RunDMC 0 Posted April 26, 2024 Posted April 26, 2024 Hi there, I'm trying to enable HTTPS on Emby 4.8.5.0 on Synology DSM 7.2.1. I've set the network configuration on Emby to require a secure connect for remote clients. I've successfully added the SSL certificate. I have successfully tested the certificate with certutil. I've checked that the firewall is forwarding the correct ports and confirmed that they show as open. But when I try to open a remote connection with HTTPS I get this error: xxx.xxx.xxx didn't send any data ERR_EMPTY_RESPONSE I don't see any related errors in the Emby logs. Any help would be greatly appreciated. Dec
RunDMC 0 Posted April 26, 2024 Author Posted April 26, 2024 2 minutes ago, RunDMC said: Just to add, when I connect locally to the HTTPS port, it seems to work fine. Obviously the cert doesn't match the address, but it does send data. Dec
Luke 42241 Posted April 26, 2024 Posted April 26, 2024 Hi, are you sure you’re testing with the correct address? Where did you get it from?
