hjason7812 35 Posted January 27, 2019 Posted January 27, 2019 you mean: Install dependencies: sudo pkg install mono libass fontconfig freetype2 fribidi gnutls iconv opus samba48 sqlite3 libtheora libva libvorbis webp libx264 libzvbi libraw Install Emby Server: pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/4.0.1.0/emby-server-freebsd_4.0.1.0_amd64.txz sysrc emby_server_enable="YES" service emby-server start when i browse to https://github.com/MediaBrowser/Emby.Releases/releases/download/4.0.1.0/emby-server-freebsd_4.0.1.0_amd64.txz it works fine tho This is what i get when i try to install the sudo.. sudo pkg install mono libass fontconfig freetype2 fribidi gnutls iconv opus samba48 sqlite3 libtheora libva libvorbis webp libx264 libzvbi libraw Updating local repository catalogue... pkg: Repository local load error: access repo file(/var/db/pkg/repo-local.sqlite) failed: No such file or directory pkg: file:///usr/ports/packages/meta.txz: No such file or directory repository local has no meta file, using default settings pkg: file:///usr/ports/packages/packagesite.txz: No such file or directory Unable to update repository local Error updating repositories! And this is what happens when i try to install the new emby server Installing emby-server-4.0.1.0_1... pkg: Missing dependency 'libass' Failed to install the following 1 package(s): https://github.com/MediaBrowser/Emby.Releases/releases/download/4.0.1.0/emby-server-freebsd_4.0.1.0_amd64.txz [root@@freenas ~]# sysrc emby_server_enable="YES" emby_server_enable: YES -> YES [root@@freenas ~]# service emby-server start emby-server does not exist in /etc/rc.d or the local startup directories (/etc/ix.rc.d /usr/local/etc/rc.d), or is not executable I can't install the server on the plugin page either 3.5.3.0 version it ends in an error..
makarai 109 Posted January 27, 2019 Posted January 27, 2019 (edited) You need to understand on what type of operation system you are. And what type of Instructions you are using. From you console command you are clearly on FreeNAS and not a FreeBSD. For the installation that you seek please do the following: Delete all emby related plugins / jails. Makesure you are on the newest freenas version system > update. Then Open a shell: Simple Installation Requires FreeNAS 11.2 Stable This Installation method will create a Jail that is fully configurable via the FreeNAS GUI LATEST STABLE (4010) cd /tmp wget https://raw.githubusercontent.com/ma-karai/iocage-plugin-emby/master/emby-server.json iocage fetch -P dhcp=on vnet=on bpf=yes allow_raw_sockets=1 -n emby-server.json --branch 'master' Edited April 26, 2019 by makarai
hjason7812 35 Posted January 27, 2019 Posted January 27, 2019 Freenas is freebsd though. There's nothing emby on there it wouldn't install.. I'll try this thank you
adrianwi 279 Posted January 27, 2019 Posted January 27, 2019 FreeNAS is built on FreeBSD, yes, but you can't just apply things in the same way. For a start, you really shouldn't be trying to install anything directly into the FreeNAS appliance. It's a great way to break it, and you'll struggle to get whatever it is working anyway. You need to be using jails or the plug-ins for installing other software which is what @makarai instructions will do (in this case creating a jail)
hjason7812 35 Posted January 27, 2019 Posted January 27, 2019 You need to understand on what type of operation system you are. And what type of Instructions you are using. From you console command you are clearly on FreeNAS and not a FreeBSD. For the installation that you seek please do the following: Delete all emby related plugins / jails. Makesure you are on the newest freenas version system > update. Then Open a shell: Simple Installation Requires FreeNAS 11.2 Stable This Installation method will create a Jail that is fully configurable via the FreeNAS GUI LATEST STABLE (4010) cd /tmp wget https://raw.githubusercontent.com/bott0r/iocage-plugin-emby/master/emby-server.json iocage fetch -P dhcp=on vnet=on bpf=yes allow_raw_sockets=1 -n emby-server.json --branch 'master' I tried this and got an error after it installed everything and then it said it destroyed emby server.. They really should've just updated the plugin that way we could just install from there.. Much easier and worked every time before.
makarai 109 Posted January 27, 2019 Posted January 27, 2019 (edited) I tried this and got an error after it installed everything and then it said it destroyed emby server.. They really should've just updated the plugin that way we could just install from there.. Much easier and worked every time before. Are you on FreeNAS-11.2-RELEASE-U1 What error? the plugin will make it to freshports at somepoint Edited January 27, 2019 by makarai
hjason7812 35 Posted January 27, 2019 Posted January 27, 2019 FreeNAS is built on FreeBSD, yes, but you can't just apply things in the same way. For a start, you really shouldn't be trying to install anything directly into the FreeNAS appliance. It's a great way to break it, and you'll struggle to get whatever it is working anyway. You need to be using jails or the plug-ins for installing other software which is what @makarai instructions will do (in this case creating a jail) The emby server in the available plugins is the old version and will not install.. Trust me i tried just ends in error.. i've been fighting with this since they changed to the iocage crap.. been using emby on a separate pc every since, but would like to get it back on freenas again because it runs much faster that way..
hjason7812 35 Posted January 27, 2019 Posted January 27, 2019 (edited) Are you on FreeNAS-11.2-RELEASE-U1 What error? the plugin will make it to freshports at somepoint Yes i am on the new release, i am currently running it again to see if it goes through this time. if i get the error again i'll post it.. Edit: It happened again, here is where it stopped Fetching artifact... Exception: URLError:<urlopen error [Errno 8] hostname nor servname provided, ornot known> occured, destroyed emby-server. Edited January 27, 2019 by hjason7812
adrianwi 279 Posted January 27, 2019 Posted January 27, 2019 You’re right again, in that the transition to iocage has been a little painful but it’s much better than warden. The plugins on FreeNAS have always been a compromise in my opinion as you’re in someone else’s hands for updates. Us the instructions above to create a iocage jail and you should have no problems keeping it up to date with a couple of shell commands, even running beta versions if that takes your fancy.
hjason7812 35 Posted January 27, 2019 Posted January 27, 2019 You’re right again, in that the transition to iocage has been a little painful but it’s much better than warden. The plugins on FreeNAS have always been a compromise in my opinion as you’re in someone else’s hands for updates. Us the instructions above to create a iocage jail and you should have no problems keeping it up to date with a couple of shell commands, even running beta versions if that takes your fancy. As you can see by the post above you the shell command didn't go as well as i would've hoped for
adrianwi 279 Posted January 27, 2019 Posted January 27, 2019 Where did you type the command? The FreeNAS shell? Can you get an external connection? What does ping google.com return? Have you used iocage before for anything?
makarai 109 Posted January 27, 2019 Posted January 27, 2019 (edited) Ok, this is an error is a network issue, can you do me a favor and install from the plugins (irrsi) and let me know if its succeed to install. Also can you give me printout if ifconfig Edited January 27, 2019 by makarai
hjason7812 35 Posted January 27, 2019 Posted January 27, 2019 Where did you type the command? The FreeNAS shell? Can you get an external connection? What does ping google.com return? Have you used iocage before for anything? Yes in the shell, yes external connection is just fine and no been trying to install emby since the conversion to iocage..
hjason7812 35 Posted January 27, 2019 Posted January 27, 2019 Ok, this is an error when the network interface can not be properly installed/initialized, can you do me a favor and install from the plugins (irrsi) and let me know if its succeed to install. It doesn't because it is the old version 3.5.3.0 it ends in the same error
makarai 109 Posted January 27, 2019 Posted January 27, 2019 (edited) It doesn't because it is the old version 3.5.3.0 it ends in the same error uninstall all existing plugins and Install the plugin named IRRSI not emby. Its because your jail network is not properly initialized Edited January 27, 2019 by makarai
adrianwi 279 Posted January 27, 2019 Posted January 27, 2019 Can you even get a FreeBSD release using iocage? > iocage fetch -r LATEST
hjason7812 35 Posted January 27, 2019 Posted January 27, 2019 (edited) uninstall all existing plugins and Install the plugin named IRRSI not emby. Its because your jail network is not properly initialized i get an error Edited January 27, 2019 by hjason7812
makarai 109 Posted January 27, 2019 Posted January 27, 2019 i get an error So you network, is not properly setup, its a freeNAS issue and not a emby issue. Can you give me the print out for the command ifconfig and post it here.
hjason7812 35 Posted January 27, 2019 Posted January 27, 2019 (edited) So you network, is not properly setup, its a freeNAS issue and not a emby issue. Can you give me the print out for the command ifconfig and post it here. re0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE> ether 04:a6:f2:3a:c5 hwaddr :04:a6:f2:3a:c5 inet 192.168.1.33 netmask 0xffffff00 broadcast 192.168.1.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex>) status: active lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2 inet 127.0.0.1 netmask 0xff000000 nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> groups: lo bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 02:97:e0:be:22:00 nd6 options=1<PERFORMNUD> groups: bridge id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: re0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 20000 Edited January 27, 2019 by hjason7812
makarai 109 Posted January 27, 2019 Posted January 27, 2019 (edited) ok do you have any tunables from an earlier version of freenas such as System > TunablesVariable: cloned_interfaces, Value: bridge0, Type: rc.confVariable: ifconfig_bridge0, Value: addm vnet0 up, Type: rc.conf Edited January 27, 2019 by makarai
hjason7812 35 Posted January 27, 2019 Posted January 27, 2019 ok do you have any tunables from an earlier version of freenas such as System > Tunables Variable: cloned_interfaces, Value: bridge0, Type: rc.conf Variable: ifconfig_bridge0, Value: addm vnet0 up, Type: rc.conf No i don't have any of that, just have old boot versions in case the new ones don't work
makarai 109 Posted January 27, 2019 Posted January 27, 2019 (edited) I suppose you nas is in static ip address mode, can you set it to DHCP. You probably have to reboot the nas as well. I am sorry. If the network settings are not properly setup you will run into problems as soon as you want to use a network service. Edited January 27, 2019 by makarai
hjason7812 35 Posted January 27, 2019 Posted January 27, 2019 Yes i have it in static ip mode. would that cause this issue?
makarai 109 Posted January 27, 2019 Posted January 27, 2019 (edited) Yes i have it in static ip mode. would that cause this issue? only, if you have not setup a propper gateway and dns manually. The problem is: Your jail tries to create a virtual interface and tries to connect to the physical adapter, and this doesn't work and fails so jails and vm,s will be destroyed, it was a bug in freenas beta 2 or so. Now when you are on the newest version of freenas this should not happen anymore. Edited January 27, 2019 by makarai
hjason7812 35 Posted January 27, 2019 Posted January 27, 2019 (edited) ok, so i just put it in DHCP and it is restarting now. Edit: Server came back up tried to install random plugin and got the same error Edited January 27, 2019 by hjason7812
