rbjtech 5345 Posted May 1, 2024 Posted May 1, 2024 (edited) 26 minutes ago, Nikomajor said: Update: Manually inputting the IP address in the Emby app seems to have fixed everything and now there's a buffering issue which may be due to my mobile network. Yes, DDNS is never going to work if you have CGNAT - DNS will just point to the incorrect WAN IP .. 26 minutes ago, Nikomajor said: or pulling the trigger on a public static IP. This will be the best solution - as your ISP will move you off CGNAT onto an addressable real public IP. DDNS will then also work or you can of course use a real DNS A-Record also (as the IP never changes). Edited May 1, 2024 by rbjtech
