Gabi92 0 Posted May 16, 2024 Posted May 16, 2024 14 hours ago, Luke said: Is there a ramdisk involved? The ram disk is not part of the machine ram, it´s host ram and now it´s disabled. 13 hours ago, isamudaison said: If you're dead-set on using a RAM disk, I've had success with the following: - Allocate 40GB - A cron job that runs every hour (here is my specific cron job): 0 * * * * bash /home/isamudaison/clean-emby-transcode >> /home/isamudaison/log/clean-emby.log 2>&1 This executes the clean-emby-transcode script and outputs to a log file specified Here is the `clean-emby-transcode` script: #!/bin/bash docker exec emby sh -c 'find /transcode/transcoding-temp/ -mmin +360 -delete -print' This deletes any file modified over 360 min in the past (assuming a docker container that uses the specified path). This falls apart if someone leaves a live tv stream transcoding forever (event shows like super bowl/oscars/whatever), I suspect 80GB would be an ideal size for a RAMdisk. Finally i´ll be using a disk with around 110 GiB dedicated for transcode but i think this option will be handy in order to avoid space issues in case all of the ppl are playing the biggest movies. Also now, i´m facing some issues related to the transcode but not related to the space :). I´ve attached the log so you can see it, let me know if it´s better to open a new post to split the topics. Thank you everyone embyserver.txt ffmpeg-transcode-e2c08962-b666-4131-a7a9-b23b5f17b0ee_1.txt ffmpeg-transcode-0f0d7b7a-4125-429f-aa05-7ee531c14b02_1.txt
Luke 42244 Posted May 22, 2024 Posted May 22, 2024 @Gabi92 can you please describe the issue? Thanks.
