Dont1982 8 Posted May 3, 2024 Posted May 3, 2024 After I installed the latest update to emby, the live tv guide fails to update. It has done this the last 4 times it has tried to update. I have attached the logs, also I am using the emby supplied guides. It was working fine prior to the update. Any help would be greatly appreciated. embyserver.txt embyserver-63850349257.txt
Dont1982 8 Posted May 4, 2024 Author Posted May 4, 2024 12 minutes ago, ebr said: Hi. Try removing the ComsSkip plug-in. So the do skip plugin is what is making it not update? I reselected the guides and the live tv setup and it worked. This is prior to seeing this about removing comskip. If it does it again I will remove comskip and see if that does the trick. Is there any other plugin like comskip that does the same thing?
sa2000 690 Posted May 7, 2024 Posted May 7, 2024 (edited) @ebr - the Guide update ran but failed after a minute with an error. I do see ComSkipper errors later on. The guide update was at this time 2024-05-03 16:09:02.971 Info TaskManager: Executing Refresh Guide . . . 2024-05-03 16:10:33.918 Info TaskManager: Refresh Guide Failed after 1 minute(s) and 30 seconds The error was on a file access for "Emby-Server\programdata\data\livetv\timers.json'" - I presume it was a sharing violation clash on opening the file. System.IO.IOException: System.IO.IOException: The requested operation cannot be performed on a file with a user-mapped section open. : 'C:\Users\emby-server\AppData\Roaming\Emby-Server\programdata\data\livetv\timers.json' The full logged error was 2024-05-03 16:10:33.893 Debug SqliteItemRepository: GetitemById LiveTvProgram 2331171 Teen UFO, Flying Dinosaur Over Idaho, and Headless Goats 2024-05-03 16:10:33.914 Debug SqliteItemRepository: GetitemById LiveTvProgram 2331172 Spontaneous Human Combustion, The Tell-Tale Hum, and UFO Explosion 2024-05-03 16:10:33.918 Error TaskManager: Error *** Error Report *** Version: 4.8.5.0 Command line: C:\Users\emby-server\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19045 Framework: .NET 6.0.29 OS/Process: x64/x64 Runtime: C:/Users/emby-server/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 4 Data path: C:\Users\emby-server\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\emby-server\AppData\Roaming\Emby-Server\system System.IO.IOException: System.IO.IOException: The requested operation cannot be performed on a file with a user-mapped section open. : 'C:\Users\emby-server\AppData\Roaming\Emby-Server\programdata\data\livetv\timers.json' at Microsoft.Win32.SafeHandles.SafeFileHandle.CreateFile(String fullPath, FileMode mode, FileAccess access, FileShare share, FileOptions options) at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String fullPath, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize) at System.IO.Strategies.OSFileStreamStrategy..ctor(String path, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize) at System.IO.Strategies.FileStreamHelpers.ChooseStrategy(FileStream fileStream, String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, Int64 preallocationSize) at System.IO.FileStream..ctor(String path, FileStreamOptions options) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, Int32 bufferSize, FileOpenOptions fileOpenOptions, Int64 preAllocationSize) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileOpenOptions fileOpenOptions) at Emby.Common.Implementations.Serialization.JsonSerializer.SerializeToFile(Object obj, String file) at Emby.LiveTV.ItemDataProvider`1.UpdateList(List`1 newList) at Emby.LiveTV.TimerManager.Update(TimerInfo item) at Emby.LiveTV.EmbyTV.RefreshTimers(CancellationToken cancellationToken, IProgress`1 progress) at Emby.LiveTV.LiveTvManager.RefreshChannels(IProgress`1 progress, CancellationToken cancellationToken) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) Source: System.Private.CoreLib TargetSite: Microsoft.Win32.SafeHandles.SafeFileHandle CreateFile(System.String, System.IO.FileMode, System.IO.FileAccess, System.IO.FileShare, System.IO.FileOptions) There were loads of ComSkipper errors but logged after this - example (one of many) 2024-05-03 16:35:41.204 Error SessionManager: Error in event handler *** Error Report *** Version: 4.8.5.0 Command line: C:\Users\emby-server\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19045 Framework: .NET 6.0.29 OS/Process: x64/x64 Runtime: C:/Users/emby-server/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 4 Data path: C:\Users\emby-server\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\emby-server\AppData\Roaming\Emby-Server\system System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object. at ComSkipper.ServerEntryPoint.PlaybackProgress(Object sender, PlaybackProgressEventArgs e) at MediaBrowser.Common.Events.EventHelper.TriggerAll[T](EventHandler`1 mainHandler, Object sender, T args, ILogger logger) Source: ComSkipper TargetSite: Void PlaybackProgress(System.Object, MediaBrowser.Controller.Library.PlaybackProgressEventArgs) Edited May 8, 2024 by sa2000
Dont1982 8 Posted May 8, 2024 Author Posted May 8, 2024 ok i have deleted comskip. going to see if it works now.
Dont1982 8 Posted May 9, 2024 Author Posted May 9, 2024 It failed again this morning. Comskip has been uninstalled and server restarted yesterday. embyserver.txt
Luke 42184 Posted May 10, 2024 Posted May 10, 2024 13 hours ago, Dont1982 said: It failed again this morning. Comskip has been uninstalled and server restarted yesterday. embyserver.txt 1.24 MB · 0 downloads HI, can you try rebooting your machine and see if that helps?
Dont1982 8 Posted May 10, 2024 Author Posted May 10, 2024 I have done this multiple times. That was one of the first things I did.
sa2000 690 Posted May 10, 2024 Posted May 10, 2024 This is the same error that I saw in the earlier log - a file open clash on this System.IO.IOException: System.IO.IOException: The requested operation cannot be performed on a file with a user-mapped section open. : 'C:\Users\emby-server\AppData\Roaming\Emby-Server\programdata\data\livetv\timers.json' with the full error being 2024-05-09 08:50:37.122 Info LiveTV: Found existing series based on provider ids: 2365438 2024-05-09 08:50:37.128 Error TaskManager: Error *** Error Report *** Version: 4.8.6.0 Command line: C:\Users\emby-server\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19045 Framework: .NET 6.0.29 OS/Process: x64/x64 Runtime: C:/Users/emby-server/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 4 Data path: C:\Users\emby-server\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\emby-server\AppData\Roaming\Emby-Server\system System.IO.IOException: System.IO.IOException: The requested operation cannot be performed on a file with a user-mapped section open. : 'C:\Users\emby-server\AppData\Roaming\Emby-Server\programdata\data\livetv\timers.json' at Microsoft.Win32.SafeHandles.SafeFileHandle.CreateFile(String fullPath, FileMode mode, FileAccess access, FileShare share, FileOptions options) at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String fullPath, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize) at System.IO.Strategies.OSFileStreamStrategy..ctor(String path, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize) at System.IO.Strategies.FileStreamHelpers.ChooseStrategy(FileStream fileStream, String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, Int64 preallocationSize) at System.IO.FileStream..ctor(String path, FileStreamOptions options) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, Int32 bufferSize, FileOpenOptions fileOpenOptions, Int64 preAllocationSize) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileOpenOptions fileOpenOptions) at Emby.Common.Implementations.Serialization.JsonSerializer.SerializeToFile(Object obj, String file) at Emby.LiveTV.ItemDataProvider`1.UpdateList(List`1 newList) at Emby.LiveTV.TimerManager.Update(TimerInfo item) at Emby.LiveTV.EmbyTV.UpdateTimersForSeriesTimer(SeriesTimerInfo seriesTimer, Boolean updateTimerSettings, Boolean deleteInvalidTimers, SeriesMetadataState seriesMetadataState, CancellationToken cancellationToken) at Emby.LiveTV.EmbyTV.RefreshSeriesTimers(CancellationToken cancellationToken, IProgress`1 progress) at Emby.LiveTV.LiveTvManager.RefreshChannels(IProgress`1 progress, CancellationToken cancellationToken) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) Source: System.Private.CoreLib TargetSite: Microsoft.Win32.SafeHandles.SafeFileHandle CreateFile(System.String, System.IO.FileMode, System.IO.FileAccess, System.IO.FileShare, System.IO.FileOptions) 2024-05-09 08:50:37.128 Debug TaskManager: Refresh Guide Failed after 3 minute(s) and 1 seconds As this appears reproducible and it is running on windows, we can troubleshoot the problem using https://learn.microsoft.com/en-us/sysinternals/downloads/procmon Server Debug Logging may also add some more info Would be happy to investigate and see what has the file locked out Please note that procmon PML files would be massive but they zip very well. Do not leave procmon running for long as it gobbles system resources - so enable debug logging on the server, run procmon to capture events then restart the server and start a guide refresh. Stop procmon capture when it fails and save all as PML and zip and upload externally and send me a link by private message and would also need the server log to see the time of the file access error Do you run some auto backup software that may have locked the file out at that time? What antivirus / security software do you have running There are some tools that list all open files - you could use these before starting to capture diagnostics to see if the file is open by any process The file being 'C:\Users\emby-server\AppData\Roaming\Emby-Server\programdata\data\livetv\timers.json'
Dont1982 8 Posted May 12, 2024 Author Posted May 12, 2024 On 5/10/2024 at 2:17 PM, sa2000 said: This is the same error that I saw in the earlier log - a file open clash on this System.IO.IOException: System.IO.IOException: The requested operation cannot be performed on a file with a user-mapped section open. : 'C:\Users\emby-server\AppData\Roaming\Emby-Server\programdata\data\livetv\timers.json' with the full error being 2024-05-09 08:50:37.122 Info LiveTV: Found existing series based on provider ids: 2365438 2024-05-09 08:50:37.128 Error TaskManager: Error *** Error Report *** Version: 4.8.6.0 Command line: C:\Users\emby-server\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19045 Framework: .NET 6.0.29 OS/Process: x64/x64 Runtime: C:/Users/emby-server/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 4 Data path: C:\Users\emby-server\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\emby-server\AppData\Roaming\Emby-Server\system System.IO.IOException: System.IO.IOException: The requested operation cannot be performed on a file with a user-mapped section open. : 'C:\Users\emby-server\AppData\Roaming\Emby-Server\programdata\data\livetv\timers.json' at Microsoft.Win32.SafeHandles.SafeFileHandle.CreateFile(String fullPath, FileMode mode, FileAccess access, FileShare share, FileOptions options) at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String fullPath, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize) at System.IO.Strategies.OSFileStreamStrategy..ctor(String path, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize) at System.IO.Strategies.FileStreamHelpers.ChooseStrategy(FileStream fileStream, String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, Int64 preallocationSize) at System.IO.FileStream..ctor(String path, FileStreamOptions options) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, Int32 bufferSize, FileOpenOptions fileOpenOptions, Int64 preAllocationSize) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileOpenOptions fileOpenOptions) at Emby.Common.Implementations.Serialization.JsonSerializer.SerializeToFile(Object obj, String file) at Emby.LiveTV.ItemDataProvider`1.UpdateList(List`1 newList) at Emby.LiveTV.TimerManager.Update(TimerInfo item) at Emby.LiveTV.EmbyTV.UpdateTimersForSeriesTimer(SeriesTimerInfo seriesTimer, Boolean updateTimerSettings, Boolean deleteInvalidTimers, SeriesMetadataState seriesMetadataState, CancellationToken cancellationToken) at Emby.LiveTV.EmbyTV.RefreshSeriesTimers(CancellationToken cancellationToken, IProgress`1 progress) at Emby.LiveTV.LiveTvManager.RefreshChannels(IProgress`1 progress, CancellationToken cancellationToken) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) Source: System.Private.CoreLib TargetSite: Microsoft.Win32.SafeHandles.SafeFileHandle CreateFile(System.String, System.IO.FileMode, System.IO.FileAccess, System.IO.FileShare, System.IO.FileOptions) 2024-05-09 08:50:37.128 Debug TaskManager: Refresh Guide Failed after 3 minute(s) and 1 seconds As this appears reproducible and it is running on windows, we can troubleshoot the problem using https://learn.microsoft.com/en-us/sysinternals/downloads/procmon Server Debug Logging may also add some more info Would be happy to investigate and see what has the file locked out Please note that procmon PML files would be massive but they zip very well. Do not leave procmon running for long as it gobbles system resources - so enable debug logging on the server, run procmon to capture events then restart the server and start a guide refresh. Stop procmon capture when it fails and save all as PML and zip and upload externally and send me a link by private message and would also need the server log to see the time of the file access error Do you run some auto backup software that may have locked the file out at that time? What antivirus / security software do you have running There are some tools that list all open files - you could use these before starting to capture diagnostics to see if the file is open by any process The file being 'C:\Users\emby-server\AppData\Roaming\Emby-Server\programdata\data\livetv\timers.json' that's the thing. when I restart or manually run the refresh it works. For some reason the auto doesn't do it. And sometimes it does. When it fails again I will try to capture it. 1
sa2000 690 Posted May 13, 2024 Posted May 13, 2024 (edited) On 12/05/2024 at 17:16, Dont1982 said: For some reason the auto doesn't do it If you can work out when the next auto refresh is then can start enabling diagnostics a few minutes before that. It is important to confirm initially that the file concerned is not held open before the refresh starts Microsoft SysInternals have a tool for that - Handle.exe see Handle - Sysinternals | Microsoft Learn If the file is not open already when you start SysInternals process monitor then the capture will show what processes / threads open the file and then the failing one Please familiarize yourself with the tools beforehand and do some dummy runs Also have debug logging enabled but remember to have logs redacted before uploading here - or you could send me zipped raw unedited log files by private message together with the link for getting the zipped PML file from procmon and what handle.exe found Edited May 13, 2024 by sa2000
Dont1982 8 Posted May 14, 2024 Author Posted May 14, 2024 I run surfshark vpn. With the vpn off everything works fine. With it on it get the update error. any ideas on this? Also with it on I get a lot of channels that done work with it on, but same channels work with it off. I have contacted IPTV service and they state that a vpn has no effect on their services.
Luke 42184 Posted May 14, 2024 Posted May 14, 2024 3 hours ago, Dont1982 said: I run surfshark vpn. With the vpn off everything works fine. With it on it get the update error. any ideas on this? Also with it on I get a lot of channels that done work with it on, but same channels work with it off. I have contacted IPTV service and they state that a vpn has no effect on their services. Can you do more testing to confirm this? The file writing and vpn should be completely independent of each other. I think the results you saw are most likely coincidental. Thanks.
Dont1982 8 Posted May 14, 2024 Author Posted May 14, 2024 I have tested this multiple times. And I’m never home when the sever auto updates the guide. Since I have disconnected the vpn it has worked as it should. As soon as I connect the con and run a refresh it fails. Also I noticed that some of the live channels would not work with vpn on but would work fine with it off. 1
sa2000 690 Posted May 15, 2024 Posted May 15, 2024 Maybe the Surfshark vpn product has some security / anti virus / malware detection functionality included and has code that accesses files If not, may be it is changing the timing and this is a timing issue If the problem comes back, we will need to find out what is causing the file access sharing violation error on this file during guide refresh - "C:\Users\emby-server\AppData\Roaming\Emby-Server\programdata\data\livetv\timers.json" and Microsoft SysIntenternals tools like Handle and ProcMon together with the Emby Server logs will help with the invstigation
