David Patt 21 Posted April 19, 2024 Posted April 19, 2024 I think this is fault at my tv (Sony Bravia Xf9005) but some Dolby vision files play great but some playing black and white only for no reason. I try few external players and some work with colors but i guess it transcode or something because no dolby vision logo show up. Anyone with similar troubles ?
Luke 42140 Posted April 29, 2024 Posted April 29, 2024 @David Patt Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
David Patt 21 Posted April 29, 2024 Author Posted April 29, 2024 Just hit play on movie and play wuth sound and subtitle but image is in black and white. embyserver.txt
Happy2Play 9797 Posted April 29, 2024 Posted April 29, 2024 On 4/19/2024 at 10:47 AM, David Patt said: but some Dolby vision files play great but some playing black and white only for no reason. Are they all the same profile as that appears to be the issue across the board on DV and its supported profiles.
David Patt 21 Posted April 29, 2024 Author Posted April 29, 2024 Dv profile 8 play ok Dv profile 7.6 like in screen show only black and white. Also i presume its my tv fault to not recognize this profile.
Happy2Play 9797 Posted April 29, 2024 Posted April 29, 2024 Don't know anything about it but other topics suggest TVs will only support certain profiles. But some one that knows more device specifics will have to comment.
Luke 42140 Posted April 30, 2024 Posted April 30, 2024 Hi, what Emby app are you playing from? What TV?
David Patt 21 Posted April 30, 2024 Author Posted April 30, 2024 1 hour ago, Luke said: Hi, what Emby app are you playing from? What TV? Android tv 2.1.11 Sony Bravia 55XF9005 ( sony x900f in other regions)
RanmaCanada 500 Posted May 2, 2024 Posted May 2, 2024 DV profile 7.6 is a dual layer profile that typically can only be played on UHD players. dvhe.07.06 This string represents a dual-layer Blu-ray HDR10 compatible Dolby Vision stream encoded as 10-bit HEVC video with a level up to 3840×2160 at 24 fps. If you want to play these files you need to use the scene tools available For more reading. And a reddit post about how this is impossible to play on Android. 2
David Patt 21 Posted May 3, 2024 Author Posted May 3, 2024 Thanks for answer. Ajother weird thing happen. I randomly try some movies and it flicker to black and white and then they play in COLOR , so itry that movie what play in black and white only and it play in COLOR too for some reason. Was there some update ? I am really confused.
RanmaCanada 500 Posted May 3, 2024 Posted May 3, 2024 It might be trying to fall back to the HDR 10 layer, with limited success. You're still better off to use quietvoid's tools to fix these so they are compatible with your hardware. 1
