Victor240 1 Posted June 23, 2024 Author Posted June 23, 2024 Unfortunately, it's not working. While the episodes were added to trakt after adding more episodes and checking again, everything was removed. I've added a new log in case it's helpful. embyserver20240623.txt
Luke 42248 Posted June 24, 2024 Posted June 24, 2024 4 hours ago, Victor240 said: Unfortunately, it's not working. While the episodes were added to trakt after adding more episodes and checking again, everything was removed. I've added a new log in case it's helpful. embyserver20240623.txt 29.2 MB · 0 downloads What was removed exactly? Did you try browsing your library on the trakt website?
Victor240 1 Posted June 24, 2024 Author Posted June 24, 2024 Collected episodes were removed, there are two examples: For this show, episodes 1 to 8 are present in emby and were also added to trakt, now only episode 8 is shown in trakt collection. On this occasion, episodes 1 to 3 are present in emby and were also added in trakt and now none of them is shown in trakt So in both cases, episodes were added to trakt as soon as they were added to emby but later were removed from trakt with no change in emby.
Luke 42248 Posted July 1, 2024 Posted July 1, 2024 How do you know that Emby removed them from Trakt?
Victor240 1 Posted July 1, 2024 Author Posted July 1, 2024 I don't know that emby removed them, it's most probably the trakt plugin in emby because there's nothing else connected to trakt.
sadistpanda 2 Posted August 22, 2024 Posted August 22, 2024 (edited) I am having same issue. New shows are getting picked up in emny but not all shows new seasons are added to trakt. No errors, sync goes fine. For example Futurama gets added to collection, The serpent queen and evil (2019) aren't Edited August 22, 2024 by sadistpanda
Victor240 1 Posted August 25, 2024 Author Posted August 25, 2024 On 7/20/2024 at 4:13 AM, Luke said: Hi, are you still having an issue with this? Hi @Luke, yes the issue persists.
Victor240 1 Posted September 2, 2024 Author Posted September 2, 2024 @LukeIs there something I can provide you that might help with a solution?
sadistpanda 2 Posted September 10, 2024 Posted September 10, 2024 Same Boat. Most tvshows get added perfectly, scrobbling works also but certain Tv shows dont get the latest season updated: example: SEAL TEAM - latest season EVIL (2019) - Latest Season Serpent Queen - Latest Season Plenty more but these popped up. No real errors in log files. Just doesnt get picked up by trakt
sadistpanda 2 Posted September 10, 2024 Posted September 10, 2024 Forgot to add my serverlog. I know some of the anime isnt properly detected but that is not the this. Example is SEAL TEAM for example; it is properly detected by emby but not send to Trakt collection. There are more shows but thats a running one. embyserver.txt
