cmoore1990 0 Posted April 27, 2024 Posted April 27, 2024 Can you please let me know how I can use Emby on my Mac. I have OS 13.3 (22E252) (MacBook Air 2018).
Luke 42237 Posted April 30, 2024 Posted April 30, 2024 Hi, are you looking to run Emby Server on your mac, or an Emby client app so that you can connect to an existing Emby Server?
cmoore1990 0 Posted May 12, 2024 Author Posted May 12, 2024 Hi Luke, Thanks for the reply. I'm not 100% what this means but I think I'm just trying to run a client app.
Luke 42237 Posted May 16, 2024 Posted May 16, 2024 On 5/12/2024 at 12:06 PM, cmoore1990 said: Hi Luke, Thanks for the reply. I'm not 100% what this means but I think I'm just trying to run a client app. @cmoore1990so this means you're going to connect to someone else's Emby Server? If this is the case then you can install the Emby app from the macOS app store.
