Luke 42243 Posted March 19, 2025 Posted March 19, 2025 Hi, can you please try this build and see how things compare? Thanks !
wjcarpenter 9 Posted March 19, 2025 Author Posted March 19, 2025 That's great news of a potential fix. It will take me a little while to be able to test that build, so I hope one of the other folks experiencing the same problem can get to it before me.
wjcarpenter 9 Posted April 10, 2025 Author Posted April 10, 2025 Alas, no joy. With the latest Android app, both on my phone and on my Android TV, no change in symptoms except: External players now work in both environments. Captions show up in those external players. I used VLC on my phone and Kodi on Android TV. Most recordings from TVE did not show captions in either Android app. However, one recording I made did display captions on the Android TV app but not on the phone app.I tried to replicate that behavior by making a second recording on the same TVE channel (Sundance TV on Philo), but it wouldn't show the captions on either Android app.
Luke 42243 Posted April 10, 2025 Posted April 10, 2025 22 minutes ago, wjcarpenter said: Alas, no joy. With the latest Android app, both on my phone and on my Android TV, no change in symptoms except: External players now work in both environments. Captions show up in those external players. I used VLC on my phone and Kodi on Android TV. Most recordings from TVE did not show captions in either Android app. However, one recording I made did display captions on the Android TV app but not on the phone app.I tried to replicate that behavior by making a second recording on the same TVE channel (Sundance TV on Philo), but it wouldn't show the captions on either Android app. Hi, what version number did you try?
wjcarpenter 9 Posted April 10, 2025 Author Posted April 10, 2025 9 minutes ago, Luke said: what version number did you try Phone: 3.4.36 TV: 2.1.23g (installed just today, so it must be the latest even though it's dated December 2024)
Luke 42243 Posted April 18, 2025 Posted April 18, 2025 Quote Phone: 3.4.36 OK this should be resolved once you have a version number higher than that. We're working on getting an update out to the store. Thanks.
wjcarpenter 9 Posted April 19, 2025 Author Posted April 19, 2025 My phone is now at 3.4.56 and the closed captions play correctly. Yay! My Android TV does not yet set an available update, so I'm still on 2.1.23g. 1
wjcarpenter 9 Posted May 14, 2025 Author Posted May 14, 2025 On 4/19/2025 at 11:09 AM, wjcarpenter said: My Android TV does not yet set an available update, so I'm still on 2.1.23g. Is an update with this fix in the works for the Android TV app?
Solution Luke 42243 Posted May 15, 2025 Solution Posted May 15, 2025 3 hours ago, wjcarpenter said: Is an update with this fix in the works for the Android TV app? Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks.
ebr 16336 Posted May 15, 2025 Posted May 15, 2025 15 hours ago, wjcarpenter said: Is an update with this fix in the works for the Android TV app? Hi. Not at this time. The standard app should display them properly.
wjcarpenter 9 Posted May 15, 2025 Author Posted May 15, 2025 Oh, wow. I didn't even realize that the standard Android app could be used on Android TV. It works and solves the problem. I've only poked around a little bit, but I assume the main difference is in UI presentation, and I'm not losing any interesting features. 1
