icegoddess222 8 Posted May 23, 2024 Posted May 23, 2024 hi i have my emby set up so fast forward is 30s and rewind is 10s in the settings. previously clicking right or left would fast forward or rewind based on those preset values. but i think it was changed recently. manually clicking the buttons in the OSD for emby theater follows the same preset fast forward/rewind rates, but clicking the left and right buttons only skips back and forth by 10s no matter what the settings are set to. is it possible to adjust this back? its annoying to hit right 9x instead of 3x to skip intros. ive tried most basic troubleshooting stuff
Luke 42235 Posted May 23, 2024 Posted May 23, 2024 Hi, yes I see the issue. Fast forward is using the skip back length, so if you have them set for different values then that will be an issue. We'll get this resolved. Thanks.
icegoddess222 8 Posted May 24, 2024 Author Posted May 24, 2024 its working fantastically again thank you luke 1
StevenDTX 15 Posted May 30, 2024 Posted May 30, 2024 (edited) On 5/24/2024 at 5:46 PM, icegoddess222 said: its working fantastically again thank you luke What was the fix? Server or client update? Im still having the issue. Server version: 4.8.7.0 Android CLient: 3.3.95 Thanks! Edit: I just noticed this is in the Emby Theater forum. Im having this issue with the Android client running on my Shield TV. Edited May 30, 2024 by StevenDTX
Luke 42235 Posted May 30, 2024 Posted May 30, 2024 56 minutes ago, StevenDTX said: What was the fix? Server or client update? Im still having the issue. Server version: 4.8.7.0 Android CLient: 3.3.95 Thanks! Edit: I just noticed this is in the Emby Theater forum. Im having this issue with the Android client running on my Shield TV. Hi, it is resolved in the next app update. Thanks. 1
