Yamega 1 Posted May 23, 2024 Posted May 23, 2024 Hi, I've been using Emby for a while now but I'm wondering what does the stream info mean, when there is barely any info I mean. Sometimes it's clear it's streaming in the file's full bitrate, for example, 1mbps or 900kbps But sometimes there is no info at all. And sometimes it just says "Direct Play" and nothing else. Is it not playing with full bitrate like it's supposed to? It's happening when streaming on both the internal network and over the internet I should also probably mention the server is running on an Android device
Luke 42242 Posted May 25, 2024 Posted May 25, 2024 Hi, in the second screenshot, what Emby app are you playing with?
Yamega 1 Posted May 25, 2024 Author Posted May 25, 2024 Both screenshots are from the same playing session in the same Emby Android app, just a minute or so apart
Luke 42242 Posted May 28, 2024 Posted May 28, 2024 OK we'll take a look at this. Thanks for reporting.
