EmbFinPlex 3 Posted May 11, 2024 Posted May 11, 2024 When I try to tune to a channel with a recording in-progess, I only have the option to watch the channel from the current live state as opposed to the beginning of the recording. When the playback begins, I can only rewind it to the point that I tuned to the channel. Only when the recording finishes does it show up under my TV Shows library and I can start the playback from the beginning. I thought in the past there was an option to start playback from the beginning of a recording when it was in-progess. Currently, I can't see any way to start the playback of an in-progess recording from the beginning until it finishes recording. Am I missing something? Currently running Emby 4.8.0.18 beta on Windows with the 2.0.98a FireTV app.
Solution Luke 42241 Posted May 12, 2024 Solution Posted May 12, 2024 Hi, when you play from the live TV section, it will just play the channel from the live position. Eden you play from the library, it will play from the beginning. We need to improve this so that both options are available no matter how you start playing. 1
ebr 16335 Posted May 13, 2024 Posted May 13, 2024 On 5/10/2024 at 9:53 PM, EmbFinPlex said: I thought in the past there was an option to start playback from the beginning of a recording when it was in-progess. There was but I think the server changed how it is handling in-progress recordings such that the app can no longer determine that. 1
EmbFinPlex 3 Posted May 13, 2024 Author Posted May 13, 2024 Thanks all, I thought I had seen a "play from beginning" option but I was probably confusing it with Plex. I just wanted to make sure that I wasn't overlooking something. 1
