herobucket 2 Posted May 12, 2024 Posted May 12, 2024 When I watch my media on the Emby web app with a Windows PC I have the ability to select the playback speed an all my files. When I watch the same media from the same NAS on the same network via the Emby app installed on an Nvidia Shield Pro, approximately 20% of the files don't give the option to change the playback speed. I can't see any clear pattern for why some do allow the speed to be changed and some don't. I'm wondering if this is expected behavior, and if there is anything I can do to have the ability to adjust the playback speed on all the files?
ebr 16337 Posted May 12, 2024 Posted May 12, 2024 1 hour ago, herobucket said: I can't see any clear pattern for why some do allow the speed to be changed and some don't. Hi. It is related to the audio. If you are bitstreaming a compressed audio format (DTS, DD etc.) there is no way to change the playback speed.
