Lessaj 486 Posted May 28, 2024 Posted May 28, 2024 1 minute ago, Luke said: That's going to reset the triggers for time based operations like scheduled tasks and live tv recordings. It's not really something that's going to cause resource consumption and so therefore I don't think it needs an option to disable it. As for why his system is firing these events, the answer to that is specific to his environment, so I'm not sure. But yes these could all be related. Having said that, the log covers 11 hours of time, and the number of triggers is not something that I think is going to cause a problem. Oh yes wasn't looking at it from a resource consumption standpoint but was curious if this can trigger a display setting change activity, which would be more from the OS side of thingsĀ triggering it rather than on the Emby side but with a headless server I'm also unsure how that would be related it just fits in the time span and I wanted to know if the system logged the events. The event message I believe also indicates what the time was before/after the change, and just following the logging I don't see any gaps so if it is changing it's probably a few ms at most. I haven't seen the message in a while but I have seen it before. I would also agree that retriggering the hardware detection shouldn't really be an issue, it completes very quickly.
WeAreBasstards 0 Posted May 28, 2024 Author Posted May 28, 2024 So the CPU usage simply freezes at 5% and then it feels like nothing works in Emby anymore.
Luke 42289 Posted May 28, 2024 Posted May 28, 2024 13 minutes ago, WeAreBasstards said: So the CPU usage simply freezes at 5% and then it feels like nothing works in Emby anymore. Hi, are you sure it's at that exact time?
WeAreBasstards 0 Posted May 28, 2024 Author Posted May 28, 2024 3 minutes ago, Luke said: Emby No, I just noticed that it happens regularly and only a restart of Emby helps
WeAreBasstards 0 Posted May 28, 2024 Author Posted May 28, 2024 (edited) 7 minutes ago, Luke said: Emby This looks similar to this but over a longer period of time Edited May 28, 2024 by WeAreBasstards
Luke 42289 Posted May 29, 2024 Posted May 29, 2024 10 hours ago, WeAreBasstards said: This looks similar to this but over a longer period of time What does this indicate?
WeAreBasstards 0 Posted May 29, 2024 Author Posted May 29, 2024 (edited) 16 minutes ago, Luke said: What does this indicate? The CPU usage And whenever it stops at 5% like in the picture, nothing works on Emby anymore. Edited May 29, 2024 by WeAreBasstards
Luke 42289 Posted May 29, 2024 Posted May 29, 2024 14 hours ago, WeAreBasstards said: The CPU usage And whenever it stops at 5% like in the picture, nothing works on Emby anymore. Only for that brief moment, right?
WeAreBasstards 0 Posted May 30, 2024 Author Posted May 30, 2024 8 hours ago, Luke said: Only for that brief moment, right? Exactly. Sometimes it works again by itself after a few minutes and sometimes you have to restart Emby for it to work again
WeAreBasstards 0 Posted May 30, 2024 Author Posted May 30, 2024 2 minutes ago, Luke said: What control do you have over the server machine? No physical control. Otherwise full admin rights.
Luke 42289 Posted May 30, 2024 Posted May 30, 2024 is there anything in windows event viewer about display settings change and/or timezone change?
WeAreBasstards 0 Posted May 30, 2024 Author Posted May 30, 2024 3 minutes ago, Luke said: is there anything in windows event viewer about display settings change and/or timezone change? No
