Luke 42244 Posted May 13, 2024 Posted May 13, 2024 Hi, this should be resolved for the next release. Thanks. 1
chouyee 5 Posted May 15, 2024 Posted May 15, 2024 On 5/13/2024 at 11:48 PM, Luke said: Hi, this should be resolved for the next release. Thanks. The next version? Official version or beta version? Can you tell us the specific version number?
Luke 42244 Posted May 15, 2024 Posted May 15, 2024 1 hour ago, chouyee said: The next version? Official version or beta version? Can you tell us the specific version number? It's in the beta channel now.
QAQrz 6 Posted May 15, 2024 Posted May 15, 2024 (edited) 47 minutes ago, Luke said: It's in the beta channel now. beta 4.9.0.19 works, thanks Edited May 15, 2024 by QAQrz 1
valentine83 2 Posted May 15, 2024 Posted May 15, 2024 10 hours ago, Luke said: Jest już w kanale beta. Thank you all, it works!
Luke 42244 Posted May 15, 2024 Posted May 15, 2024 The fix will also be included in the Emby Server 4.8.7 maintenance release. Thanks.
chouyee 5 Posted May 17, 2024 Posted May 17, 2024 On 5/16/2024 at 6:04 AM, Luke said: The fix will also be included in the Emby Server 4.8.7 maintenance release. Thanks. Thank you. I'll try.
