RafaG 17 Posted April 17, 2024 Posted April 17, 2024 (edited) Hi, I have a 4K Av1 file that I can't watch. I received an error "there is not compatible transmisions availables" (or something similar). I don' have any problem with VLC or Jellyfin. Regards, ffmpeg-transcode-57d8c82e-1a37-4b48-919c-8ffbb7f2509d_1.txt embyserver.txt Edited April 17, 2024 by RafaG
visproduction 328 Posted April 17, 2024 Posted April 17, 2024 Rafa, A m3u8 file is a playlist with links in the file to pull the video from somewhere else online. VLC will play it by going out to the source and pulling the video down if it is available. Often these playlist files timeout when the host site decides to update them to point to different files. Emby is not playing it, I believe, because you didn't actually download the file. Hope that helps.
RafaG 17 Posted April 17, 2024 Author Posted April 17, 2024 Hi, My file is local to emby server. I use another computer in the same network (local) to watch this file through Emby Web client. I can use VLC over my local network to play the file without problems. Thanks anyway
visproduction 328 Posted April 18, 2024 Posted April 18, 2024 My guess is that VLC handles m3u8 playlist files and goes to the correct local media file. Emby is probably not doing that. Open the m3u8 file to see the issue better. It is usually just a list of other media file names that tells the software, go here and play it. See: https://www.lifewire.com/m3u8-file-2621956 If you put the actual media .mkv file inside a designated library that Emby sees, then it should show up as an available media file. Be sure to use the exact title with the year that imbd.com uses, with any extra - 720P like this. Double Indemnity (1944) - 720P.mkv Hope that helps.
Lessaj 477 Posted April 18, 2024 Posted April 18, 2024 I see a couple errors related to deleting a folder from transcoding-temp but I'm not sure if these errors really mean anything. Can you try clearing any folders in your transcoding-temp folder? Assuming no one has an active transcoding stream going it's safe to remove anything in that folder. Also, if you try to play without subtitles does it work? That's the reason for the transcode. 2024-04-17 09:08:35.221 Error EncodingManager: Unable to delete temp folder C:\emby.windows\transcoding-temp\DC5D96 due to Access to the path '\\?\C:\emby.windows\transcoding-temp\DC5D96' is denied., will try again. 2024-04-17 09:08:45.365 Error EncodingManager: Unable to delete temp folder C:\emby.windows\transcoding-temp\FA549F due to Access to the path '\\?\C:\emby.windows\transcoding-temp\FA549F\FA549F_Fonts' is denied., will try again. TranscodeReasons=SubtitleCodecNotSupported TranscodeReasons=SubtitleCodecNotSupported,DirectPlayError
RafaG 17 Posted April 19, 2024 Author Posted April 19, 2024 15 hours ago, visproduction said: My guess is that VLC handles m3u8 playlist files and goes to the correct local media file. Emby is probably not doing that. Open the m3u8 file to see the issue better. It is usually just a list of other media file names that tells the software, go here and play it. See: https://www.lifewire.com/m3u8-file-2621956 If you put the actual media .mkv file inside a designated library that Emby sees, then it should show up as an available media file. Be sure to use the exact title with the year that imbd.com uses, with any extra - 720P like this. Double Indemnity (1944) - 720P.mkv Hope that helps. Hi, I don't use any m3u8 file, this is something that Emby done by itself. I don't known why Emby server made a m3u8 file internaly, but there are not m3u8 file in my disk. My installation is easy, one Av1, 4k, MKV file in my Emby server and from an Emby server web client it's not played.
RafaG 17 Posted April 19, 2024 Author Posted April 19, 2024 14 hours ago, Lessaj said: I see a couple errors related to deleting a folder from transcoding-temp but I'm not sure if these errors really mean anything. Can you try clearing any folders in your transcoding-temp folder? Assuming no one has an active transcoding stream going it's safe to remove anything in that folder. Also, if you try to play without subtitles does it work? That's the reason for the transcode. 2024-04-17 09:08:35.221 Error EncodingManager: Unable to delete temp folder C:\emby.windows\transcoding-temp\DC5D96 due to Access to the path '\\?\C:\emby.windows\transcoding-temp\DC5D96' is denied., will try again. 2024-04-17 09:08:45.365 Error EncodingManager: Unable to delete temp folder C:\emby.windows\transcoding-temp\FA549F due to Access to the path '\\?\C:\emby.windows\transcoding-temp\FA549F\FA549F_Fonts' is denied., will try again. TranscodeReasons=SubtitleCodecNotSupported TranscodeReasons=SubtitleCodecNotSupported,DirectPlayError I try another approach, I stop Emby server, delete all temp files, I try again. Same result. But, if I play without subtitules, work perfect. New logs embyserver.txt ffmpeg-transcode-89754351-2d74-4428-bacc-1f765a1c013b_1.txt ffmpeg-transcode-eb6c8a9a-6283-415e-ac88-bb51f4ab72d9_1.txt
visproduction 328 Posted April 19, 2024 Posted April 19, 2024 (edited) 9 hours ago, RafaG said: Hi, I don't use any m3u8 file, this is something that Emby done by itself. I don't known why Emby server made a m3u8 file internaly, but there are not m3u8 file in my disk. My installation is easy, one Av1, 4k, MKV file in my Emby server and from an Emby server web client it's not played. Aha. Interesting. I did not know that. Maybe the m3u8 reference in your log file is a result of the encoding to the temporary cache directory. It would be nice to have that directory set to a separate, newer hard drive that is reasonable fast and make sure there is enough room. A completely different drive for the transcoding directory, separate from any library, would make the transcoding interfere less with pulling library media. Does someone know how Emby uses m3u8 files? I never run transcoding at all and so I never run into this. Edited April 19, 2024 by visproduction
Lessaj 477 Posted April 19, 2024 Posted April 19, 2024 Okay I didn't think the error about deleting the temp folder really meant anything. Looks like this is a problem with transcoding the ASS subs, but it might be doing something that you can only see with some debug options enabled. If you have the Diagnostics Plugin installed try setting the trasncoding log level to debug information, hit save, reproduce the issue and provide the logs. Otherwise my recommendation is to get some SRT subs for this and you should be able to watch it just fine, those don't need to be burned in to the video. 12 minutes ago, visproduction said: Aha. Interesting. I did not know that. Maybe the m3u8 reference in your log file is a result of the encoding to the temporary cache directory. It would be nice to have that directory set to a separate, newer hard drive that is reasonable fast and make sure there is enough room. A completely different drive for the transcoding directory, separate from any library, would make the transcoding interfere less with pulling library media. Does someone know how Emby uses m3u8 files? I never run transcoding at all and so I never run into this. That's how it works when transcoding, it creates a "playlist" of TS files and it reads from the playlist, requesting TS segments when needed. 1
RafaG 17 Posted April 20, 2024 Author Posted April 20, 2024 (edited) Hi, same process, shutdown server, debug options, play file, new logs embyserver.txt ffmpeg-transcode-1f793dd4-4be7-4213-9446-3c4d88312884_1.txt ffmpeg-transcode-4e843fda-7f7e-4077-bb77-ef1bb5cf96e2_1.txt ffmpeg-transcode-a4f4ff5e-7572-46f0-913c-215385d8af04_1.txt (thanks both of you for your support, I hope someone from emby team could see my logs) Edited April 20, 2024 by RafaG
Lessaj 477 Posted April 21, 2024 Posted April 21, 2024 With the debugging enabled I can see that it's reading through the ASS subs but not particularly quickly though I'm not sure why. Again I'd recommend getting an SRT for this instead.
RafaG 17 Posted April 21, 2024 Author Posted April 21, 2024 (edited) I have the same file in 1080p h265 with same ASS subs, work perfect. The problem only exist with Av1 codec and ASS subs. Edited April 21, 2024 by RafaG
RafaG 17 Posted April 23, 2024 Author Posted April 23, 2024 Sorry to mention, but I don't know what to do. @Luke could you give some advice?
RafaG 17 Posted April 25, 2024 Author Posted April 25, 2024 Hi, I have two files from same video, one is HEVC + ASS, other is AV1 with same ASS subtitles. Windows Emby Server 4.8.5.0, web windows client. If I play HEVC file with or without subtitles everithing works fine. If I play AV1 witout subtitles, works, but with subtitules, don't work, I receive a message "there is not compatible transmisions availables". I attach logs and mediainfo from files. Regards, ffmpeg-transcode-a4f4ff5e-7572-46f0-913c-215385d8af04_1.txt ffmpeg-transcode-1f793dd4-4be7-4213-9446-3c4d88312884_1.txt ffmpeg-transcode-4e843fda-7f7e-4077-bb77-ef1bb5cf96e2_1.txt embyserver.txt AV1.txt HEVC.txt
Luke 42184 Posted April 25, 2024 Posted April 25, 2024 Hi, is there something non-standard about this file? First we tried to direct play, but the browser video player raised an error because there was something about the file that it didn't like. So then we tried to switch to transcoding to be able to play, and it seems there was also a problem with that. Another thing to try is disabling hardware transcoding and see if that helps.
RafaG 17 Posted April 25, 2024 Author Posted April 25, 2024 I don't think so. I make both files with Handbrake. If I use VLC I don't have any problem, If I use Jellyfin server and web client, I don't have any problem. If I disable hardware transcoding I have the same problem, same error. If you need the file, I could send you
Luke 42184 Posted April 26, 2024 Posted April 26, 2024 Is this the same discussion that we're having here?
RafaG 17 Posted April 26, 2024 Author Posted April 26, 2024 (edited) Yes, but the subject is not correct. When I wrote this post I don't know that the problem is related with ASS subtitules Edited April 26, 2024 by RafaG
RafaG 17 Posted April 28, 2024 Author Posted April 28, 2024 Hi, Someone from emby' team could help me? If I can play the file with other systems I think the problem is in emby. I think is related by how subtitules are handle by emby, but I can't do anymore. If anyone want the file, I can send it without problems to checkit.
RafaG 17 Posted May 1, 2024 Author Posted May 1, 2024 (edited) Hi, Someone from emby' team could help me? Edited May 1, 2024 by RafaG
RafaG 17 Posted May 10, 2024 Author Posted May 10, 2024 Hi! I really don't understand why I didn't received any information from Emby's team about this problem. @Luke@ebr @softworkz @Abobader @CBers My info again: I have two files from same video, one is HEVC + ASS, other is AV1 with same ASS subtitles. Windows Emby Server 4.8.5.0, web windows client. If I play HEVC file with or without subtitles everithing works fine. If I play AV1 without subtitles, works, but with subtitules, don't work, I receive a message "there is not compatible transmisions availables". I attach logs and mediainfo from files. I make both files with Handbrake. If I use VLC I don't have any problem, If I use Jellyfin server and web client, I don't have any problem. If I disable hardware transcoding I have the same problem, same error. If you need the file, I could send you. Regards, AV1.txt HEVC.txt embyserver.txt ffmpeg-transcode-1f793dd4-4be7-4213-9446-3c4d88312884_1.txt ffmpeg-transcode-4e843fda-7f7e-4077-bb77-ef1bb5cf96e2_1.txt ffmpeg-transcode-a4f4ff5e-7572-46f0-913c-215385d8af04_1 (1).txt
speechles 2060 Posted May 10, 2024 Posted May 10, 2024 (edited) TranscodeReasons=SubtitleCodecNotSupported,DirectPlayError The client cannot understand what to do when it has nothing given to it. There is both a direct play error meaning it must burn them in. Then a subtitle codec not supported error. It is basically transcoding into NULL based on your log. Quote 08:51:12.764 [NULL @ 0000027b55dfe880] Frame 16: size 3840x1606 upscaled 3840 render 3840x1606 subsample 2x2 bitdepth 10 tiles 1x1. 08:51:12.764 [NULL @ 0000027b55dfe880] Frame 8: size 3840x1606 upscaled 3840 render 3840x1606 subsample 2x2 bitdepth 10 tiles 1x1. 08:51:12.764 [NULL @ 0000027b55dfe880] Frame 4: size 3840x1606 upscaled 3840 render 3840x1606 subsample 2x2 bitdepth 10 tiles 1x1. 08:51:12.764 [NULL @ 0000027b55dfe880] Frame 2: size 3840x1606 upscaled 3840 render 3840x1606 subsample 2x2 bitdepth 10 tiles 1x1. There is nothing for it to do. You need textual subtitles that can be overlaid onto the AV1 so it can play directly. Transcoding AV1 is very complicated to do at a watchable framerate especially combined with sizing subtitles to overlay onto those video frames. You can download external SRT to go with that file with Emby subtitle search. The timings may match up if you pick the right version of SRT. Edited May 10, 2024 by speechles
RafaG 17 Posted May 10, 2024 Author Posted May 10, 2024 (edited) Hi, Thanks for your answer. I try to play this file with emby web client and FireTv app, don't work. I don't understand, why can I play it with VLC with ASS subtitles without problems? or with jellyfin , or even with ffplay: Are you tell me that Emby don't support transcoding Av1 files? That is the problem? Edited May 10, 2024 by RafaG
RanmaCanada 500 Posted May 13, 2024 Posted May 13, 2024 I thought we already discussed this and it is the fact that what you are trying to do is not supported in the standard. I love it when people continue to think they know more than the people helping them.. Can we just close this discussion as OP has deleted their previous thread where we already answered this?
