pgvince 0 Posted May 8, 2024 Posted May 8, 2024 I deploy my emby server in a docker container. After I input the Emby premiere in the server settings, it works fine for a while. But after some time or when I reboot the server, the premiere subscription is gone. And when I visit the premiere setting page, I can see the key is there but the page is always kept loading. The only workaround is I need to clear the key, click save then input the key and save again. It is pretty annoying that I need to reenter the key again and again. My emby version 4.8.5, I also tried to upgrade to 4.9.16 but it didn't help. Anyone know how to fix this, thanks.
Abobader 3484 Posted May 8, 2024 Posted May 8, 2024 Hello pgvince, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
ebr 16307 Posted May 8, 2024 Posted May 8, 2024 Hi. It has to be something in the configuration of the Docker or network that is interfering with validation. Can we see a server log from when it fails?
Neminem 1593 Posted May 8, 2024 Posted May 8, 2024 (edited) DId you make your config folder persistent, meaning saved outside you docker container. If not it will be deleted on restart of docker. How to Deal with Docker Container Persistence and Storage (howtogeek.com) Persist container data | Docker Docs Edited May 8, 2024 by jaycedk 1
Luke 42184 Posted June 24, 2024 Posted June 24, 2024 10 minutes ago, datianshi12 said: Did you get this sorted? HI there, are you having an issue?
datianshi12 1 Posted June 24, 2024 Posted June 24, 2024 3 minutes ago, Luke said: 您好,您遇到问题了吗? "Yeah, I think I had the same issue. It should be the same problem.
Luke 42184 Posted June 24, 2024 Posted June 24, 2024 19 minutes ago, datianshi12 said: "Yeah, I think I had the same issue. It should be the same problem. OK , did you go through the questions that were asked in this topic?
