taromisaki 0 Posted May 17, 2024 Posted May 17, 2024 I'm a problem with database, now my server emby is inactive. I tried restoring the database but after a few weeks the error returns. Please help me..... embyserver-63851549010.txt
Neminem 1623 Posted May 17, 2024 Posted May 17, 2024 It looks like a permissions issue. SQLitePCL.pretty.SQLiteException: ReadOnly: attempt to write a readonly database
taromisaki 0 Posted May 17, 2024 Author Posted May 17, 2024 I put 755 to all files in /var/lib/emby/data/.... It still does not work
Neminem 1623 Posted May 17, 2024 Posted May 17, 2024 Tbh I have no clue about linux permissions. I just found that log entry.
taromisaki 0 Posted May 17, 2024 Author Posted May 17, 2024 (edited) What do you suggest to solve it? Do you need any other logs? embyserver-63851558760.txt embyserver-63851558891.txt Edited May 17, 2024 by taromisaki Insert new Emby log
Neminem 1623 Posted May 17, 2024 Posted May 17, 2024 I have no clue, I was trying to point you in the right direction. In you new logs i see System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path '/var/lib/emby/data/lastversion.txt' is denied. and SQLitePCL.pretty.SQLiteException: ReadOnly: attempt to write a readonly database - PRAGMA journal_mode Have you look in the server documentation Linux | Emby Documentation There is a link to something about permissions An Introduction to Linux Permissions | DigitalOcean
kikinjo 294 Posted May 17, 2024 Posted May 17, 2024 Try this 3 commands: sudo setfacl -m u:emby:rwx /var/lib/emby/ sudo setfacl -R -m u:emby:rwx /var/lib/emby/ sudo setfacl -R -d -m u:emby:rwx /var/lib/emby/ restart emby and test
taromisaki 0 Posted May 17, 2024 Author Posted May 17, 2024 I gave the command: sudo /opt/emby-server/bin/emby-server because "Error in appHost.Init " Now it work!
Happy2Play 9812 Posted May 17, 2024 Posted May 17, 2024 I would look at the discussion here. As it appear to be the same issue. Jumped to the middle.
taromisaki 0 Posted May 20, 2024 Author Posted May 20, 2024 (edited) I updated to version 4.8.7.0 and now emby won't start. I read an error in the database, I restored library.db and replaced the corrupt file with the restored one. Now dont' work. How do I get it to restart? embyserver-63851793097.txt Edited May 20, 2024 by taromisaki
taromisaki 0 Posted May 20, 2024 Author Posted May 20, 2024 (edited) What solution do you propose? Edited May 20, 2024 by taromisaki
Happy2Play 9812 Posted May 20, 2024 Posted May 20, 2024 7 hours ago, taromisaki said: I updated to version 4.8.7.0 and now emby won't start. I read an error in the database, I restored library.db and replaced the corrupt file with the restored one. Now dont' work. How do I get it to restart? embyserver-63851793097.txt 22.04 kB · 2 downloads What exactly did you do as you have a corrupt database. Corrupt: database disk image is malformed I guess the question becomes was the db corrupt before the update?
taromisaki 0 Posted May 21, 2024 Author Posted May 21, 2024 19 hours ago, Happy2Play said: What exactly did you do as you have a corrupt database. Corrupt: database disk image is malformed I guess the question becomes was the db corrupt before the update? The database was not corrupt before the upgrade. However, in recent months he has become easily corrupted. I did the database recovery guide via: sqlite3 library.db ".recover" | sqlite3 library-recovered.db and I replaced the library with the copy of the recovered one. But not often does it return to being corrupt. Is there a method to analyze the library and identify where it is corrupt?
Luke 42244 Posted May 22, 2024 Posted May 22, 2024 HI, are you ever force killing the emby server process? That is probably the leading way to cause this.
taromisaki 0 Posted May 22, 2024 Author Posted May 22, 2024 (edited) 54 minutes ago, Luke said: HI, are you ever force killing the emby server process? That is probably the leading way to cause this. Yes I had some unexpected server crashes a while ago. Are there any remedies for this problem? Edited May 22, 2024 by taromisaki
Luke 42244 Posted May 22, 2024 Posted May 22, 2024 HI, remedies for what exactly? If you're referring to a server crash, we'd have to look at a specific example of that: How to Report a Problem Thanks.
Happy2Play 9812 Posted May 22, 2024 Posted May 22, 2024 42 minutes ago, taromisaki said: Yes I had some unexpected server crashes a while ago. Are there any remedies for this problem? I guess it really depends on what/how the database is corrupted and what is actually corrupt within the database.
taromisaki 0 Posted May 22, 2024 Author Posted May 22, 2024 (edited) 5 minutes ago, Happy2Play said: I guess it really depends on what/how the database is corrupted and what is actually corrupt within the database. What could be the possible solution? Format and reinstall ubuntu server and restore a working emby backup? Edited May 22, 2024 by taromisaki
Happy2Play 9812 Posted May 22, 2024 Posted May 22, 2024 (edited) 4 minutes ago, taromisaki said: What could be the possible solution? Format and reinstall ubuntu server and restore a working emby backup? In the end if it is a Corrupt: database disk image is malformed if recovery process does not fix the issue you have to create a new library.db and is now really problematic as all library configs only exist within the database. So it may be a matter of how may database backups you maintian and if all of them are corrupt? Edited May 22, 2024 by Happy2Play
