Siamsquare 0 Posted May 25, 2024 Posted May 25, 2024 Hi, I've been a bit stupid, auto-update on my 2 Shield Pro was enabled (never had problems before) and the Shield updated my Kodi v20.3 , which worked fine to V21. I use Emby for Kodi in native mode and now nothing syncs anymore, Emby does login on the Emby server. I tried a database reset but nothing works. When you select the folders to a to the library nothing is synced. Any1 else with this problem and maybe a solution? Emby server 4.8.7.0 Emby for Kodi 9.4.21
Siamsquare 0 Posted May 26, 2024 Author Posted May 26, 2024 Thanks for the quick reply, I also have another problem... My server gets stuck at 90% scanning my folders. I'm sure it's just one movie folder which has a mixture of mkv, iso and bdmv file structures. Never had this problem. I tried deleting and re-adding the folder but it keeps stuck and have to add movie one by one manually. Any suggestions?
quickmic 1709 Posted May 26, 2024 Posted May 26, 2024 Enable debug log mode on Emby server and upload the file for review.
Siamsquare 0 Posted May 26, 2024 Author Posted May 26, 2024 Here it is while my library scan was stuck 90% Thanks! embyserver.txt
Luke 42237 Posted May 26, 2024 Posted May 26, 2024 4 hours ago, Siamsquare said: Here it is while my library scan was stuck 90% Thanks! embyserver.txt 219.77 kB · 3 downloads HI, what makes you think that it's stuck? I would just be patient and allow it to finish.
Siamsquare 0 Posted May 26, 2024 Author Posted May 26, 2024 Well I let it scan for 24 hours, never took so long so I guess something makes it stuck! After 24 hours it's still @ 90%...
Luke 42237 Posted May 26, 2024 Posted May 26, 2024 2 hours ago, Siamsquare said: Well I let it scan for 24 hours, never took so long so I guess something makes it stuck! After 24 hours it's still @ 90%... Hi, that log only represents 9 minutes though. Can you please attach the log from when you thought it was stuck? Thanks.
Siamsquare 0 Posted May 27, 2024 Author Posted May 27, 2024 Let's try this again...here you go,thanks. I let it log for about 30 min while the library scan was stuck @ 90% embyserver (1).txt
