Luke 42237 Posted October 12, 2018 Author Posted October 12, 2018 Try not doing a sync and then see if the issue remains. Thanks.
Drego344 23 Posted October 12, 2018 Posted October 12, 2018 it only seems to disconnect whenever kodi trys pulling from it
Drego344 23 Posted October 12, 2018 Posted October 12, 2018 i tried using the emby web same thing when i tried playing anything....it stays on when i not playing anything
Drego344 23 Posted October 12, 2018 Posted October 12, 2018 is there another way to get the kodi companion plugin
Luke 42237 Posted October 12, 2018 Author Posted October 12, 2018 i tried using the emby web same thing when i tried playing anything....it stays on when i not playing anything Server log?
Drego344 23 Posted October 12, 2018 Posted October 12, 2018 i delete everything and install the one in freenas database 3.3.10, sorry logs deleted....works.....but i cant install kodi companion....so no update.......this is driving me nuts
Smartypants 0 Posted October 12, 2018 Posted October 12, 2018 i delete everything and install the one in freenas database 3.3.10, sorry logs deleted....works.....but i cant install kodi companion....so no update.......this is driving me nuts What are you doing actually? Installing Emby from the plugins in FreeNAS or creating a jail and installing Emby in it? I'm just not sure to understand what you are doing.
Drego344 23 Posted October 12, 2018 Posted October 12, 2018 i did it both ways and no luck....im upgrading to 11.2
Smartypants 0 Posted October 13, 2018 Posted October 13, 2018 I'm just trying on 11.2 as well and I'm running quickly into some libraries version issues. Particularly libx264 which has been updated to v155. I'm now getting this error: Shared object "libx264.so.152" not found, required by "libavcodec.so.58" If I just rename libx264.so.155 to libx264.so.152 I'm getting this error: /usr/local/opt/emby-server/lib/libavcodec.so.58: Undefined symbol "x264_bit_depth" I got it working downgrading the version to 152 but it was a real pain. The way I'm seeing this is by installing the packages required separately from the Emby package, we are going to run into issues like this everytime a package get updated. I see that usr/local/opt/emby-server/lib contains some of the libraries required. Maybe they should all be there, including libx264.so.152 Just a thing to think about.
Luke 42237 Posted October 13, 2018 Author Posted October 13, 2018 The way I'm seeing this is by installing the packages required separately from the Emby package, we are going to run into issues like this everytime a package get updated Yes you are correct and that is something we may have to start doing, shipping our own versions of these.
Drego344 23 Posted October 13, 2018 Posted October 13, 2018 i got it working also...thank goodness.....but the library update is slow....even with real time monitoring on....i have a couple stuff downloaded about two hours now and they are still not in my library......i also have kodi companion......any suggestions?
Luke 42237 Posted October 13, 2018 Author Posted October 13, 2018 I would wait for the initial library scan to finish. Thanks.
Drego344 23 Posted October 13, 2018 Posted October 13, 2018 ok....thank you will check back in if no change
Luke 42237 Posted October 13, 2018 Author Posted October 13, 2018 As far as the realtime monitor goes, see my answer here: https://emby.media/community/index.php?/topic/63977-xigmanas-nas4free-realtime-monitoring-on-zfs/&do=findComment&comment=634979 Thanks.
Drego344 23 Posted October 14, 2018 Posted October 14, 2018 so every thing is working beautifully except for emby not displaying movie run time......i tried meta refresh, but no go....because of this i don't have a resume point in kodi.....any suggestions?
Luke 42237 Posted October 14, 2018 Author Posted October 14, 2018 Please see how to report a problem. thanks !
Drego344 23 Posted October 14, 2018 Posted October 14, 2018 i hope this is what you want server logs.txt
Luke 42237 Posted October 14, 2018 Author Posted October 14, 2018 Try updating to 3.6.0.55. Then repeat the tests you mentioned in your previous post. Thanks.
Drego344 23 Posted October 14, 2018 Posted October 14, 2018 i upgraded to version 3.6.0.55.....then i did a meta refresh.....and the runtime is still not displaying
Drego344 23 Posted October 14, 2018 Posted October 14, 2018 i also just notice that the web app wont play file.....but everything plays on kodi server logs.txt
