Guest Posted May 1, 2024 Posted May 1, 2024 Hello, Is there some setting that will overlay videos when they play in the web player so that they are lightened/washed out? I've seen it on different users on different computers (Windows) in Chrome. Not sure about other browsers. The overlay disappears when interacting with the player controls, for example by clicking on the settings icon in the player. Once the player controls are no longer actively being used (but still visible, and after hidden) the lightening overlay reappears. I've tinkered with the styles without any luck but honestly didn't spend a lot of time on it. Thanks for any feedback.
Solution Luke 42184 Posted May 1, 2024 Solution Posted May 1, 2024 Hi, there is nothing like this, but older versions of the server may have done the opposite - darkening while a menu was open and then removing that layer once closed.
Guest Posted May 2, 2024 Posted May 2, 2024 Thanks Luke. On reflection this is probably actually what's happening. The video is naturally very bright/washed out and this overlay is briefly darkening it.
