TZTZoro 26 Posted May 28, 2024 Posted May 28, 2024 (edited) On the iphone 15 pro line(maybe also others) when you are playing media in landscape mode depending on the rotation controls are hidden behind the camera notch or just some of the info text, for example in one orientation i can not use the brightness controls from emby to set my brightness it is not a big of a deal but it seems like a simple fix which is of course not a simple fix i hope you guys can fix it and the best of luck! ps ios 17.5.1 and emby 2.2.21 Edited May 28, 2024 by TZTZoro
TZTZoro 26 Posted May 28, 2024 Author Posted May 28, 2024 well it seems to be a duplicate of this one
Luke 42241 Posted May 28, 2024 Posted May 28, 2024 Hi, we'll take a look at it. Thanks for reporting.
Luke 42241 Posted June 14, 2024 Posted June 14, 2024 HI, how do things compare with Emby for iOS 2.2.22?
TZTZoro 26 Posted June 15, 2024 Author Posted June 15, 2024 @Lukemy camera island is still covering up stuff for me(iphone 15 pro max iors 2.2.22) the brightness slider would need to move 1.5 times the width of the slider to the left and when watching a tv show the S from s1:e2 is completely covered, the number is fine but the S is gone it is also the same on the iphone 15 pro
Solution TZTZoro 26 Posted July 22, 2024 Author Solution Posted July 22, 2024 @LukeThank you for the fix 2.2.23 fixed it for me 1
