Skyecairns 1 Posted May 20, 2024 Posted May 20, 2024 Some artwork for Movies and TV Shows not showing up . I get a picture of a folder. If I go into the folder some of the episodes have pictures from the show. Some of the art work I do get has poor resolution. here's a picture of what i'm getting. Any thoughts
Happy2Play 9798 Posted May 20, 2024 Posted May 20, 2024 Without a server log it is hard to say. Maybe permission/provider issue/network issues?
Luke 42184 Posted May 20, 2024 Posted May 20, 2024 Hi @Skyecairnswhat metadata fetchers are enabled on the library, and in what order? What image fetchers are enabled on the library? Do your tv series folders have images inside them?
Skyecairns 1 Posted May 21, 2024 Author Posted May 21, 2024 I was using all the image fetchers available. The images were not inside my folder. Earlier I even tried using Kodi's Files-add videos and it was fast but didn't like result as much as I liked Emby as I had used Emby before. I felt like I was on a dial-up service. I eventally tried Identify with with IMBd's ID it was also extremely slow but worked sometimes I got no poster but then I tried Edit Images to get a poster. Bottom line all is well now. thanks for the help 1
