mydefposse 3 Posted May 14, 2024 Posted May 14, 2024 Hi, We've switched ISP's and now have a Calix router and I just can't get the port to be seen on WAN. I have forwarded port 8096 as you can see. I have added a rule to the Windows Firewall, but the port remains closed Anyone have any experience with Calix routers? Thanks!
Luke 42184 Posted May 14, 2024 Posted May 14, 2024 HI, does this guide help you? https://www.purevpn.com/blog/port-forward-calix-router/ 1
mydefposse 3 Posted May 14, 2024 Author Posted May 14, 2024 Thanks - turns out my ISP put us behind a CGNAT, so I'll call them tomorrow to ask for a static IPv4 instead! 1
mydefposse 3 Posted May 14, 2024 Author Posted May 14, 2024 Just to update - the CGNAT was the issue. To anyone in the UK who is with Lit Fibre, you can call and ask to be switched to a static IPv4 for £5 a month and you will be able to port forward after this. 1
