Hispanico957 23 Posted May 20, 2024 Posted May 20, 2024 If I try to search for a video (file title name) when I am inside a category for example "Animation", an error accessing the server etc. always appears. If I do the same search on Film, that is, all the films are regularly found. Is it a bug or what? Thank Hispa
Luke 42184 Posted May 20, 2024 Posted May 20, 2024 Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks.
Hispanico957 23 Posted May 20, 2024 Author Posted May 20, 2024 (edited) 2 hours ago, Luke said: Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks. Yess you are right i try on my NVidia Shield Pro Emby Androd and in this app the search also in categories run well. So the problem is Emby for Android Tv !? Thank again Hispa Edited May 20, 2024 by Hispanico957
Luke 42184 Posted May 20, 2024 Posted May 20, 2024 Quote Yess you are right i try on my NVidia Shield Pro Emby Androd Hi, are you happy continuing to use this?
Hispanico957 23 Posted May 21, 2024 Author Posted May 21, 2024 8 hours ago, Luke said: Hi, are you happy continuing to use this? Well honestly Emby for Android TV has more options and is graphically better than the pure Android version. Can't this be fixed for Android TV too? Hispa
Luke 42184 Posted May 21, 2024 Posted May 21, 2024 18 hours ago, Hispanico957 said: Well honestly Emby for Android TV has more options and is graphically better than the pure Android version. Can't this be fixed for Android TV too? Hispa Hi, more options such as what? What option is missing that you would like to see?
Hispanico957 23 Posted June 13, 2024 Author Posted June 13, 2024 So to summarize this problem of the search in the categories not working, it is present in the Emby version for Android TV and not in the Android version. Sorry Staff, isn't it possible to fix this BUG so as to have the two versions as similar as possible in terms of use? Thank Hispa
Luke 42184 Posted June 13, 2024 Posted June 13, 2024 HI, we are trying to consolidate our efforts so that we don't have to build everything twice. Have you tried the latest version of the Emby standard android app?
Hispanico957 23 Posted June 14, 2024 Author Posted June 14, 2024 6 hours ago, Luke said: HI, we are trying to consolidate our efforts so that we don't have to build everything twice. Have you tried the latest version of the Emby standard android app? Yep with standard android app this issue not happened as I already said above ...the bug is on Emby for Android TV Thank Hispa 1
