 1: 2228 2: 3: ODBCDriver 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCDriver`, `Component` WHERE `ODBCDriver`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2) MSI (s) (B0:BC) [22:35:05:023]: Note: 1: 2205 2: 3: ODBCTranslator MSI (s) (B0:BC) [22:35:05:023]: Note: 1: 2228 2: 3: ODBCTranslator 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCTranslator`, `Component` WHERE `ODBCTranslator`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2) Action start 22:35:05: SetODBCFolders.MSI (s) (B0:BC) [22:35:05:024]: Skipping action: DDSE_CA_Uninstall_InstallValidatePre_x86 (condition is false)MSI (s) (B0:BC) [22:35:05:024]: Doing action: InstallValidateMSI (s) (B0:BC) [22:35:05:024]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:05: SetODBCFolders. Return value 0.MSI (s) (B0:BC) [22:35:05:027]: PROPERTY CHANGE: Deleting MsiRestartManagerSessionKey property. Its current value is '349acf2f933871468019bc85aa5d3603'.MSI (s) (B0:BC) [22:35:05:027]: Note: 1: 2205 2: 3: Dialog MSI (s) (B0:BC) [22:35:05:027]: Feature: VCRedist_x86_enu; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:027]: Feature: VC_RED_enu_x86_net_SETUP; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:027]: Feature: Servicing_Key; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:027]: Feature: KB2467173; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:027]: Feature: KB2151757; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:027]: Feature: KB982573; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:027]: Component: C_x86_VCRedist_Detection; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:028]: Component: Servicing_Key_ProductChipLanguage; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:028]: Component: MSDIA80_DLL_Redist_11215_____x86.3643236F_FC70_11D3_A536_0090278A1BB8; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:028]: Component: C_CENTRAL_atl100_x86; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:028]: Component: C_CENTRAL_msvcr100_x86; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:028]: Component: C_CENTRAL_msvcp100_x86; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:028]: Component: C_CENTRAL_mfc100_x86; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:028]: Component: C_CENTRAL_mfc100u_x86; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:028]: Component: C_CENTRAL_mfcm100_x86; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:028]: Component: C_CENTRAL_mfcm100u_x86; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:028]: Component: C_CENTRAL_mfc100cht_x86; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:028]: Component: C_CENTRAL_mfc100chs_x86; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:028]: Component: C_CENTRAL_mfc100enu_x86; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:028]: Component: C_CENTRAL_mfc100deu_x86; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:028]: Component: C_CENTRAL_mfc100esn_x86; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:028]: Component: C_CENTRAL_mfc100fra_x86; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:028]: Component: C_CENTRAL_mfc100ita_x86; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:028]: Component: C_CENTRAL_mfc100jpn_x86; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:028]: Component: C_CENTRAL_mfc100kor_x86; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:028]: Component: C_CENTRAL_mfc100rus_x86; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:028]: Component: C_CENTRAL_vcomp100_x86; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:028]: Component: C_VC_Redist_Noninstall_Install_exe_x86; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: C_VC_Redist_Noninstall_Install_res_dll_x86_enu; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: C_VC_Redist_Noninstall_Install_res_dll_x86_kor; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: C_VC_Redist_Noninstall_Install_res_dll_x86_jpn; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: C_VC_Redist_Noninstall_Install_res_dll_x86_rus; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: C_VC_Redist_Noninstall_Install_res_dll_x86_ita; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: C_VC_Redist_Noninstall_Install_res_dll_x86_fra; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: C_VC_Redist_Noninstall_Install_res_dll_x86_esn; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: C_VC_Redist_Noninstall_Install_res_dll_x86_deu; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: C_VC_Redist_Noninstall_Install_res_dll_x86_cht; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: C_VC_Redist_Noninstall_Install_res_dll_x86_chs; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: C_VC_Redist_Noninstall_MSI_x86_enu; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: C_VC_Redist_Noninstall_EULA_enu; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: C_VC_Redist_Noninstall_EULA_kor; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: C_VC_Redist_Noninstall_EULA_jpn; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: C_VC_Redist_Noninstall_EULA_rus; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: C_VC_Redist_Noninstall_EULA_ita; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: C_VC_Redist_Noninstall_EULA_fra; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: C_VC_Redist_Noninstall_EULA_esn; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: C_VC_Redist_Noninstall_EULA_deu; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: C_VC_Redist_Noninstall_EULA_cht; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: C_VC_Redist_Noninstall_EULA_chs; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: C_VC_Redist_Noninstall_Install_ini_ln; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: C_VC_Redist_Noninstall_Install_ini_enu; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: C_VC_Redist_Noninstall_VCRedist_Bmp; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: C_VC_Redist_Noninstall_VCRedist_CAB; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: Servicing_Key_ProductFamily; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:029]: Component: Servicing_Key_ProductEdition; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:029]: Component: Servicing_Key_ProductLanguage; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:029]: Component: KB2467173.ARP.Add; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: KB2467173.ARP.NoRemove; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: KB2467173.ARP.Remove; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:029]: Component: KB2467173.SE; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:029]: Component: KB2151757.ARP.Add; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: KB2151757.ARP.NoRemove; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:029]: Component: KB2151757.ARP.Remove; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:030]: Component: KB2151757.SE; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:030]: Component: KB982573.ARP.Add; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:030]: Component: KB982573.ARP.NoRemove; Installed: Absent; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:030]: Component: KB982573.ARP.Remove; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:030]: Component: KB982573.SE; Installed: Absent; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:030]: Component: __C_x86_VCRedist_Detection65; Installed: Null; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:030]: Component: __Servicing_Key_ProductChipLanguage65; Installed: Null; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:030]: Component: __Servicing_Key_ProductFamily65; Installed: Null; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:030]: Component: __Servicing_Key_ProductEdition65; Installed: Null; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:030]: Component: __Servicing_Key_ProductLanguage65; Installed: Null; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:030]: Component: __KB2467173.ARP.Add65; Installed: Null; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:030]: Component: __KB2467173.ARP.NoRemove65; Installed: Null; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:030]: Component: __KB2467173.ARP.Remove65; Installed: Null; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:030]: Component: __KB2467173.SE65; Installed: Null; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:030]: Component: __KB2151757.ARP.Add65; Installed: Null; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:030]: Component: __KB2151757.ARP.NoRemove65; Installed: Null; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:030]: Component: __KB2151757.ARP.Remove65; Installed: Null; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:030]: Component: __KB2151757.SE65; Installed: Null; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:030]: Component: __KB982573.ARP.Add65; Installed: Null; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:030]: Component: __KB982573.ARP.NoRemove65; Installed: Null; Request: Local; Action: NullMSI (s) (B0:BC) [22:35:05:030]: Component: __KB982573.ARP.Remove65; Installed: Null; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:030]: Component: __KB982573.SE65; Installed: Null; Request: Local; Action: LocalMSI (s) (B0:BC) [22:35:05:030]: Note: 1: 2205 2: 3: BindImage MSI (s) (B0:BC) [22:35:05:030]: Note: 1: 2205 2: 3: ProgId MSI (s) (B0:BC) [22:35:05:030]: Note: 1: 2205 2: 3: PublishComponent MSI (s) (B0:BC) [22:35:05:030]: Note: 1: 2205 2: 3: SelfReg MSI (s) (B0:BC) [22:35:05:030]: Note: 1: 2205 2: 3: Extension MSI (s) (B0:BC) [22:35:05:030]: Note: 1: 2205 2: 3: Font MSI (s) (B0:BC) [22:35:05:030]: Note: 1: 2205 2: 3: Shortcut MSI (s) (B0:BC) [22:35:05:030]: Note: 1: 2205 2: 3: Class MSI (s) (B0:BC) [22:35:05:030]: Note: 1: 2205 2: 3: Icon MSI (s) (B0:BC) [22:35:05:030]: Note: 1: 2205 2: 3: TypeLib Action start 22:35:05: InstallValidate.MSI (s) (B0:BC) [22:35:05:040]: Note: 1: 2205 2: 3: _RemoveFilePath MSI (s) (B0:BC) [22:35:05:434]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.MSI (s) (B0:BC) [22:35:05:438]: Note: 1: 2205 2: 3: BindImage MSI (s) (B0:BC) [22:35:05:438]: Note: 1: 2205 2: 3: ProgId MSI (s) (B0:BC) [22:35:05:438]: Note: 1: 2205 2: 3: PublishComponent MSI (s) (B0:BC) [22:35:05:438]: Note: 1: 2205 2: 3: SelfReg MSI (s) (B0:BC) [22:35:05:438]: Note: 1: 2205 2: 3: Extension MSI (s) (B0:BC) [22:35:05:438]: Note: 1: 2205 2: 3: Font MSI (s) (B0:BC) [22:35:05:438]: Note: 1: 2205 2: 3: Shortcut MSI (s) (B0:BC) [22:35:05:438]: Note: 1: 2205 2: 3: Class MSI (s) (B0:BC) [22:35:05:438]: Note: 1: 2205 2: 3: Icon MSI (s) (B0:BC) [22:35:05:438]: Note: 1: 2205 2: 3: TypeLib MSI (s) (B0:BC) [22:35:05:441]: Note: 1: 2727 2: MSI (s) (B0:BC) [22:35:05:444]: Note: 1: 2205 2: 3: FilesInUse MSI (s) (B0:BC) [22:35:05:466]: Note: 1: 2727 2: MSI (s) (B0:BC) [22:35:05:468]: Skipping action: DDSE_CA_Uninstall_InstallValidatePost_x86 (condition is false)MSI (s) (B0:BC) [22:35:05:468]: Skipping action: DDSE_CA_Uninstall_InstallInitializePre_x86 (condition is false)MSI (s) (B0:BC) [22:35:05:468]: Doing action: InstallInitializeMSI (s) (B0:BC) [22:35:05:468]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:05: InstallValidate. Return value 1.MSI (s) (B0:BC) [22:35:05:469]: Machine policy value 'AlwaysInstallElevated' is 0MSI (s) (B0:BC) [22:35:05:469]: User policy value 'AlwaysInstallElevated' is 0MSI (s) (B0:BC) [22:35:05:469]: BeginTransaction: Locking ServerMSI (s) (B0:BC) [22:35:05:470]: SRSetRestorePoint skipped for this transaction.MSI (s) (B0:BC) [22:35:05:470]: Server not locked: locking for product {F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}Action start 22:35:05: InstallInitialize.MSI (s) (B0:BC) [22:35:05:648]: Skipping action: DDSE_CA_Uninstall_InstallInitializePost_x86 (condition is false)MSI (s) (B0:BC) [22:35:05:648]: Doing action: AllocateRegistrySpaceMSI (s) (B0:BC) [22:35:05:648]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:05: InstallInitialize. Return value 1.Action start 22:35:05: AllocateRegistrySpace.MSI (s) (B0:BC) [22:35:05:650]: Doing action: ProcessComponentsMSI (s) (B0:BC) [22:35:05:650]: Note: 1: 2205 2: 3: ActionText Action ended 22:35:05: AllocateRegistrySpace. Return value 1.MSI (s) (B0:BC) [22:35:05:654]: Resolving source.MSI (s) (B0:BC) [22:35:05:654]: Resolving source to launched-from source.MSI (s) (B0:BC) [22:35:05:654]: Setting launched-from source as last-used.MSI (s) (B0:BC) [22:35:05:655]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'c:\daf45604ed9e19e765be7e\'.MSI (s) (B0:BC) [22:35:05:655]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'c:\daf45604ed9e19e765be7e\'.MSI (s) (B0:BC) [22:35:05:655]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}'.MSI (s) (B0:BC) [22:35:05:655]: SOURCEDIR ==> c:\daf45604ed9e19e765be7e\MSI (s) (B0:BC) [22:35:05:655]: SOURCEDIR product ==> {F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}MSI (s) (B0:BC) [22:35:05:656]: Determining source typeMSI (s) (B0:BC) [22:35:05:657]: Source type from package 'vc_red.msi': 2MSI (s) (B0:BC) [22:35:05:659]: SECREPAIR: Hash Database: C:\Windows\Installer\SourceHash{F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}MSI (s) (B0:BC) [22:35:05:659]: SECREPAIR: SourceHash database file already exists. Deleting it.MSI (s) (B0:BC) [22:35:05:692]: Note: 1: 2262 2: SourceHash 3: -2147287038 MSI (s) (B0:BC) [22:35:05:774]: SECREPAIR: New Hash Database creation complete.MSI (s) (B0:BC) [22:35:05:785]: SECREPAIR: CryptAcquireContext: Could not create the default key containerMSI (s) (B0:BC) [22:35:05:785]: SECREPAIR: Crypt Provider not initialized. Error:-2146893809MSI (s) (B0:BC) [22:35:05:785]: SECUREREPAIR: Failed to CreateContentHash of the file: vc_red.msi: for computing its hash. Error: -2146893809MSI (s) (B0:BC) [22:35:05:785]: SECREPAIR: Failed to create hash for the install source filesMSI (s) (B0:BC) [22:35:05:785]: Note: 1: 2262 2: SourceHash 3: -2147287038 MSI (s) (B0:BC) [22:35:05:785]: SECUREREPAIR: SecureRepair Failed. Error code: 8009000f6A9E8008Action start 22:35:05: ProcessComponents.MSI (s) (B0:BC) [22:35:05:792]: Object already exists.MSI (s) (B0:BC) [22:35:05:798]: Machine policy value 'DisableRollback' is 0MSI (s) (B0:BC) [22:35:05:798]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2 Action ended 22:35:05: ProcessComponents. Return value 3.MSI (s) (B0:BC) [22:35:05:801]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2 MSI (s) (B0:BC) [22:35:05:804]: No System Restore sequence number for this installation.MSI (s) (B0:BC) [22:35:05:804]: Unlocking ServerAction ended 22:35:05: INSTALL. Return value 3.Property(S): DiskPrompt = [1]Property(S): UpgradeCode = {1F4F1D2A-D9DA-32CF-9909-48485DA06DD5}Property(S): REDISTFOUNDVER = #1Property(S): TARGETDIR = c:\Property(S): VCMsM.3643236F_FC70_11D3_A536_0090278A1BB8 = c:\Program Files\Common Files\Microsoft Shared\VC\Property(S): SystemFolder_x86_VC = c:\Windows\system32\Property(S): CSetupMM_URT_x86.3643236F_FC70_11D3_A536_0090278A1BB8 = c:\Property(S): DR_54322.3643236F_FC70_11D3_A536_0090278A1BB8 = c:\Property(S): KB2467173.Classification = HotfixProperty(S): KB2151757.Classification = HotfixProperty(S): KB982573.Classification = HotfixProperty(S): ProgramFilesFolder2_x86.3643236F_FC70_11D3_A536_0090278A1BB8 = C:\Program Files\Property(S): ProgramFilesFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 = c:\Program Files\Property(S): CommonFilesFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 = c:\Program Files\Common Files\Property(S): WindowsVolume_x86.3643236F_FC70_11D3_A536_0090278A1BB8 = c:\Property(S): WindowsFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 = C:\Windows\Property(S): SystemFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 = C:\Windows\system32\Property(S): System16Folder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 = C:\Windows\system\Property(S): TempFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 = C:\Users\maryann\AppData\Local\Temp\Property(S): StartMenuFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 = C:\ProgramData\Microsoft\Windows\Start Menu\Property(S): ProgramMenuFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Property(S): CommonAppDataFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 = C:\ProgramData\Property(S): AppDataFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 = C:\Users\maryann\AppData\Roaming\Property(S): DesktopFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 = C:\Users\Public\Desktop\Property(S): AdminToolsFolder_x86.3643236F_FC70_11D3_A536_0090278A1BB8 = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\Property(S): WindowsFolder_x86_VC = c:\Windows\Property(S): RTM_ProductName = Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219Property(S): SourceDir = c:\daf45604ed9e19e765be7e\Property(S): MSShared_x86.3643236F_FC70_11D3_A536_0090278A1BB8 = c:\Program Files\Common Files\Microsoft Shared\Property(S): VS7.3643236F_FC70_11D3_A536_0090278A1BB8 = c:\Program Files\Microsoft Visual Studio 10.0\Property(S): ProgramFilesFolder = C:\Program Files\Property(S): VersionNT = 601Property(S): Manufacturer = Microsoft CorporationProperty(S): ProductCode = {F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}Property(S): ProductLanguage = 0Property(S): ProductName = Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219Property(S): ProductVersion = 10.0.40219Property(S): ALLUSERS = 1Property(S): VSAssemblyVersion80 = 8.0.0.0Property(S): VSAssemblyVersion90 = 9.0.0.0Property(S): VSAssemblyVersion100 = 10.0.0.0Property(S): VSAssemblyVersion = 10.0.0.0Property(S): ARPHELPLINK = http://go.microsoft.com/fwlink/?LinkId=146008Property(S): ARPCOMMENTS = Caution. Removing this product might prevent some applications from running.Property(S): ARPNOMODIFY = 1Property(S): ARPURLUpdateInfo = http://go.microsoft.com/fwlink/?LinkId=146008Property(S): comspec_cmd = %comspec%Property(S): DDPatch = 0Property(S): FeatureID = 1Property(S): FILESINUSETEXT = The following applications should be closed before continuing the install:Property(S): FXAssemblyVersion = 4.0.0.0Property(S): FXAssemblyVersion35 = 3.5.0.0Property(S): INSTALLLEVEL = 2Property(S): LIMITUI = 1Property(S): NullGUID = {00000000-0000-0000-0000-000000000000}Property(S): PrimaryDir = VS7.3643236F_FC70_11D3_A536_0090278A1BB8Property(S): REBOOT = SuppressProperty(S): ReserveAdditionalCostVS7UI = 8388608Property(S): RunCount = 49Property(S): UpdateProp1 = 0Property(S): UpdateProp2 = 0Property(S): UpdateProp3 = 0Property(S): UpdateProp4 = 0Property(S): UpdateProp5 = 0Property(S): UserNameRegEntryName = UserNameProperty(S): ARPNOREPAIR = 0Property(S): BuildType = retProperty(S): URTVersion = v4.0.30319Property(S): LocProductName = Microsoft Visual C++ 2010 x86 RedistributableProperty(S): ProductCPU = x86Property(S): ProductEdition = REDProperty(S): ProductFamily = VCProperty(S): ProductImage = netProperty(S): RTM_ProductVersion = 10.0.40219Property(S): ProductVersionHigh = 655360Property(S): ProductVersionLow = 2635792385Property(S): DirectoryTable100_x86 = DirectoryTableProperty(S): SecureCustomProperties = IE501FOUND.3643236F_FC70_11D3_A536_0090278A1BB8;INSTALLBLOCKFOUND.3643236F_FC70_11D3_A536_0090278A1BB8;JSHFOUNDVER;NEWERVCREDISTVERSIONDETECTED;OCMFOUNDVER;OCMFOUNDVERLANG;REDISTFOUNDVER;REDISTFOUNDVERLANG;UNINSTALLBLOCKFOUND.3643236F_FC70_11D3_A536_0090278A1BB8;UPGRADEVCREDISTProperty(S): UPGRADEVCREDIST = {196BB40D-1578-3D01-B289-BEFC77A11A1E}Property(S): MsiLogFileLocation = C:\Users\maryann\AppData\Local\Temp\Microsoft Visual C++ 2010 x86 Redistributable Setup_20141109_223434128-MSI_vc_red.msi.txtProperty(S): PackageCode = {461C455E-DA40-49B3-871B-14308CC7CEFF}Property(S): ProductState = -1Property(S): PackagecodeChanging = 1Property(S): EXTUI = 1Property(S): CURRENTDIRECTORY = c:\daf45604ed9e19e765be7eProperty(S): CLIENTUILEVEL = 3Property(S): MSICLIENTUSESEXTERNALUI = 1Property(S): CLIENTPROCESSID = 2732Property(S): MsiSystemRebootPending = 1Property(S): VersionDatabase = 200Property(S): VersionMsi = 5.00Property(S): WindowsBuild = 7601Property(S): ServicePackLevel = 1Property(S): ServicePackLevelMinor = 0Property(S): MsiNTProductType = 1Property(S): MsiNTSuitePersonal = 1Property(S): WindowsFolder = c:\Windows\Property(S): WindowsVolume = c:\Property(S): SystemFolder = C:\Windows\system32\Property(S): System16Folder = C:\Windows\system\Property(S): RemoteAdminTS = 1Property(S): TempFolder = C:\Users\maryann\AppData\Local\Temp\Property(S): CommonFilesFolder = C:\Program Files\Common Files\Property(S): AppDataFolder = C:\Users\maryann\AppData\Roaming\Property(S): FavoritesFolder = C:\Users\maryann\Favorites\Property(S): NetHoodFolder = C:\Users\maryann\AppData\Roaming\Microsoft\Windows\Network Shortcuts\Property(S): PersonalFolder = C:\Users\maryann\Documents\Property(S): PrintHoodFolder = C:\Users\maryann\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\Property(S): RecentFolder = C:\Users\maryann\AppData\Roaming\Microsoft\Windows\Recent\Property(S): SendToFolder = C:\Users\maryann\AppData\Roaming\Microsoft\Windows\SendTo\Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\Property(S): CommonAppDataFolder = C:\ProgramData\Property(S): LocalAppDataFolder = C:\Users\maryann\AppData\Local\Property(S): MyPicturesFolder = C:\Users\maryann\Pictures\Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Property(S): DesktopFolder = C:\Users\Public\Desktop\Property(S): FontsFolder = C:\Windows\Fonts\Property(S): GPTSupport = 1Property(S): OLEAdvtSupport = 1Property(S): ShellAdvtSupport = 1Property(S): Intel = 20Property(S): PhysicalMemory = 3579Property(S): VirtualMemory = 5666Property(S): AdminUser = 1Property(S): MsiTrueAdminUser = 1Property(S): LogonUser = maryannProperty(S): UserSID = S-1-5-21-708847776-3532245682-2458546794-1000Property(S): UserLanguageID = 1033Property(S): ComputerName = MARYANN-PCProperty(S): SystemLanguageID = 1033Property(S): ScreenX = 1024Property(S): ScreenY = 768Property(S): CaptionHeight = 22Property(S): BorderTop = 1Property(S): BorderSide = 1Property(S): TextHeight = 16Property(S): TextInternalLeading = 3Property(S): ColorBits = 32Property(S): TTCSupport = 1Property(S): Time = 22:35:06Property(S): Date = 11/9/2014Property(S): MsiNetAssemblySupport = 4.0.30319.18408Property(S): MsiWin32AssemblySupport = 6.1.7601.17514Property(S): RedirectedDllSupport = 2Property(S): MsiRunningElevated = 1Property(S): Privileged = 1Property(S): USERNAME = maryannProperty(S): DATABASE = c:\Windows\Installer\197ce6e.msiProperty(S): OriginalDatabase = c:\daf45604ed9e19e765be7e\vc_red.msiProperty(S): UILevel = 2Property(S): MsiUISourceResOnly = 1Property(S): ACTION = INSTALLProperty(S): ROOTDRIVE = c:\Property(S): CostingComplete = 1Property(S): OutOfDiskSpace = 0Property(S): OutOfNoRbDiskSpace = 0Property(S): PrimaryVolumeSpaceAvailable = 0Property(S): PrimaryVolumeSpaceRequired = 0Property(S): PrimaryVolumeSpaceRemaining = 0Property(S): SOURCEDIR = c:\daf45604ed9e19e765be7e\Property(S): SourcedirProduct = {F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}MSI (s) (B0:BC) [22:35:06:088]: Windows Installer installed the product. Product Name: Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219. Product Version: 10.0.40219. Product Language: 0. Manufacturer: Microsoft Corporation. Installation success or error status: 1603.MSI (s) (B0:BC) [22:35:06:218]: Deferring clean up of packages/files, if any existMSI (s) (B0:BC) [22:35:06:218]: MainEngineThread is returning 1603MSI (s) (B0:00) [22:35:06:239]: RESTART MANAGER: Session closed.MSI (s) (B0:00) [22:35:06:239]: No System Restore sequence number for this installation.=== Logging stopped: 11/9/2014 22:35:06 ===MSI (s) (B0:00) [22:35:06:246]: User policy value 'DisableRollback' is 0MSI (s) (B0:00) [22:35:06:247]: Machine policy value 'DisableRollback' is 0MSI (s) (B0:00) [22:35:06:247]: Incrementing counter to disable shutdown. Counter after increment: 0MSI (s) (B0:00) [22:35:06:248]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2 MSI (s) (B0:00) [22:35:06:252]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2 MSI (s) (B0:00) [22:35:06:283]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1MSI (s) (B0:00) [22:35:06:284]: Restoring environment variablesMSI (c) (AC:14) [22:35:06:289]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1MSI (c) (AC:14) [22:35:06:291]: MainEngineThread is returning 1603=== Verbose logging stopped: 11/9/2014 22:35:06 ===
Beardyname 198 Posted November 10, 2014 Posted November 10, 2014 would you be so kind and remove that wall of text and use the options provided here for how to provide a logfile: http://mediabrowser.tv/community/index.php?/topic/739-how-to-report-a-problem/ No one wants to try and read code on the forum page.
ebr 16307 Posted November 10, 2014 Posted November 10, 2014 Make sure you are running as an admin and that there is adequate disc space on the machine.
