Flest 9 Posted May 28, 2024 Posted May 28, 2024 2 problems with sound level... 1 when watching content with 5.1-7.1 on 2.0-2.1, C-channel will be too quiet. actors are hard to hear, need "center mix level" 2 Some dubbed content may be too quiet, a "sound boost" option would be nice no, raising the volume on the audio system is a stupid decision, because if you then turn on normal content, it will hurt your ears))) for tv-shows these settings can be saved for all subsequent episodes on the current device.
Flest 9 Posted May 29, 2024 Author Posted May 29, 2024 8 hours ago, ebr said: Hi. What app are you using? hi, android app and emby theater
ebr 16337 Posted May 29, 2024 Posted May 29, 2024 Hi, there's already an open request for this or something functionally equivalent. Please join in and contribute to the existing discussion at:
