jazztrance 0 Posted May 16, 2024 Author Posted May 16, 2024 5 minutes ago, Happy2Play said: Technically you have not tagged the album itself only folders. But I have tested tagging both via album tab and via folder tab with same results. I see - didn't realize the distinction. Tagged the album and artist now and refreshed metadata but still no albums showing in album view for the restricted user.
Luke 42301 Posted May 23, 2024 Posted May 23, 2024 OK from testing again I can confirm the issue with 4.8. We'll look into it. Thanks.
dpandkp 1 Posted November 22, 2024 Posted November 22, 2024 On 5/23/2024 at 1:56 PM, Luke said: OK from testing again I can confirm the issue with 4.8. We'll look into it. Thanks. Greetings Luke. Was this addressed in a release? I've been happy on 4.8.8.0 for awhile but decided to update to 4.8.10.0 to see if that would help and the issue persists. I see there are three beta builds and thought I'd see if one of those would make a difference. Thanks.
pwhodges 2039 Posted November 23, 2024 Posted November 23, 2024 Remember if you use a beta build on your main instance of Emby you can't go back, because it modifies the database. You should run up a separate test instance using the beta, or make a backup immediately before changing to beta. Paul
Luke 42301 Posted November 27, 2024 Posted November 27, 2024 On 11/22/2024 at 2:46 PM, dpandkp said: Greetings Luke. Was this addressed in a release? I've been happy on 4.8.8.0 for awhile but decided to update to 4.8.10.0 to see if that would help and the issue persists. I see there are three beta builds and thought I'd see if one of those would make a difference. Thanks. Hi, yes there are fixes related to this in the beta channel. Thanks.
