bwarthen 13 Posted November 3, 2024 Author Posted November 3, 2024 Hi, How would I actually inherit the language on my plugin? So for instance my plugin creates libraries that are prefixed with "Because you watched". How would i just have those display in whatever language is selected by the user?
Luke 42234 Posted November 3, 2024 Posted November 3, 2024 31 minutes ago, bwarthen said: Hi, How would I actually inherit the language on my plugin? So for instance my plugin creates libraries that are prefixed with "Because you watched". How would i just have those display in whatever language is selected by the user? HI ,currently this is not possible. Items in the database only have one title value.
mickle026 653 Posted November 4, 2024 Posted November 4, 2024 There's language and country code. I am not sure where to get these outside of a metadata provider, but you can. string CountryCode = info.MetadataCountryCode; string Language = info.MetadataLanguage; string CultureString = Language + "-" + CountryCode; So you can create your own translation engine if you wish, but there is already one inside emby (like a word swap engine) There is also some plugins in the sdk (I think) that show you how to use the "i18n" conversions. I have not done this so cannot really advise. so you can display "Because you watched" as "Parce que tu as regardé" if the code is french, you have to create a translation file also though. Look at jelums code here https://github.com/luzmane/emby.movie.auto.merge Jelum has implimented it inside that plugin.
bwarthen 13 Posted November 4, 2024 Author Posted November 4, 2024 (edited) Removed Edited November 4, 2024 by bwarthen answered already
bwarthen 13 Posted November 4, 2024 Author Posted November 4, 2024 Thanks mickle026 That is exactly what I needed. 1
