n0tanks87 6 Posted May 20, 2024 Posted May 20, 2024 Has anyone else ever gotten a "playback error machine actively refused it"? I'm using a hdhomerun flex 4k and by is new to me. Had issues last night setting it up and completely un-installed emby and reinstalled it just to get guide data working. Tv worked fine this morning and now I'm getting this with every channel of Ota. Any idea what I should do?
n0tanks87 6 Posted May 20, 2024 Author Posted May 20, 2024 Small update. I can not remove the hdhomerun or the guide data. Neither will delete. I tried refreshing. Everything is still there.
n0tanks87 6 Posted May 20, 2024 Author Posted May 20, 2024 It shows on my android app on my phone and tablet that the guide data and hdhr are removed but on the web app it shows they are still there and can not be deleted. I also have found that when I go to search for devices it list my hdhr as 2 separate tuners instead of 1. Refreshing guide data does not remove either the data or tuner in the web app. i don't know if this will help but here is a log? 2024-05-20 20:21:00.194 Operating System: Microsoft Windows 10.0.22631 OS/Process: x64/x64 Emby Server version: 4.8.7.0 Operating system: Microsoft Windows NT 10.0.22631.0 Command Line: C:\Users\n0tan\AppData\Roaming\Emby-Server\system\EmbyServer.dll App: Emby Web 4.8.7.0 Firefox Windows User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:126.0) Gecko/20100101 Firefox/126.0 http://localhost:8096/emby/videos/46589/live.m3u8?DeviceId=69232c82-382c-4570-87b4-3fa70ce4ba32&MediaSourceId=native_1d59007513b964b01163cce59c6482cf_d7442c19209747036a6fced1bf489408&PlaySessionId=cbccfd6dfeca4cfeaa0fa53d6e0c5186&api_key=e784aaf4076b4600a2e314cc55ee6c44&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_1d59007513b964b01163cce59c6482cf_d7442c19209747036a6fced1bf489408&VideoCodec=h264,av1&AudioCodec=aac&VideoBitrate=199616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=ContainerNotSupported {"Protocol":"Http","Id":"native_1d59007513b964b01163cce59c6482cf_d7442c19209747036a6fced1bf489408","Path":"http://127.0.0.1:8096/LiveTv/LiveStreamFiles/4bbd03b0d3a24f378c0d2ab104fc4870/stream.ts","Type":"Default","ProbePath":"C:\\Users\\n0tan\\AppData\\Roaming\\Emby-Server\\programdata\\transcoding-temp\\4bbd03b0d3a24f378c0d2ab104fc4870\\0000000.ts","ProbeProtocol":"File","Container":"mpegts","Size":4505600,"IsRemote":false,"HasMixedProtocols":false,"ContainerStartTimeTicks":946916689560,"SupportsTranscoding":true,"WallClockStart":"2024-05-21T04:20:56.5925042Z","SupportsDirectStream":true,"SupportsDirectPlay":false,"IsInfiniteStream":true,"RequiresOpening":true,"RequiresClosing":true,"LiveStreamId":"06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_1d59007513b964b01163cce59c6482cf_d7442c19209747036a6fced1bf489408","RequiresLooping":false,"SupportsProbing":false,"MediaStreams":[{"Codec":"mpeg2video","StreamStartTimeTicks":946918334000,"TimeBase":"1/90000","VideoRange":"SDR","DisplayTitle":"720p MPEG2VIDEO","IsInterlaced":false,"BitRate":9160337,"BitDepth":8,"RefFrames":1,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":720,"Width":1280,"AverageFrameRate":59.94006,"RealFrameRate":59.94006,"Profile":"Main","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","PixelFormat":"yuv420p","Level":4,"IsAnamorphic":false,"ExtendedVideoType":"None","ExtendedVideoSubType":"None","ExtendedVideoSubTypeDescription":"None"},{"Codec":"ac3","Language":"eng","StreamStartTimeTicks":946916689560,"TimeBase":"1/90000","DisplayTitle":"English AC3 5.1","DisplayLanguage":"English","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":384000,"Channels":6,"SampleRate":48000,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","ExtendedVideoType":"None","ExtendedVideoSubType":"None","ExtendedVideoSubTypeDescription":"None"},{"Codec":"ac3","Language":"spa","StreamStartTimeTicks":946916689560,"TimeBase":"1/90000","DisplayTitle":"Spanish AC3 stereo","DisplayLanguage":"Spanish","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Type":"Audio","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","ExtendedVideoType":"None","ExtendedVideoSubType":"None","ExtendedVideoSubTypeDescription":"None"},{"Codec":"eia_608","StreamStartTimeTicks":946918334000,"TimeBase":"1/90000","Title":"Closed Captions 1","DisplayTitle":"(Default EIA_608)","IsInterlaced":false,"IsDefault":true,"IsForced":false,"IsHearingImpaired":false,"Type":"Subtitle","Index":100,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":false,"Protocol":"File","ExtendedVideoType":"None","ExtendedVideoSubType":"None","ExtendedVideoSubTypeDescription":"None","SubtitleLocationType":"VideoSideData"}],"Formats":[],"Bitrate":9736337,"RequiredHttpHeaders":{},"AddApiKeyToDirectStreamUrl":false,"ReadAtNativeFramerate":false,"DefaultAudioStreamIndex":1} >>>>>> User policy for n0tanks87 Enable Playback Remuxing: True Enable Video Playback Transcoding: True Enable Audio Playback Transcoding: True >>>>>> Hardware Decoders for mpeg2video [X] DX11VA Radeon RX 570 Series - MPEG-2 >>>>>> Hardware Encoders for h264 [X] AMF Radeon RX 570 Series - H.264 (AVC) >>>>>> Selected Codecs Decoder DX11VA Radeon RX 570 Series - MPEG-2 Adapter #0: 'Radeon RX 570 Series' Id:26591 (Driver: , Vendor: 4098) Max Bitrate: 78 Mbit/s - Frame Sizes: max 2048x1080 Color Formats: NV12, YUV420P - Bit Depths: 8 Profiles: Simple Profile (High Level), Main Profile (High Level) Encoder AMF Radeon RX 570 Series - H.264 (AVC) Adapter #0: 'Radeon RX 570 Series' Id:26591 (Driver: , Vendor: 4098) D3D11 Max Bitrate: 234 Mbit/s - Frame Sizes: 64x64...4096x4096 - Width Alignment: 1 - Height Alignment: 4 Bit Depths: 8 Profiles: Main Profile (Level 5.2), High Profile (Level 5.2) >>>>>> FindVideoEncoder - MediaType: h264, UseHardwareCodecs: True, HWA-Mode: Advanced Info Checking: 'AMF Radeon RX 570 Series - H.264 (AVC)' Info Check successful - selecting 'AMF Radeon RX 570 Series - H.264 (AVC)' >>>>>> FindVideoDecoder - MediaType: mpeg2video, UseHardwareCodecs: True, HWA-Mode: Advanced Info Checking: 'DX11VA Radeon RX 570 Series - MPEG-2' Info Check successful - selecting 'DX11VA Radeon RX 570 Series - MPEG-2' C:\Users\n0tan\AppData\Roaming\Emby-Server\system\ffmpeg.exe -loglevel +timing -y -print_graphs_file "C:\Users\n0tan\AppData\Roaming\Emby-Server\programdata\logs\ffmpeg-transcode-33689650-73da-4bb8-a724-b659e6733fdc_1graph.txt" -copyts -start_at_zero -analyzeduration 3000000 -f mpegts -c:v:0 mpeg2video -threads:v:0 1 -hwaccel:v:0 d3d11va -hwaccel_device:v:0 0 -noautorotate -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/4bbd03b0d3a24f378c0d2ab104fc4870/stream.ts" -map 0:0 -map 0:1 -sn -c:v:0 h264_amf -b:v:0 9160337 -g:v:0 180 -maxrate:v:0 9160337 -bufsize:v:0 18320674 -keyint_min:v:0 180 -r:v:0 59.940059661865234 -pix_fmt:v:0 yuv420p -profile:v:0 high -c:a:0 aac -ab:a:0 192000 -ac:a:0 2 -metadata:s:a:0 language=eng -filter:a:0 "volume=2" -disposition:a:0 default -fflags +discardcorruptts+fillwallclockdts -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "C:\Users\n0tan\AppData\Roaming\Emby-Server\programdata\transcoding-temp\87AA92\87AA92.m3u8" -segment_list_type m3u8 -segment_time 00:00:03.000 -segment_list_entry_prefix hls/87AA92/ -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "C:\Users\n0tan\AppData\Roaming\Emby-Server\programdata\transcoding-temp\87AA92\87AA92_%d.ts" 22:21:00.214 ffmpeg version 5.1-emby_2023_06_25 Copyright (c) 2000-2022 the FFmpeg developers and softworkz for Emby LLC 22:21:00.214 built with gcc 12.2.0 (Rev10, Built by MSYS2 project) 22:21:00.214 Execution Date: 2024-05-20 22:21:00 22:21:00.221 [mpeg2video @ 000001ddeb5dda00] Invalid frame dimensions 0x0. Last message repeated 42 times 22:21:00.231 Input #0, mpegts, from 'http://127.0.0.1:8096/LiveTv/LiveStreamFiles/4bbd03b0d3a24f378c0d2ab104fc4870/stream.ts': 22:21:00.231 Duration: N/A, start: 94691.668956, bitrate: N/A 22:21:00.231 Program 3 22:21:00.231 Stream #0:0[0x31]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p(tv, progressive), 1280x720 [SAR 1:1 DAR 16:9], Closed Captions, Level 4, 59.94 fps, 59.94 tbr, 90k tbn, Start-Time 94691.833s 22:21:00.231 Side data: 22:21:00.231 cpb: bitrate max/min/avg: 16904000/0/0 buffer size: 7995392 vbv_delay: N/A 22:21:00.231 Stream #0:1[0x34](eng): Audio: ac3 ([129][0][0][0] / 0x0081), 48000 Hz, 5.1(side), fltp, 384 kb/s, Start-Time 94691.669s 22:21:00.232 Stream #0:2[0x35](spa): Audio: ac3 ([129][0][0][0] / 0x0081), 48000 Hz, stereo, fltp, 192 kb/s, Start-Time 94691.669s (visual impaired) 22:21:00.236 [AVHWDeviceContext @ 000001ddec08b100] Using D3D11 device 1002:67df (Radeon RX 570 Series). 22:21:00.267 Stream mapping: 22:21:00.267 Stream #0:0 -> #0:0 (mpeg2video (native) -> h264 (h264_amf)) 22:21:00.267 Stream #0:1 -> #0:1 (ac3 (native) -> aac (native)) 22:21:00.267 Press [q] to stop, [?] for help 22:21:00.481 Output #0, segment, to 'C:\Users\n0tan\AppData\Roaming\Emby-Server\programdata\transcoding-temp\87AA92\87AA92_%d.ts': 22:21:00.481 Metadata: 22:21:00.481 encoder : Lavf59.27.100 22:21:00.481 Stream #0:0: Video: h264, yuv420p(tv, progressive), 1280x720 [SAR 1:1 DAR 16:9], q=2-31, 9160 kb/s, 59.94 fps, 90k tbn 22:21:00.481 Metadata: 22:21:00.481 encoder : Lavc59.37.100 h264_amf 22:21:00.481 Stream #0:1(eng): Audio: aac (LC), 48000 Hz, stereo, fltp, 192 kb/s (default) 22:21:00.481 Metadata: 22:21:00.481 encoder : Lavc59.37.100 aac 22:21:00.487 elapsed=00:00:00.15 frame= 1 fps=0.0 q=0.0 size=N/A time=00:00:00.00 bitrate=N/A throttle=off speed= 0x 22:21:00.924 elapsed=00:00:00.65 frame= 87 fps=0.0 q=-0.0 size=N/A time=00:00:01.33 bitrate=N/A throttle=off speed=2.05x 22:21:01.426 elapsed=00:00:01.15 frame= 193 fps=167 q=-0.0 size=N/A time=00:00:03.10 bitrate=N/A throttle=off speed=2.69x 22:21:01.561 [segment @ 000001ddebcaf000] Opening 'C:\Users\n0tan\AppData\Roaming\Emby-Server\programdata\transcoding-temp\87AA92\87AA92.m3u8.tmp' for writing 22:21:01.562 SegmentComplete=video:0 Index=0 Start=0.000000 End=3.920589 Duration=3.920589 offset_pts=0 start_pts=0 Frames=180 filename=hls/87AA92/87AA92_0.ts 22:21:01.562 [segment @ 000001ddebcaf000] Opening 'C:\Users\n0tan\AppData\Roaming\Emby-Server\programdata\transcoding-temp\87AA92\87AA92_1.ts.tmp' for writing 22:21:01.932 elapsed=00:00:01.65 frame= 294 fps=177 q=-0.0 size=N/A time=00:00:04.79 bitrate=N/A throttle=off speed=2.89x 22:21:02.480 elapsed=00:00:02.21 frame= 336 fps=152 q=-0.0 size=N/A time=00:00:05.49 bitrate=N/A throttle=off speed=2.48x 22:21:03.027 elapsed=00:00:02.76 frame= 358 fps=130 q=-0.0 size=N/A time=00:00:05.85 bitrate=N/A throttle=off speed=2.12x 22:21:03.698 elapsed=00:00:03.26 frame= 405 fps=124 q=-0.0 size=N/A time=00:00:06.62 bitrate=N/A throttle=off speed=2.03x 22:21:03.941 [segment @ 000001ddebcaf000] Opening 'C:\Users\n0tan\AppData\Roaming\Emby-Server\programdata\transcoding-temp\87AA92\87AA92.m3u8.tmp' for writing 22:21:03.942 SegmentComplete=video:0 Index=1 Start=3.920589 End=6.923589 Duration=3.003000 offset_pts=0 start_pts=3920589 Frames=180 filename=hls/87AA92/87AA92_1.ts 22:21:03.942 [segment @ 000001ddebcaf000] Opening 'C:\Users\n0tan\AppData\Roaming\Emby-Server\programdata\transcoding-temp\87AA92\87AA92_2.ts.tmp' for writing 22:21:04.010 [mpegts @ 000001dde9c9bd40] PES packet size mismatch 22:21:04.010 [mpegts @ 000001dde9c9bd40] Packet corrupt (stream = 1, dts = 8522889566). 22:21:04.010 http://127.0.0.1:8096/LiveTv/LiveStreamFiles/4bbd03b0d3a24f378c0d2ab104fc4870/stream.ts: corrupt input packet in stream 1 Last message repeated 1 times 22:21:04.015 [ac3 @ 000001ddeb5c1800] incomplete frame 22:21:04.015 http://127.0.0.1:8096/LiveTv/LiveStreamFiles/4bbd03b0d3a24f378c0d2ab104fc4870/stream.ts: corrupt decoded frame in stream 1 [segment @ 000001ddebcaf000] Opening 'C:\Users\n0tan\AppData\Roaming\Emby-Server\programdata\transcoding-temp\87AA92\87AA92.m3u8.tmp' for writing SegmentComplete=video:0 Index=2 Start=6.923589 End=7.957956 Duration=1.034367 offset_pts=0 start_pts=6923589 Frames=62 filename=hls/87AA92/87AA92_2.ts elapsed=00:00:03.78 frame= 422 fps=111 q=-0.0 Lsize=N/A time=00:00:06.95 bitrate=N/A dup=1 drop=0 throttle=off speed=1.84x video:5302kB audio:170kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown [aac @ 000001ddeb5c2880] Qavg: 473.474 EXIT ======= ExtraData 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 ---
Luke 42241 Posted May 23, 2024 Posted May 23, 2024 Hi @n0tanks87please attach the complete emby server and ffmpeg log files. thanks.
n0tanks87 6 Posted May 24, 2024 Author Posted May 24, 2024 On 5/23/2024 at 3:02 PM, Luke said: Hi @n0tanks87please attach the complete emby server and ffmpeg log files. thanks. @LukeDon't know if these are right. Hopefully these will help. hardware_detection-63851912809.txt embyserver.txt ffmpeg-transcode-33689650-73da-4bb8-a724-b659e6733fdc_1.txt
n0tanks87 6 Posted May 24, 2024 Author Posted May 24, 2024 I did notice I can't rewind or fast forward on my android phone and tablet.
Luke 42241 Posted May 28, 2024 Posted May 28, 2024 On 5/24/2024 at 6:21 PM, n0tanks87 said: I did notice I can't rewind or fast forward on my android phone and tablet. HI, we are working on improving this. Thanks.
Luke 42241 Posted May 28, 2024 Posted May 28, 2024 Regarding the web app problem, how does Chrome compare?
n0tanks87 6 Posted May 29, 2024 Author Posted May 29, 2024 16 hours ago, Luke said: Regarding the web app problem, how does Chrome compare? I can't on chrome. But I can rewind and fast forward on my roku device.
Luke 42241 Posted June 2, 2024 Posted June 2, 2024 On 5/29/2024 at 8:10 AM, n0tanks87 said: I can't on chrome. But I can rewind and fast forward on my roku device. But you can play?
n0tanks87 6 Posted June 4, 2024 Author Posted June 4, 2024 On 6/1/2024 at 10:32 PM, Luke said: But you can play? I can't on chrome. I can on Firefox. And on roku.
n0tanks87 6 Posted July 4, 2024 Author Posted July 4, 2024 On 6/30/2024 at 10:38 PM, Luke said: Hi, are you still having an issue with this? Yes I am. And sorry for the late response. I have been busy.
Luke 42241 Posted July 22, 2024 Posted July 22, 2024 @n0tanks87can you please provide a new log file example? Thanks ! 1
Solution n0tanks87 6 Posted July 22, 2024 Author Solution Posted July 22, 2024 4 hours ago, Luke said: @n0tanks87can you please provide a new log file example? Thanks ! I don't know what happened but after restarting my pc today and letting emby update it is working just fine. Didn't realize I had unchecked auto update. Every channel works now. No playback errors. Virtualtv plugin is working just fine as well. 1
