Duffyx 25 Posted February 8, 2019 Posted February 8, 2019 (edited) Hi guys, I authored a review of the new emby-server port. Shouldn't take to long now to get it in the ports tree ... https://reviews.freebsd.org/D19130 Edited February 8, 2019 by driesmp
hjason7812 35 Posted February 15, 2019 Posted February 15, 2019 Quick question.. How do i update emby now that it is all shell code? Thanks
Luke 42237 Posted February 15, 2019 Author Posted February 15, 2019 Quick question.. How do i update emby now that it is all shell code? Thanks How did you install?
hjason7812 35 Posted February 15, 2019 Posted February 15, 2019 (edited) How did you install? All through shell with the help of Makarai in this thread.. Emby says there is an update so i would like to know how to update it because i can't just click the update button anymore.. Edited February 15, 2019 by hjason7812
Luke 42237 Posted February 15, 2019 Author Posted February 15, 2019 You would just install the latest using the same procedure.
hjason7812 35 Posted February 15, 2019 Posted February 15, 2019 (edited) You would just install the latest using the same procedure. So it would be this? pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/4.0.2.0/emby-server-freebsd_4.0.2.0_amd64.txz Edited February 15, 2019 by hjason7812
Luke 42237 Posted February 15, 2019 Author Posted February 15, 2019 I would ask @@makarai because i don't know exactly what he had you do.
bluemonkey07 590 Posted February 15, 2019 Posted February 15, 2019 So it would be this? pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/4.0.2.0/emby-server-freebsd_4.0.2.0_amd64.txzThat worked for me, first "service emby-server stop" and after "service emby-server start"
hjason7812 35 Posted February 15, 2019 Posted February 15, 2019 I figured it out. No need to stop emby you need to go into the shell of emby and put in the code then whwn done restart emby.after that you are all up to date
hjason7812 35 Posted March 5, 2019 Posted March 5, 2019 got a problem with emby i can't go to it on anything including directly to the url. I can't use shell at all either it is just a blank screen can't type nor paste anything just stays blank.. any help would be greatly appreciated thanks
Luke 42237 Posted March 5, 2019 Author Posted March 5, 2019 got a problem with emby i can't go to it on anything including directly to the url. I can't use shell at all either it is just a blank screen can't type nor paste anything just stays blank.. any help would be greatly appreciated thanks If i recall you installed with @@makarai's custom install method, now that we're back in freebsd ports I would suggest using that. Thanks.
hjason7812 35 Posted March 5, 2019 Posted March 5, 2019 If i recall you installed with @@makarai's custom install method, now that we're back in freebsd ports I would suggest using that. Thanks. What do you mean freebsd ports? If you're talking about the plugin? It is still the 3.5.3 version or something like that. Also i can't do anything get all kinds of errors while trying to install a new versions of emby etc
Luke 42237 Posted March 6, 2019 Author Posted March 6, 2019 Our 4.0.1 release has been merged into freebsd ports.
hjason7812 35 Posted March 6, 2019 Posted March 6, 2019 Our 4.0.1 release has been merged into freebsd ports. i don't see it, it still says 3.5.3.0 on plugin's.. i don't know what these ports are how to find them nor install them.. never heard of it before... and the little snippets of info don't help either
makarai 109 Posted March 6, 2019 Posted March 6, 2019 (edited) freshports and the freenas plugins are different! Freenas plugins will only be updated quarterly so you have to wait until it shows a new version in the freenas plugin repository. FreenasPlugins get their plugins from Freshports, but it takes time. Edited March 6, 2019 by makarai
hjason7812 35 Posted March 6, 2019 Posted March 6, 2019 freshports and the freenas plugins are different! Freenas plugins will only be updated quarterly so you have to wait until it shows a new version in the freenas plugin repository. FreenasPlugins get their plugins from Freshports, but it takes time. Luke said it's there somewhere and he won't provide help until i install it..
makarai 109 Posted March 6, 2019 Posted March 6, 2019 @hjason7812 Did you update freenas? What the status of your current jails? What other plugins have you installed? Do you have a running emby atm? if yes which version?
hjason7812 35 Posted March 6, 2019 Posted March 6, 2019 Yes i updated to 11.2-u2.1 Up but can't go to emby on anything including direct url. No other plugins installed The emby version is 4.0.2.0
makarai 109 Posted March 6, 2019 Posted March 6, 2019 Luke said it's there somewhere and he won't provide help until i install it.. The freshports base has been updated 3 days ago it takes time until it makes it into freenas. Freenas only updates quarterly its plugins. So the plugin repository will not help you right this second.
makarai 109 Posted March 6, 2019 Posted March 6, 2019 (edited) Yes i updated to 11.2-u2.1 Up but can't go to emby on anything including direct url. No other plugins installed The emby version is 4.0.2.0 Have you fixed the vnet bug that is in freenas u2 atm? if not type this in the freenas shel! /bin/sh -c 'export JAILS="$(iocage list -h | cut -f 2)"; for jail in $JAILS; do iocage set vnet_default_interface=auto $jail; done; iocage set vnet_default_interface=auto default' Edited March 6, 2019 by makarai
hjason7812 35 Posted March 6, 2019 Posted March 6, 2019 (edited) No i haven't. The main shell or jail shell? Edited March 6, 2019 by hjason7812
makarai 109 Posted March 6, 2019 Posted March 6, 2019 (edited) if you still have the old emby jail running 4.0.8 or whatever we installed. Restart that jail and check if its working, if not please use the standard method of installing in one of my many posts. or here https://emby.media/community/index.php?/topic/60971-new-freenas-package-for-testing/page-7&do=findComment&comment=619899 Edited March 6, 2019 by makarai
hjason7812 35 Posted March 6, 2019 Posted March 6, 2019 (edited) yeah i still get the unable to connect page when going to the url. I guess i'll have to reinstall it again... thanks Edited March 6, 2019 by hjason7812
