ZCXZXC 0 Posted May 30, 2024 Posted May 30, 2024 Dear developers, does emby tv 1.8.5.29 no longer support Android 5.0? Recently, I installed emby tv 2.0 and later versions. All decoding on my letv x3 was catastrophic and especially laggy, and the decoding color was abnormal. Using version 1.8, the h265 hevc source decoding was normal again. Or does it no longer support Android 5.0's matar 6a928...? But what's even more strange is that if you use a third-party player to play these 4K HDR 10 HEVC, it's normal again? Is the exoplay decoding library upgraded after emby tv 2.0? Has it abandoned Android 5.0's matar 6a928? I checked a lot of information, but I can't find the reason. There is basically no compatibility after emby tv 1.8? Does exoplay call the Android 5.0 decoding library, or does exoplay come with its own decoding library? Can it be used in the next emby tv Can versions after 2.1 be compatible with the old Android 5.0 matar 6a928? Or can emby tv set 4K source to automatically hard decode to 1080P settings to improve the compatibility of the old system?
ZCXZXC 0 Posted May 30, 2024 Author Posted May 30, 2024 emby tv version 2.1 can be installed on the Android 5.0 system, but the decoding is not normal, the color is wrong, and it is very stuck. Reinstall emby tv version 1.8 and it can be decoded normally.. It's so uncomfortable.
ZCXZXC 0 Posted May 30, 2024 Author Posted May 30, 2024 (edited) mstar 6a928 ..... Edited May 30, 2024 by ZCXZXC
Luke 42244 Posted May 30, 2024 Posted May 30, 2024 Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks.
ZCXZXC 0 Posted May 30, 2024 Author Posted May 30, 2024 1 hour ago, Luke said: Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? 你好。 您能否尝试在同一设备的应用商店中搜索我们的标准 Android 应用(在 Amazon 上搜索“Emby”,在 Google 上搜索“Emby for Android”)并查看比较结果如何? Thanks. 谢谢。 I downloaded all the emby apps from https://emby.tv/download.html. In fact, the final result is the same, all cannot be decoded. It is not that something was modified after emby tv1.8.2 that caused it to be unable to decode. I have tried all emby Android or emby tv.. The result is the same. I really can't solve it, so I came to the forum for help...
ebr 16337 Posted May 30, 2024 Posted May 30, 2024 Hi. I know Emby for Android TV requires a minimum of Android 5.1 but I don't know when was the last time anyone ran it on such an old version of the OS.
RanmaCanada 502 Posted May 30, 2024 Posted May 30, 2024 You will be hard pressed to find anything to support such an old version of Android. It's almost a decade old, support for it is non-existant. Upgrade your device, or use a dongle with a more up to date version of Android.
ZCXZXC 0 Posted May 31, 2024 Author Posted May 31, 2024 10 hours ago, ebr said: Hi. I know Emby for Android TV requires a minimum of Android 5.1 but I don't know when was the last time anyone ran it on such an old version of the OS. 你好。 我知道 Android TV 版 Emby 至少需要 Android 5.1,但我不知道最后一次有人在如此旧版本的操作系统上运行它是什么时候。 Haha, I am a victim of LETV X3 X55 PRO. You know what I am saying, so I am trying to find a way to update the Android version of LETV, which may be difficult.. I don’t want to stay on the old version... just because it is not updated... oh.. it is too difficult for me.
RanmaCanada 502 Posted June 4, 2024 Posted June 4, 2024 On 30/05/2024 at 20:56, ZCXZXC said: Haha, I am a victim of LETV X3 X55 PRO. You know what I am saying, so I am trying to find a way to update the Android version of LETV, which may be difficult.. I don’t want to stay on the old version... just because it is not updated... oh.. it is too difficult for me. you can't update it. Even the people at xda forums have tried. Buy a Xiaomi stick or box.
