DonMacaroni 55 Posted May 5, 2024 Posted May 5, 2024 (edited) For some reason, initiating playback via CarPlay always fails, while initiating it via IOS App, while connected to CarPlay always works. Maybe someone from Emby team can take a look, it is a bit frustrating, since technically (from end user perspective) Emby CarPlay "does not work". From logs, bunch of errors happen, around the time I attempted it, (search for string "Halo" which is track name) or Timestamp starting from 15:48 Client is latest from AppStore, connection is over Wireguard to the server (Emby unfortunately does not support CarPlay on downloaded files, yet) embyserver.txt Edited May 5, 2024 by DonMacaroni 2
Guest Posted May 7, 2024 Posted May 7, 2024 This has been a problem since 2022, maybe even before that. It's still not resolved. I believe it's due to the size of the library. I have over 10K albums and i pretty much cannot play anything. One way i can get it to play is if line up an album or playlist on the phone and then press play once it's connected via carplay. But searching, browsing or playing via carplay produces the same results as you and many others. Having moved over from Plex where this works amazingly well. It's very disappointing considering this is a paid Emby premiere feature.
DonMacaroni 55 Posted May 7, 2024 Author Posted May 7, 2024 (edited) So, if I have 10 tracks under “favourites”, it still tries to fetch entire library (100k+ items) when I press play on one of those favourite tracks? It is insane, who implements things like that? I moved away from Plex, their android app thinks that my TV is an Phone and refuses to output multichannel audio to ARC or via TosLink. So going back to Plex is not an option either. Edited May 7, 2024 by DonMacaroni
DonMacaroni 55 Posted May 7, 2024 Author Posted May 7, 2024 I must admit, I do love Emby and responsivness of the dev’s here, despite all those small inconveniences, which hopefully will be fixed one day. 1
sjkiss 28 Posted October 15, 2024 Posted October 15, 2024 On 5/7/2024 at 12:44 PM, DonMacaroni said: I must admit, I do love Emby and responsivness of the dev’s here, despite all those small inconveniences, which hopefully will be fixed one day. My sentiments exactly.
Luke 42239 Posted January 2, 2025 Posted January 2, 2025 Hi, we're looking into this. Thanks for reporting. 2
sjkiss 28 Posted March 28, 2025 Posted March 28, 2025 Carplay is not functional in the current iteration of Emby for IoS 2.2.36 . Can you please address when it will be functional? Thank you. 1
Depechie 12 Posted June 26, 2025 Posted June 26, 2025 Just here to say that I’m in the same situation… unable to start playing anything through CarPlay because op lib size. 2
cprzro 0 Posted August 19, 2025 Posted August 19, 2025 Hi, I’m experiencing the same issue with content not loading on Apple CarPlay. Or am I missing something? Do I need a subscription for this? Before I purchase a full Emby account, I want to test the server and apps myself. (At the moment, my server is running without SSL – are there any specific settings I need to adjust in the Emby configuration for the carplay app?)
DonMacaroni 55 Posted August 19, 2025 Author Posted August 19, 2025 (edited) Emby CarPlay is simply broken, not much you can do. Dev’s have to fix it, but it has not been a priority, I guess. As far as I can tell, it breaks as it tries to fetch the full library whn tou fire it up and fails. Edited August 19, 2025 by DonMacaroni 1
cprzro 0 Posted August 19, 2025 Posted August 19, 2025 Okay, then the app still needs some development. Alternatively, I'm satisfied that I can at least play audiobooks or music through the phone, and then, for example, the forward and backward options work in CarPlay. For the convenient solution via the CarPlay app, I'll have to be patient
DonMacaroni 55 Posted October 11, 2025 Author Posted October 11, 2025 (edited) @Lukeunfortunately not much difference, it is still pretty much unusable, while navigation seems to be ok now (unless yous elect something crazy, like all albums or something), playback still fails. I will have more time tomorrow, to dump logs, etc. Edited October 11, 2025 by DonMacaroni 1
Depechie 12 Posted October 23, 2025 Posted October 23, 2025 Same here… latest server version. Selecting albums always results in error popup.
Luke 42239 Posted October 28, 2025 Posted October 28, 2025 On 10/11/2025 at 4:08 AM, DonMacaroni said: @Lukeunfortunately not much difference, it is still pretty much unusable, while navigation seems to be ok now (unless yous elect something crazy, like all albums or something), playback still fails. I will have more time tomorrow, to dump logs, etc. Hi there, please attach the Emby server log from when the problem occurred: How to Report a Problem Thanks!
DonMacaroni 55 Posted October 28, 2025 Author Posted October 28, 2025 @Lukeunfortunately, unable to do so for 3-4 weeks. Travelling. 1
Depechie 12 Posted February 3 Posted February 3 Just did a check again… The CarPlay app keeps giving could not load content. But retrying the same action will work after a few tries. the logs are filled with coverartarchive calls during the same time. And not of the content being selected… so I guess it is just the fact that with large music libs the server does not respond in time for CarPlay not sure if some optimalisation can be done in code to only smart load what is selected? also during CarPlay browsing the art is not needed only until you are on track detail? Not sure if the cover art is shown in other views? 2026-02-03 18:54:07.133 Info HttpClient: Http response 200 from http://coverartarchive.org/release/4bdde761-c506-434e-8c8c-42a9c7136c06/34017038984.jpg after 2641ms 2026-02-03 18:54:07.222 Info HttpClient: Http response 200 from http://coverartarchive.org/release/5940381b-0f00-4e58-9ca8-a3759f24fe57/5970332162.png after 2827ms 2026-02-03 18:54:07.414 Info ProviderManager: Saving image to /var/lib/emby/metadata/musicalbums/Fairytales from the underground-musicbrainzalbum-4bdde761-c506-434e-8c8c-42a9c7136c06/folder.jpg 2026-02-03 18:54:08.910 Info ProviderManager: Saving image to /var/lib/emby/metadata/musicalbums/Ezoa En Niet Anders-musicbrainzalbum-5940381b-0f00-4e58-9ca8-a3759f24fe57/folder.png 2026-02-03 18:54:15.092 Info HttpClient: GET http://coverartarchive.org/release/38e091d2-65ea-48c8-9603-92d44d6941a3/10084023527.jpg 2026-02-03 18:54:15.726 Info HttpClient: Http response 200 from http://coverartarchive.org/release/38e091d2-65ea-48c8-9603-92d44d6941a3/10084023527.jpg after 633ms 2026-02-03 18:54:16.495 Info ProviderManager: Saving image to /var/lib/emby/metadata/musicalbums/Judas -musicbrainzalbum-38e091d2-65ea-48c8-9603-92d44d6941a3/folder.jpg 2026-02-03 18:54:19.871 Info HttpClient: GET http://coverartarchive.org/release/4102fb55-daa6-4cec-a8eb-7dd35f840049/34586010077.jpg 2026-02-03 18:54:20.016 Info HttpClient: GET https://coverartarchive.org/release/72e4c53a-348e-47a6-b2e2-22c475ef27ec/41692044176.jpg 2026-02-03 18:54:20.966 Info HttpClient: Http response 200 from https://coverartarchive.org/release/72e4c53a-348e-47a6-b2e2-22c475ef27ec/41692044176.jpg after 949ms 2026-02-03 18:54:22.040 Info ProviderManager: Saving image to /var/lib/emby/metadata/musicalbums/Late Night Tales-musicbrainzalbum-72e4c53a-348e-47a6-b2e2-22c475ef27ec/folder.jpg 2026-02-03 18:54:22.628 Info HttpClient: Http response 200 from http://coverartarchive.org/release/4102fb55-daa6-4cec-a8eb-7dd35f840049/34586010077.jpg after 2757ms 2026-02-03 18:54:23.489 Info ProviderManager: Saving image to /var/lib/emby/metadata/musicalbums/Last Curtain Call-musicbrainzalbum-4102fb55-daa6-4cec-a8eb-7dd35f840049/folder.jpg
DonMacaroni 55 Posted March 2 Author Posted March 2 Anyway, due to being low priority for devs. Started with small sideproject for myself, PlexAMP kind of App for Emby. I have a rough prototype, currently only supporting playlists and their playback. It will be IOS only (we have plenty of Android music players for Emby anyways). 1
Depechie 12 Posted March 2 Posted March 2 8 minutes ago, DonMacaroni said: Anyway, due to being low priority for devs. Started with small sideproject for myself, PlexAMP kind of App for Emby. I have a rough prototype, currently only supporting playlists and their playback. It will be IOS only (we have plenty of Android music players for Emby anyways). I already switched some time back to Narjo - https://narjomusic.com/ Which works perfectly with CarPlay and Emby. 1 2
DonMacaroni 55 Posted March 2 Author Posted March 2 Then I save myself from all the hassle, I guess... Was fun hack project though, never wrote mobile app before or even attempted to do so.
Steven 159 Posted March 7 Posted March 7 (edited) On 02/03/2026 at 21:22, Depechie said: I already switched some time back to Narjo - https://narjomusic.com/ Which works perfectly with CarPlay and Emby. This is really awesome and works amazingly well connected to my Emby server. I’ve been testing today while out and about in the car with no issues at all. Emby could never be quite the perfect dedicated music player as it does so many things, but this is going to be my go to when playing music at home. Thank you. Edited March 7 by Steven 1
sfatula 208 Posted March 15 Posted March 15 Narjo does work great for carplay for sure. Can't wait until they add the Apple TV version too. I converted from Cloudbeats which was ok.
