jglazer63 23 Posted April 17, 2024 Posted April 17, 2024 While it does move the files as I want now, I see it leaves behind empty directories:
Luke 42255 Posted April 17, 2024 Posted April 17, 2024 Hi there, let’s look at a specific example: How to Report a Problem Thanks.
jglazer63 23 Posted April 17, 2024 Author Posted April 17, 2024 Not sure how to show you. I placed a folder of .MKV files in the watch folder. It moved all the .MKV files but left the folder (now empty) behind. I've tried with a few folders (trying to migrate away from Tiny Media Manager to Emby Auto Organize). It is just leaving empty folders. Does it come back later and clean them up? How often does auto-organize run on its own? Is there a schedule?
Happy2Play 9814 Posted April 17, 2024 Posted April 17, 2024 2 hours ago, jglazer63 said: How often does auto-organize run on its own? Is there a schedule? Did you look in schedule task? How often do you want it to run? As you can delete the current trigger and add your own. 2 hours ago, jglazer63 said: Not sure how to show you. I placed a folder of .MKV files in the watch folder. It moved all the .MKV files but left the folder (now empty) behind. Logs are needed for a specific example but appeared to work in my test. 2024-04-17 13:41:00.586 Debug App: Deleting empty directory E:\Media\Watch folder\Watch Movie folder\Mooned.2023.1080p.BluRay.x264-OFT Note you looks like you will need to enable debug logging to see this. Logs-Settings tab
