M0lf 0 Posted May 21, 2024 Posted May 21, 2024 Dear all, I am using Emby for quite a while now. Really love it. But I stumbled across a issue. I have a TV Show with +100 Episodes, I need the subtitles for it, since it is not my motherlanguage. Sadly there where no subtitles delivered with this show, and OpenSubtitles found some for me, but I have to delay the subtitles for each episode to 10 seconds (10'000 ms). Since the delay can only be changed by +50 or -50 ms, that is quite a tapping and tapping to get there. I just wanted to ask or bring up the topic, that a simpler way to set the delay would be veeery appreciated. Note: Yes I did try to edit the Subtitles .sr file myself to delay it, but that breaks the episode (video and audio is laggy) Thank you very much in advance!
Luke 42242 Posted May 22, 2024 Posted May 22, 2024 Hi, for the next update to the Emby android app, this has been changed to a slider, so I think you'll like that. You'll be able to just quickly drag the slider to 10 seconds. 1
M0lf 0 Posted May 22, 2024 Author Posted May 22, 2024 (edited) Quote @Luke Hi, for the next update to the Emby android app, this has been changed to a slider, so I think you'll like that. You'll be able to just quickly drag the slider to 10 seconds. Kiss Kiss Love to hear that I do have another thing that came into my mind while using Emby. I have Premiere. I noticed that when you haven't granted the Emby App the permission for storage and you download something for offline access, there is no information. It just prepares the file with the Bitrate (according to web interface, have not looked into the app or server) and that's it. Would be nice to have a warning or alert for this case Also, and that's just a minor idea that I had, it would be nice if there is a 'system' dashboard to see some stats of the server ond certain directories. Like CPU/RAM/Network Load, Kernel / OS Build and some stats about the files. Thanks for the work and I'd love to see more in the future. Edited May 22, 2024 by M0lf Forgot to quote :)
