sschimi 3 Posted May 21, 2024 Posted May 21, 2024 Hey guys, i'm encountering a really weird bug on my Nvidia Shield. Information: Agent: Android 11; SHIELD Android TV Build/RQ1A.210105.003 Server-Version 4.8.7.0 When i'm playing a double-episode (don't know the correct name) e.g. PAW Patrol - S1:E1-2 - Rocky will nicht baden, Das große Herbstfest the ui and app freezes at the end, when it should show the next episode info (no matter if the next episode will be an single-episode or not). The next-episode-info is not shown and sometimes the whole app freezes, sometimes the progress bar freezes. Playing a single-episode everything is fine (no matter if the next episode will be an double-episode). Don't know since when this issue exists, but it seems to be a bug since some versions.
ebr 16337 Posted May 22, 2024 Posted May 22, 2024 Hi. Can you try the beta release of the app? Thanks.
sschimi 3 Posted May 22, 2024 Author Posted May 22, 2024 41 minutes ago, ebr said: Hi. Can you try the beta release of the app? Thanks. Hi ebr, looks fine. just had a couple of minutes and can confirm that the freezing and the next-episode-info seems to be fixed for merged episodes in the beta app. Thank you! 2
