cubitfx 1 Posted April 30, 2024 Posted April 30, 2024 Some shows, like Supernatural and Brun Notice are starting with the audio track that includes director's commentary and I have to keep manually changing back to the primary audio track. Any helpful tips to figure out why this is happening?
Abobader 3484 Posted April 30, 2024 Posted April 30, 2024 Hello cubitfx, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Happy2Play 9799 Posted April 30, 2024 Posted April 30, 2024 What does Emby show in Media Info section for the problem shows?
cubitfx 1 Posted April 30, 2024 Author Posted April 30, 2024 Good question. I'll check and report back next time it happens! 1
cubitfx 1 Posted April 30, 2024 Author Posted April 30, 2024 Fortunately, it happened last night. It chose the "English AC3 Stereo" audio track instead of the "English DTS-HD MA 5.1 (Default)" audio track. Under "Stats for Nerds": Roku STB 3941x2 Emby 4.1.17 Stream MKV (26.54 Mbs) -> HLS (8Mbs 87 fps) Reducing bitrate due to quality setting Video 1080 H264 -> Transcode (H264 7.776 Mbs) Audio English DTS-HD MA 5.1 (Default) -> Direct Play
Luke 42184 Posted April 30, 2024 Posted April 30, 2024 @cubitfx Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
cubitfx 1 Posted May 1, 2024 Author Posted May 1, 2024 @Luke - Apologies for skipping steps. I missed that post somehow or I'd have followed it. I think the logs have rotated at this point, so I'll put a pin in this and the next time it happens, I'll grab logs right away.
visproduction 328 Posted May 2, 2024 Posted May 2, 2024 (edited) Discussion on how to change the audio track order of the media file: https://superuser.com/questions/1440629/change-audio-track-order-in-mkv-files You can also remux the file with AVIDemux and there is a way to switch audio tracks in the audio control menu. You just flip the choices of which comes first and remux or encode if you want to convert. Remuxing with encoding takes about 1 minute per 2 hour media. Edited May 2, 2024 by visproduction
visproduction 328 Posted May 3, 2024 Posted May 3, 2024 (edited) 23 hours ago, visproduction said: Remuxing with encoding takes about 1 minute per 2 hour media. Correction: Remuxing without encoding, takes about 1 minute per 2 hour media. Edited May 3, 2024 by visproduction
rbjtech 5335 Posted May 3, 2024 Posted May 3, 2024 2 hours ago, visproduction said: Correction: Remuxing without encoding, takes about 1 minute per 2 hour media. Not really sure you can put a duration on a remux operation. It's related to the size of the source file, media source (hdd/ssd) etc I can assume you that remuxing a 100 MB MKV on an NVME is of magnitudes faster than trying to remux a 100 GB MKV on a slow HDD .. 1
visproduction 328 Posted May 3, 2024 Posted May 3, 2024 It takes me under 2 minutes to remux 3GB on a notebook i7 Windows 10. That seemed like a good average. Who is archiving 100GB media? Whew!
Luke 42184 Posted May 3, 2024 Posted May 3, 2024 On 5/1/2024 at 10:34 AM, cubitfx said: @Luke - Apologies for skipping steps. I missed that post somehow or I'd have followed it. I think the logs have rotated at this point, so I'll put a pin in this and the next time it happens, I'll grab logs right away. @cubitfxyes that would be great, thanks.
Lessaj 479 Posted May 3, 2024 Posted May 3, 2024 1 hour ago, visproduction said: It takes me under 2 minutes to remux 3GB on a notebook i7 Windows 10. That seemed like a good average. Who is archiving 100GB media? Whew! That sounds kind of slow, but it is a laptop I guess. I can usually remux a file of that size within a few seconds. Return of the King is ~125GB. It takes me about 6 minutes to remux it. It's going to depend a lot on your hardware. 1
rbjtech 5335 Posted May 4, 2024 Posted May 4, 2024 (edited) 8 hours ago, Lessaj said: That sounds kind of slow, but it is a laptop I guess. I can usually remux a file of that size within a few seconds. Return of the King is ~125GB. It takes me about 6 minutes to remux it. It's going to depend a lot on your hardware. yep.. this is my point - an extreme example, but you are not going to remux this in 2 minutes .. 09/02/2024 15:00 672,673 clearlogo.png 05/11/2018 18:17 25,087,933 The Lord of the Rings- The Return of the King (2003) - Remux-2160p Extended DV HDR10-trailer.mkv 27/08/2023 04:07 16,346,336 The Lord of the Rings- The Return of the King (2003) - Remux-2160p Extended DV HDR10-320-10.bif 09/02/2024 15:00 524,129 landscape.jpg 22/04/2024 01:53 143,736,602,947 The Lord of the Rings- The Return of the King (2003) - Remux-2160p Extended DV HDR10.mkv 09/02/2024 15:00 2,073,973 fanart.jpg 09/02/2024 15:00 1,186,879 poster.jpg 26/01/2024 11:30 1,545,511 The Lord of the Rings- The Return of the King (2003) - Remux-2160p Extended DV HDR10-trailer.png 22/04/2024 03:58 17,746 The Lord of the Rings- The Return of the King (2003) - Remux-2160p Extended DV HDR10.nfo 9 File(s) 143,784,058,127 bytes Edited May 4, 2024 by rbjtech 1
Lessaj 479 Posted May 4, 2024 Posted May 4, 2024 8 hours ago, rbjtech said: yep.. this is my point - an extreme example, but you are not going to remux this in 2 minutes .. 09/02/2024 15:00 672,673 clearlogo.png 05/11/2018 18:17 25,087,933 The Lord of the Rings- The Return of the King (2003) - Remux-2160p Extended DV HDR10-trailer.mkv 27/08/2023 04:07 16,346,336 The Lord of the Rings- The Return of the King (2003) - Remux-2160p Extended DV HDR10-320-10.bif 09/02/2024 15:00 524,129 landscape.jpg 22/04/2024 01:53 143,736,602,947 The Lord of the Rings- The Return of the King (2003) - Remux-2160p Extended DV HDR10.mkv 09/02/2024 15:00 2,073,973 fanart.jpg 09/02/2024 15:00 1,186,879 poster.jpg 26/01/2024 11:30 1,545,511 The Lord of the Rings- The Return of the King (2003) - Remux-2160p Extended DV HDR10-trailer.png 22/04/2024 03:58 17,746 The Lord of the Rings- The Return of the King (2003) - Remux-2160p Extended DV HDR10.nfo 9 File(s) 143,784,058,127 bytes Maybe with a bunch of really fast SSDs.
