makarai 109 Posted January 27, 2019 Posted January 27, 2019 ok, so i just put it in DHCP and it is restarting now. Ok your nas should have a different ip now. when its restarted post the output of ipconfig, then try to install irrsi again and check in ipconfig if the vnet0 interface has been created.
hjason7812 35 Posted January 27, 2019 Posted January 27, 2019 Ok your nas should have a different ip now. when its restarted post the output of ipconfig, then try to install irrsi again and check in ipconfig if the vnet0 interface has been created. Actually it didn't get a new ip, even though it is supposed to
makarai 109 Posted January 27, 2019 Posted January 27, 2019 (edited) ok, so i just put it in DHCP and it is restarting now. Edit: Server came back up tried to install random plugin and got the same error Can you give me the output of: uname -a , cat /etc/version and ifconfig Edited January 27, 2019 by makarai
adrianwi 279 Posted January 27, 2019 Posted January 27, 2019 It does sound like your FreeNAS networking isn't configured correctly. I'd try the following in the FreeNAS shell: > iocage activate > iocage fetch -r LATEST > iocage create -r LATEST -n test 1
hjason7812 35 Posted January 27, 2019 Posted January 27, 2019 Can you give me the output of: uname -a , cat /etc/version and ifconfig @@freenas ~]# uname -a FreeBSD freenas.local 11.2-STABLE FreeBSD 11.2-STABLE #0 r325575+fc3d65faae6(HEAD): Thu Dec 20 16:12:30 EST 2018 root@@nemesis.tn.ixsystems.com:/freenas-releng-final/freenas/_BE/objs/freenas-releng-final/freenas/_BE/os/sys/FreeNAS.amd64 amd64 @@freenas ~]# cat /etc/version FreeNAS-11.2-RELEASE-U1 (31f889bbf) @@freenas ~]# ifconfig re0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE> ether :04:a6:f2:3a:c5 hwaddr :04:a6:f2:3a:c5 inet 192.168.1.33 netmask 0xffffff00 broadcast 192.168.1.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex>) status: active lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2 inet 127.0.0.1 netmask 0xff000000 nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> groups: lo
makarai 109 Posted January 27, 2019 Posted January 27, 2019 another question are you in a virtualbox?
makarai 109 Posted January 27, 2019 Posted January 27, 2019 Create a new bridge: ifconfig bridge create ifconfig bridge0 addm re0 post ifconfig try IRRSI (not random) post ifconfig
hjason7812 35 Posted January 27, 2019 Posted January 27, 2019 (edited) Create a new bridge: ifconfig bridge create ifconfig bridge0 addm re0 post ifconfig try IRRSI (not random) post ifconfig Same error again on install ifconfig re0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE> ether :04:a6:f2:3a:c5 hwaddr :04:a6:f2:3a:c5 inet 192.168.1.33 netmask 0xffffff00 broadcast 192.168.1.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex>) status: active lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2 inet 127.0.0.1 netmask 0xff000000 nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> groups: lo bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 02:97:e0:be:22:00 nd6 options=1<PERFORMNUD> groups: bridge id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: re0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 20000 bridge1: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 02:97:e0:be:22:01 nd6 options=1<PERFORMNUD> groups: bridge id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 0 ifcost 0 port 0 Edited January 27, 2019 by hjason7812
makarai 109 Posted January 27, 2019 Posted January 27, 2019 (edited) ok my bad, your ifconfig output earlier did not contain a bridge adapter, so this does not help. repeat the following in order ifconfig bridge1 destroy ifconfig bridge0 destroy ifconfig #check if all bridges are gone ifconfig bridge create ifconfig bridge0 addm re0 ifconfig re0 up Edited January 27, 2019 by makarai
makarai 109 Posted January 27, 2019 Posted January 27, 2019 (edited) done ifconfig output ? and try irrsi again pls Edited January 27, 2019 by makarai
hjason7812 35 Posted January 27, 2019 Posted January 27, 2019 ifconfig output ? and try irrsi again pls Still the same error # ifconfig re0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE> ether 54:04:a6:f2:3a:c5 hwaddr 54:04:a6:f2:3a:c5 inet 192.168.1.33 netmask 0xffffff00 broadcast 192.168.1.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex>) status: active lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2 inet 127.0.0.1 netmask 0xff000000 nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> groups: lo bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 02:97:e0:be:22:00 nd6 options=1<PERFORMNUD> groups: bridge id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: re0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 20000 Thank you for helping by the way.. I think i might have to get on the server console and do some things.. But i am really tired so i am heading to bed right now. Feel free to add some stuff that you think of i could try.. Thanks again
makarai 109 Posted January 27, 2019 Posted January 27, 2019 man that sucks, i would refer to the freenas forum.
adrianwi 279 Posted January 27, 2019 Posted January 27, 2019 What network adapter do you have in your FreeNAS box? Is it a Realtek one?
Lilan 0 Posted January 27, 2019 Posted January 27, 2019 We also maintain the ports version. We should have 4.0 submitted there within a week or so. Thanks. Thanks, that's good to hear. Using the ports version should be the same as using the regular package, correct?
hjason7812 35 Posted January 28, 2019 Posted January 28, 2019 @@adrianwi i think it is a realtek it's an asus board they like using realtek
makarai 109 Posted January 28, 2019 Posted January 28, 2019 (edited) Still the same error # ifconfig re0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE> ether 54:04:a6:f2:3a:c5 hwaddr 54:04:a6:f2:3a:c5 inet 192.168.1.33 netmask 0xffffff00 broadcast 192.168.1.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex>) status: active lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2 inet 127.0.0.1 netmask 0xff000000 nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> groups: lo bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 02:97:e0:be:22:00 nd6 options=1<PERFORMNUD> groups: bridge id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: re0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 20000 Thank you for helping by the way.. I think i might have to get on the server console and do some things.. But i am really tired so i am heading to bed right now. Feel free to add some stuff that you think of i could try.. Thanks again I helped a guy yesterday with creating a standalone jail, just give it a try: https://emby.media/community/index.php?/topic/68990-emby-server-wont-start-at-jail-boot-up-term-undefined-variable/&do=findComment&comment=690903 Can you create a normal jail, with the GUI Jails > Add > fill out name > 11.2-release > next ? DHCP ticked vnet ticked next -> submit start the jail #enter the jail shell pkg install mono libass fontconfig freetype2 fribidi gnutls iconv opus samba48 sqlite3 libtheora libva libvorbis webp libx264 libzvbi libraw pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/4.0.1.0/emby-server-freebsd_4.0.1.0_amd64.txz sysrc -f /etc/rc.conf emby_server_enable="YES" service emby-server start 2>/dev/null restart jail if it gets an ip address add port and check Edited January 28, 2019 by makarai
hjason7812 35 Posted January 28, 2019 Posted January 28, 2019 I'll try this in a few and get back to ya
hjason7812 35 Posted January 28, 2019 Posted January 28, 2019 I helped a guy yesterday with creating a standalone jail, just give it a try: https://emby.media/community/index.php?/topic/68990-emby-server-wont-start-at-jail-boot-up-term-undefined-variable/&do=findComment&comment=690903 Can you create a normal jail, with the GUI Jails > Add > fill out name > 11.2-release > next ? DHCP ticked vnet ticked next -> submit start the jail #enter the jail shell sudo pkg install mono libass fontconfig freetype2 fribidi gnutls iconv opus samba48 sqlite3 libtheora libva libvorbis webp libx264 libzvbi librawpkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/4.0.1.0/emby-server-freebsd_4.0.1.0_amd64.txz sysrc -f /etc/rc.conf emby_server_enable="YES" service emby-server start 2>/dev/null restart jail if it gets an ip address add port and check Ok, i was able to create the jail i went into the jail shell and put in the sudo pkg install it failed and said sudo: command not found and for the add - f it says add: command not found
hjason7812 35 Posted January 28, 2019 Posted January 28, 2019 Sorry try without sudo something weird happened after i added the jail, i tried to install emby from the plug in menu again and it installed.. But it is the old version... How do i update it to the new version?
makarai 109 Posted January 28, 2019 Posted January 28, 2019 (edited) something weird happened after i added the jail, i tried to install emby from the plug in menu again and it installed.. But it is the old version... How do i update it to the new version? you dont Its based on an old freebsd, has tons of bugs, and when you update it will most likely break. Can you finish the other installation method. Also print out of ifconfig again (maybe you have a vnet adapter now) Edited January 28, 2019 by makarai
hjason7812 35 Posted January 28, 2019 Posted January 28, 2019 you dont Its based on an old freebsd, has tons of bugs, and when you update it will most likely break. Can you finish the other installation method. No it won't let me do anything with that line of code it all fails
makarai 109 Posted January 28, 2019 Posted January 28, 2019 (edited) error message? you need to be in the jails shell pkg install mono libass fontconfig freetype2 fribidi gnutls iconv opus samba48 sqlite3 libtheora libva libvorbis webp libx264 libzvbi libraw Edited January 28, 2019 by makarai
