aja07 20 Posted May 29, 2024 Posted May 29, 2024 Hi, just installed the Android app on my shield (from the Google store)and I noticed the Forward skip is using the setting for the Back skip (not sure if they are just reversed). Thanks.. Anthony
Luke 42242 Posted May 29, 2024 Posted May 29, 2024 Hi, its' resolved in the next update to the app. Thanks. 1
