JuJuJurassic 50 Posted October 21, 2024 Author Posted October 21, 2024 So do I have the longest outstanding ticket/support request? I haven't been able to play Live TV since April, I've upgraded the versions since then. It worked previously, but now doesn't. If anyone can give me some advise on where to look, and what log file. Any help at all, I would be very grateful. Here's the original post Thanks
Luke 42241 Posted October 21, 2024 Posted October 21, 2024 Hi, have you updated to Emby Server 4.8.10? Has that helped?
JuJuJurassic 50 Posted October 21, 2024 Author Posted October 21, 2024 (edited) Hi, yes it's running 4.8.10 Here's the ffmpeg and the latest embyserver.txt.(and hardware detection) Thanks Julian ffmpeg-transcode-e6521797-5d0a-4177-ac3f-dedb5a63a363_1.txt embyserver (25).txt hardware_detection-63865121973.txt Edited October 21, 2024 by JuJuJurassic
JuJuJurassic 50 Posted October 21, 2024 Author Posted October 21, 2024 The TV Tuner details are; HD Homerun Tuner IP Address http://xx.xx.xx.xx Restrict to channels marked as favourite (not ticked) If enabled, only channels that are marked as favourite on the tuner device will be imported. Allow hardware transcoding (ticked) <tested both ticked and not ticked> If enabled, allow the tuner to transcode streams on the fly. This may help reduce transcoding required by Emby Server. Channels with DRM will not be imported.
Carlo 4561 Posted October 23, 2024 Posted October 23, 2024 When I look at your log, I'm seeing the transcoder getting corrupt packets from the tuner. Is the HDHomeRun and your Emby Server both connected via Ethernet? What HDHomeRun is this you have? Cable or OTA? While watching this channel, hat does your HDHomeRun show for: Signal Strength (ss) Signal Quality (snq) Symbol Quality (seq) (use brower interface, tech3 or hdhomerun_config)
sa2000 697 Posted October 23, 2024 Posted October 23, 2024 (edited) Interesting - that is the Emby Web client app on Chrome that decided to stop the playback. It read the first 3 segments from the server stream and then stopped the playback. At this time the ffmpeg transcoder was past the first 3 segments and was writing the 4th segment when its process was aborted because the web app requested to stop. Does this happen on all TV channels and all emby client apps ? On local devices? I am extracting the sequence of requests from Emby Web running on Chrome 129 2024-10-21 18:46:18.949 Info Server: http/2 GET https://emby_remote_ip:8920/emby/videos/5363945/master.m3u8 2024-10-21 18:46:18.992 Info Server: http/2 GET https://emby_remote_ip:8920/emby/videos/5363945/live.m3u8? 2024-10-21 18:46:19.525 Info Server: http/2 GET https://emby_remote_ip:8920/emby/videos/5363945/hls/F6828E/F6828E_0.ts? 2024-10-21 18:46:19.979 Info SessionManager: Playback start reported by app Emby Web 4.8.10.0 on Google Chrome Windows playing BBC ONE Yorks. Started at 0 ms. PlaySessionId: a256bdfb16634fdd8d4eb7947d1b7787 2024-10-21 18:46:20.709 Info Server: http/2 POST https://emby_remote_ip:8920/emby/Sessions/Playing/Progress? 2024-10-21 18:46:22.960 Info Server: http/2 GET https://emby_remote_ip:8920/emby/videos/5363945/live.m3u8 2024-10-21 18:46:22.969 Info Server: http/2 GET https://emby_remote_ip:8920/emby/videos/5363945/hls/F6828E/F6828E_1.ts? 2024-10-21 18:46:25.962 Info Server: http/2 GET https://emby_remote_ip:8920/emby/videos/5363945/live.m3u8? 2024-10-21 18:46:25.970 Info Server: http/2 GET https://emby_remote_ip:8920/emby/videos/5363945/hls/F6828E/F6828E_2.ts? 2024-10-21 18:46:28.951 Info Server: http/2 GET https://emby_remote_ip:8920/emby/videos/5363945/live.m3u8? 2024-10-21 18:46:29.959 Info Server: http/2 POST https://emby_remote_ip:8920/emby/Sessions/Playing/Progress? and then request from the web app to stop the stream - logged at 18:46:30.338 2024-10-21 18:46:30.338 Info Server: http/2 POST https://emby_remote_ip:8920/emby/Sessions/Playing/Stopped?X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=0ba41ef1-5a5e-41c3-83aa-0d8f847c7660&X-Emby-Client-Version=4.8.10.0&X-Emby-Token=x_secret1_x&X-Emby-Language=en-gb&reqformat=json. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.0.0 Safari/537.36 2024-10-21 18:46:30.344 Info SessionManager: Playback stopped reported by app Emby Web 4.8.10.0 on Google Chrome Windows playing BBC ONE Yorks. Stopped at 3790 ms. PlaySessionId: a256bdfb16634fdd8d4eb7947d1b7787 The ffmpeg transcoder was on the 4th segment at this time 18:46:28.792 [segment @ 0x28a4240] Opening '/var/lib/emby/transcoding-temp/F6828E/F6828E_4.ts.tmp' for writing There are corrupt packets logged by the transcoder - these were logged after the Emby Web app asked for the stream to stop 18:46:30.346 [mpegts @ 0x27ac600] PES packet size mismatch 18:46:30.346 [mpegts @ 0x27ac600] Packet corrupt (stream = 1, dts = 1172912981). 18:46:30.346 http://127.0.0.1:8096/LiveTv/LiveStreamFiles/86dfdaf69c404a2b8326dcd466f2a98a/stream.ts: corrupt input packet in stream 1 Last message repeated 1 times [segment @ 0x28a4240] Opening '/var/lib/emby/transcoding-temp/F6828E/F6828E.m3u8.tmp' for writing SegmentComplete=video:0 Index=4 Start=12.960000 End=15.600000 Duration=2.640000 offset_pts=0 start_pts=12960000 Frames=66 filename=hls/F6828E/F6828E_4.ts elapsed=00:00:11.14 frame= 366 fps= 33 q=11.0 Lsize=N/A time=00:00:14.86 bitrate=N/A dup=2 drop=0 throttle=off speed=1.33x video:7708kB audio:351kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown Would be useful to see what happens with emby apps streaming Live TV and also for different channels - to see if all the client apps abort in the same way (from the logs) Edited October 23, 2024 by sa2000
JuJuJurassic 50 Posted October 23, 2024 Author Posted October 23, 2024 Hi Carlo, Thank you for helping me. While playing HD home run via the app on my Win 10 laptop, the stats from the device are; I've hidden the IP Address. It's a freeview, OTA tuner Tuner 0 Status Virtual Channel 4 Channel 4 Frequency 658.000 MHz Program Number 8384 Modulation Lock t8dvbt Signal Strength 100% Signal Quality 100% Symbol Quality 100% Streaming Rate 2.179 Mbps Resource Lock xx.xx.xx.xx The HD home run and Emby server are connected over a wired ethernet connection. Thanks
JuJuJurassic 50 Posted October 23, 2024 Author Posted October 23, 2024 Hi sa2000, Ive tried it from other clients within the lan of the house. I had it wired when it was built, it seems it's just chrome that's got the problem. it works ok from firefox and the firesticks on the TV. all channels are affected, but only with chrome.
sa2000 697 Posted October 24, 2024 Posted October 24, 2024 (edited) 19 hours ago, JuJuJurassic said: it seems it's just chrome that's got the problem. it works ok from firefox and the firesticks on the TV.. all channels are affected, but only with chrome. Well that is progress - so you can now stream Live TV if you avoid using Google Chrome for it. You could try Google Chrome on the local network and see if there any clues if you run it with the browser dev console enabled (F12) and browser network logging - to see if any clues as to why the Web Client app is stopping playback after reading 3 segments I am going to attach the streams extra data from the ffmpeg log in case it is needed in any further investigation. The stream is an HLS mpeg2video stream extradata_from_ffmpeg-transcode-e6521797-5d0a-4177-ac3f-dedb5a63a363_1.txt Edited October 24, 2024 by sa2000
JuJuJurassic 50 Posted October 28, 2024 Author Posted October 28, 2024 Let's close the case. It's a chrome issue, not Emby. Thank you for your help
sa2000 697 Posted October 28, 2024 Posted October 28, 2024 2 hours ago, JuJuJurassic said: Let's close the case. It's a chrome issue, not Emby I will discuss with the development team to understand more about this hls stream issue
leetxjd 5 Posted December 12, 2024 Posted December 12, 2024 It isn't an issue with ONLY chrome. I use firefox and appletv get this same behavior. I'm going to gather some log files...
leetxjd 5 Posted December 12, 2024 Posted December 12, 2024 Here are the ffmpeg logs. I tried with hardware acceleration/transcoding and without it. Same behavior - 4 seconds of video, it kicks out, then the "throbber" appears and 4 additional seconds of video plays. ffmpeg-transcode-9fdd5b82-a471-441f-bf86-3a62e5549477_1.txt ffmpeg-transcode-2b90df72-8b0e-40d8-8930-feec0f03dfb7_1.txt
sa2000 697 Posted December 13, 2024 Posted December 13, 2024 13 hours ago, leetxjd said: Here are the ffmpeg logs. can you please provide the corresponding emby server logs
sa2000 697 Posted December 13, 2024 Posted December 13, 2024 13 hours ago, leetxjd said: I tried with hardware acceleration/transcoding and without it. Same behavior - Thanks for trying both Were subtitles in use? Could you repeat the two tests without subtitles and get me logs for these tests as well - server + ffmpeg Thanks
sa2000 697 Posted December 13, 2024 Posted December 13, 2024 14 hours ago, leetxjd said: It isn't an issue with ONLY chrome There may be different issues.
Carlo 4561 Posted December 14, 2024 Posted December 14, 2024 On 10/28/2024 at 3:03 PM, JuJuJurassic said: Let's close the case. It's a chrome issue, not Emby. Thank you for your help I know this is old but wondering if you ever got Chrome to work? Did you try Chrome on multiple computers or just one? Did you try it in MS Edge? Edge and Chrome use the same core. Have you checked to see if you have the latest firmware on your HDHR? Did you ever try this in an Incognito/InPrivate window? This is often helpful as it won't have all the plugins or other features loaded. I noticed in your ffmpeg logs (ones I saw anyway) the resolution was 704x576 or SD. Have you tried HD channels as well? Did you ever check to see if you were running the latest version of Chrome? It would be interesting to know how this works in Vivaldi as well, as that could shed some light on the possible source of the issue. Edge, Chome, Vivaldi are all Chromium based browsers. Carlo
Carlo 4561 Posted December 14, 2024 Posted December 14, 2024 On 12/12/2024 at 4:23 PM, leetxjd said: It isn't an issue with ONLY chrome. I use firefox and appletv get this same behavior. I'm going to gather some log files... It could be related but probably not the same issue. @JuJuJurassicis using an HDHomeRun setup directly in Emby while it appears you're using Media Portal as the source. What's your source setup in Media Portal? Carlo
JuJuJurassic 50 Posted December 23, 2024 Author Posted December 23, 2024 Hi Carlo, Sorry for not getting back to you quicker. Quicker. To be honest when I got it working perfectly with Firefox, I gave up with Chrome. I haven’t investigated it since. however, I am using HDHomeRun it works perfectly from the Home run apps, it’s just envy that had the problem with Chrome. Everything is updated to the Nuz version of course. Everything is updated to the Nuz version of course.
sa2000 697 Posted December 23, 2024 Posted December 23, 2024 I have the issue with chrome and edge - ok with Firefox but if I disable hardware transcoding chrome and edge work ok I am gathering diagnostics for this 1
sa2000 697 Posted December 24, 2024 Posted December 24, 2024 13 hours ago, sa2000 said: I have the issue with chrome and edge - ok with Firefox but if I disable hardware transcoding chrome and edge work ok I am gathering diagnostics for this In my case it appears to be limited to Nvidia GPU hardware transcoding and Edge and Chrome. The issue does not arise for me when Intel QuickSync is used for hardware transcoding There may be different causes for this 1
