Luke 42287 Posted May 26, 2024 Posted May 26, 2024 7 minutes ago, jiggity said: If you’re saying you should see entire series instead of the seasons or episodes, then no that delineation is not meaningless if you’re trying to create specific collections of individual episodes. So I would say if the series is what you want in the collection then just add that.
jiggity 35 Posted May 26, 2024 Author Posted May 26, 2024 (edited) 4 minutes ago, Luke said: f you’re saying you should see entire series instead of the seasons or episodes, then no that delineation is not meaningless if you’re trying to create specific collections of individual episodes. So I would say if the series is what you want in the collection then just add that. Missing the point completely. Some collections are made up of a mixture of Movies and shows, some of Seasons and episodes, some of a mixture of movies and episodes. Prior to this whole stupid horizontal sliding restructure, all items form TV, regardless of how they were added simply showed under shows. This new decision is no longer "Media Your Way" it is now do it they way we decided you should do it and we will not explain why we changed it, so just do it!! Edited May 26, 2024 by jiggity speeling
crusher11 1153 Posted May 26, 2024 Posted May 26, 2024 1 hour ago, Luke said: Depends on the library setup that they belong to. They're in a movies library, but why does the library setup matter? They're movies. Why are you continuing to ignore the fact that it's impossible to horizontally scroll large collections?
Smitty018210 147 Posted May 26, 2024 Posted May 26, 2024 (edited) 10 minutes ago, crusher11 said: Why are you continuing to ignore the fact that it's impossible to horizontally scroll large collections? There seems to be no point to arguing with them on this point. This dev team for what ever reason dose not seem to understand that not everyone whats to endlessly horizontal/side scroll through their media. If I could disable all horizontal/side scrolling and have a vertical option instead I would be so happy. I hate horizontal/side scrolling. Edited May 26, 2024 by Smitty018210
Luke 42287 Posted May 26, 2024 Posted May 26, 2024 46 minutes ago, Smitty018210 said: There seems to be no point to arguing with them on this point. This dev team for what ever reason dose not seem to understand that not everyone whats to endlessly horizontal/side scroll through their media. If I could disable all horizontal/side scrolling and have a vertical option instead I would be so happy. I hate horizontal/side scrolling. In Theater have you tried the new Group By button? It is right next to the sort button and will allow you to go back to the combined vertical list. All Emby apps will be getting that.
Luke 42287 Posted May 26, 2024 Posted May 26, 2024 57 minutes ago, crusher11 said: They're in a movies library, but why does the library setup matter? They're movies. It matters because if it was in a home videos library then it would say Videos. If it's listed in the Videos section then it's in your server database as a plain video rather than a movie. We'd have to look at the specifics of that example to get to the bottom of why, which would start with the setup of that library, plus all others, file naming, folder organization, etc.
Smitty018210 147 Posted May 26, 2024 Posted May 26, 2024 (edited) 19 minutes ago, Luke said: In Theater have you tried the new Group By button? It is right next to the sort button and will allow you to go back to the combined vertical list. All Emby apps will be getting that. ------------------------> I DO NOT USE DESKTOP OR ANDROID VIEW OPTION <------------------------------------- Where is that option in TV mode? I don't not want ANY forced Horizontal/ side scrolling. There should ALWAYS be an option for vertical viewing. Why can you not provide an option and let us users decided what work best for us? Why dose have to be only one way? Your way? Just give us more options to customize the UI! PLEASE! Edited May 26, 2024 by Smitty018210
crusher11 1153 Posted May 26, 2024 Posted May 26, 2024 1 hour ago, Luke said: It matters because if it was in a home videos library then it would say Videos. If it's listed in the Videos section then it's in your server database as a plain video rather than a movie. We'd have to look at the specifics of that example to get to the bottom of why, which would start with the setup of that library, plus all others, file naming, folder organization, etc. It's a movie library. The "Videos" entries are extras in other movies (for example, A.K. is included on the StudioCanal release of Ran), and are simply a .strm pointing at the movie's MKV, with the movie's NFO file copied over to retain all the metadata.
Luke 42287 Posted May 26, 2024 Posted May 26, 2024 16 hours ago, crusher11 said: It's a movie library. The "Videos" entries are extras in other movies (for example, A.K. is included on the StudioCanal release of Ran), and are simply a .strm pointing at the movie's MKV, with the movie's NFO file copied over to retain all the metadata. OK yes that explains it then.
crusher11 1153 Posted May 27, 2024 Posted May 27, 2024 On 5/26/2024 at 11:34 AM, crusher11 said: Why are you continuing to ignore the fact that it's impossible to horizontally scroll large collections?
ebr 16354 Posted May 27, 2024 Posted May 27, 2024 6 hours ago, crusher11 said: Why are you continuing to ignore the fact that it's impossible to horizontally scroll large collections? He's not. See the new option currently being implemented.
CrappyUserName 30 Posted December 15, 2024 Posted December 15, 2024 Did this "new option" ever get implemented? I suppose it's probably going to be easier for me to just split TV shows out of the collection into a separate one so it doesn't auto side scroll. It just adds to the user experience having to do stupid workarounds to get old functionality.....
Luke 42287 Posted December 15, 2024 Posted December 15, 2024 1 hour ago, CrappyUserName said: Did this "new option" ever get implemented? I suppose it's probably going to be easier for me to just split TV shows out of the collection into a separate one so it doesn't auto side scroll. It just adds to the user experience having to do stupid workarounds to get old functionality..... Currently it should only side scroll if there are multiple categories.
CrappyUserName 30 Posted December 16, 2024 Posted December 16, 2024 6 hours ago, Luke said: Currently it should only side scroll if there are multiple categories. I take that as a no for the new option. I have a collection that has Movies and TV shows in it. So as I said, I need to put the TV shows in a separate collection. Not sure on the decision making process with this one. Option 1 - Force users to side scroll with multiple categories in a collection. Option 2 - Have an option so users can choose between the old method or the new side scrolling method. I understand not wanting to have an overwhelming list of options for users but for something like this I would have thought option 2 would have been the better choice. Literally no one wants to side scroll with a large collection. Even having category tabs at the top would have been a better way to go. Like the home page has with "home" and "favorites". Anyway, now I know what I will be doing this afternoon....
rexerm 36 Posted December 16, 2024 Posted December 16, 2024 14 minutes ago, CrappyUserName said: I take that as a no for the new option. This was essentially fixed a few versions ago. There's now a "Group By" button in each collection (the icon looks like two stacked calculators, right next to the heart icon). You can set this to "None" and it will display all collections in the old, vertical, mixed-media-type way. You only need to change this for one for it to change for all collections, but each user would need to do this themselves, as Group By "Media Type" is still default (aka, the horizontal scrolling way).
CrappyUserName 30 Posted December 16, 2024 Posted December 16, 2024 2 hours ago, rexerm said: There's now a "Group By" button in each collection (the icon looks like two stacked calculators, right next to the heart icon). You can set this to "None" and it will display all collections in the old, vertical, mixed-media-type way. This just merges them all together. The "old" way kept the different categories separate but vertically scrolled.
Luke 42287 Posted December 16, 2024 Posted December 16, 2024 Actually the old behavior was that they were all combined into a single section that scrolled vertically.
CrappyUserName 30 Posted December 16, 2024 Posted December 16, 2024 Your gaslighting almost got me. But then I found this image showing how collections used to work. https://emby.media/community/uploads/monthly_07_2019/post-430583-0-98432900-1562252287.png in this post. https://emby.media/community/index.php?/topic/36916-smart-playlists/page/2/#findComment-760057 Granted that was 5 years ago so maybe it changed to merged before it changed to sidescrolling but I can't say I ever noticed that.
rexerm 36 Posted December 16, 2024 Posted December 16, 2024 13 minutes ago, CrappyUserName said: Your gaslighting almost got me. But then I found this image showing how collections used to work. https://emby.media/community/uploads/monthly_07_2019/post-430583-0-98432900-1562252287.png in this post. https://emby.media/community/index.php?/topic/36916-smart-playlists/page/2/#findComment-760057 Granted that was 5 years ago so maybe it changed to merged before it changed to sidescrolling but I can't say I ever noticed that. That looks to be a screenshot of the Android client. The Windows client / browsers have always had vertical mixed types (well, except for a few months when that option was nuked). It seems like the Android client might've been recently updated to match Windows. I see it now has a "Group By" button, where it did not last I checked.
CrappyUserName 30 Posted December 17, 2024 Posted December 17, 2024 2 hours ago, rexerm said: That looks to be a screenshot of the Android client. The Windows client / browsers have always had vertical mixed types (well, except for a few months when that option was nuked). It seems like the Android client might've been recently updated to match Windows. I see it now has a "Group By" button, where it did not last I checked. I just googled the issue and this is the thread that came up. I'm using the LG TV client and occasionally firefox in windows. I guess I'm in the wrong section, I wouldn't have expected something like this to be different across clients.
rexerm 36 Posted December 17, 2024 Posted December 17, 2024 13 minutes ago, CrappyUserName said: I wouldn't have expected something like this to be different across clients. Yeah, you're definitely not alone there...
embyuniverse 0 Posted January 31, 2025 Posted January 31, 2025 Does this custom css accomplish your goal? div.homeSectionsContainer div.section0 div.scrollSlider { flex-wrap: wrap; }
CrappyUserName 30 Posted February 1, 2025 Posted February 1, 2025 I can't use that in the LG client app. I solved the issue by separating my collections that contained a mix of TV and Film. eg) I now have Star Wars and Star Wars TV. Same for Marvel, Star Trek etc... I think I prefer it this way anyway instead of lumping them all into one collection. 1
