imortal088 0 Posted April 26, 2024 Posted April 26, 2024 Hello, is there a way to set an Pre-Buffer for streaming? like Amazon,... My problem is: some of my clients have micro stutter BR
visproduction 328 Posted April 28, 2024 Posted April 28, 2024 Realted with easy to follow steps to check for video streaming delivery issues. Many of these tests could possibly also help an Emby video stream. https://techcult.com/fix-amazon-prime-video-buffering-issue/
Happy2Play 9799 Posted April 28, 2024 Posted April 28, 2024 On 4/26/2024 at 1:02 AM, imortal088 said: My problem is: some of my clients have micro stutter Which clients?
imortal088 0 Posted April 29, 2024 Author Posted April 29, 2024 hello, i think i have found the issue, it was the transcoding settings, now i reset all settings to default and now it looks good. BR
ebr 16307 Posted April 29, 2024 Posted April 29, 2024 3 hours ago, imortal088 said: now i reset all settings to default Hi. Just a general note to all - this is an excellent place to start when you are having issues . Glad you got your issue fixed. 1
