visproduction 335 Posted April 29, 2024 Posted April 29, 2024 Happens 100% for all Emby versions I have used, including the latest 4.9.0.16 beta Add any media at resolution 480P. Make genre and tags options (3 dots pulldown menu) to include the resolution info. The correct resolution does appear. Add a higher resolution copy 720P or 1080P into the library folder. Update / refresh all libraries. Go to genre or tags again to see the media card. The resolution does not update. Turn resolution off and on again. The resolution data in genre or tags remains 480P and never updates.
Luke 42239 Posted April 29, 2024 Posted April 29, 2024 Hi, I don't fully understand what you're saying here, but those two screenshots have no relation to each other. The 480p on the left comes from the detected resolution. The 480p on the right comes from the filename.
Happy2Play 9811 Posted April 29, 2024 Posted April 29, 2024 (edited) But selected version has nothing to do with what Emby considers primary versions metadata/nfo (first item added) that is being read/displayed. Until there is a Default version I do not see this working unless it is coded to just display the Highest Resolution always from a multi-version standpoint and not primary. Edited April 29, 2024 by Happy2Play
visproduction 335 Posted April 29, 2024 Author Posted April 29, 2024 (edited) Resolution in the genre and tags lists never updates to include the newer media. It only picks the original media copy, whatever it is and the small 480P still shows in genres and tags for many media that have higher resolution. The dbase data is write once and never update, no matter what gets loaded into the library folder. Does that make better sense? Actually same issue happens in the main libraries. Resolution info in cards are not updated ever. If 30 videos get higher resolution copies, then all 30 will still be showing the lower resolution 480P text. It is probably somehow the default. The result is this resolution info is inaccurate whenever a different res is added to the library. There appears to be no method to update this data. Edited April 29, 2024 by visproduction
Happy2Play 9811 Posted April 29, 2024 Posted April 29, 2024 One item is primary to Emby just like each item has independently written nfo files but Emby can only display one, the first item imported. So I guess as mentioned the request would be Always provide the Highest Resolution available in a multi-version environment on this display card? As this would only be for Display purposes only though.
Happy2Play 9811 Posted April 29, 2024 Posted April 29, 2024 This is really not new as versions has limits to first item imported representing all items. So in your case if you select edit metadata it will show you that the 480p item is representing all versions.
visproduction 335 Posted April 29, 2024 Author Posted April 29, 2024 (edited) Aha! Update I found a way to change the media card to read 1080P. Go into the .nfo file for the higher res 1080P and change the dateadded to a current date, which is more recent than the other 480P version. Refresh the library. Results: 1080P now shows in media card for library, genre and tags. === Does anyone else find this important enough to change to either automatically go with a higher res or let the user set this inside metadata editor? Vote if you agree. Edited April 30, 2024 by visproduction
