KenLinder 4 Posted May 23, 2024 Posted May 23, 2024 see title. Emby should follow symbolic links/shortcuts so that a directory can be created that contains links to media files
Neminem 1623 Posted May 23, 2024 Posted May 23, 2024 What's wrong with .stem files ? STRM Files | Emby Documentation
laie_techie 16 Posted May 28, 2024 Posted May 28, 2024 Symlinks working or not should be a function of the operating system, not Emby. 1
ebr 16337 Posted May 28, 2024 Posted May 28, 2024 33 minutes ago, laie_techie said: Symlinks working or not should be a function of the operating system, not Emby. Correct. The whole point is that those are supposed to be transparent to the consumer.
rbjtech 5344 Posted May 29, 2024 Posted May 29, 2024 (edited) On 23/05/2024 at 17:49, KenLinder said: see title. Emby should follow symbolic links/shortcuts so that a directory can be created that contains links to media files Emby DOES follow symbolic links - it doesn't know any different. As has been said above, to create the symlink, you need to use the OS. Edited May 29, 2024 by rbjtech
