eddfish0409 0 Posted July 14, 2024 Posted July 14, 2024 opensubtitles still not working embyserver (3).txt
Wizb0y 1 Posted July 14, 2024 Posted July 14, 2024 Did some testing, it seems that you need an API-key to get subtitles from opensubtitles.com. But you can't enter it in the emby... VERY IMPORTANT: In HTTP request must be both headers: Api-Key and Authorization stoplight.io doesn't allow to use in shown example both headers Tested this with: Login: curl --request POST --url https://vip-api.opensubtitles.com/api/v1/login --header 'Accept: application/json' --header 'Api-Key: xxxxxxxxxxxxxxxxxxxxxx' --header 'Content-Type: application/json' --header 'User-Agent: <<emby v4.9.0.26>>' --data '{ "username": "xxxxx", "password": "xxxxx" }' result: {"user":{"allowed_translations":10,"allowed_downloads":989,"level":"VIP Member","user_id":xxxxx,"ext_installed":false,"vip":true},"token":"xxxxxxxx the token xxxxxxxxxxxxxxxxx","status":200,"base_url":"vip-api.opensubtitles.com"} Get subtitle: curl --request POST \ --url https://vip-api.opensubtitles.com/api/v1/download \ --header 'Accept: application/json' \ --header 'Api-Key: xxxxxxxxxxxxxxxxxxxxx' \ --header 'Authorization: Bearer "xxxxxxxxxx got from login xxxxxxx' \ --header 'Content-Type: application/json' \ --header 'User-Agent: <<emby v4.9.0.26>>' \ --data '{ "file_id": 123 }' result: {"link":"https://www.opensubtitles.com/download/29B68F0E03D36CA9473DB442C17FB3495D5222245198FD188092A7D54C9436965C355301917FE2347416684F4FDCFE4555883D7FD1C55584F81C43836C2623F360A30F3792B8EEF60369162445DAEAD5634B39E13AD1022EEF44C719D5AD8D229D2053C419E304076104D38D6B15E697E3CCDBB6C97E13197159444559289210B2408/subfile/castle.rock.s01e03.webrip.x264-tbs.ettv.-eng.ro.srt","file_name":"castle.rock.s01e03.webrip.x264-tbs.ettv.-eng.ro.srt","requests":1,"remaining":988,"message":"Your quota will be renewed in 8 hours and 27 minutes (2024-07-14 23:59:59 UTC) ts=1720971127 ","reset_time":"8 hours and 27 minutes","reset_time_utc":"2024-07-14T23:59:59.999Z","uk":"count_uid_xxxxxx","uid":xxxxxx,"ts":1720123127}
Happy2Play 9814 Posted July 14, 2024 Posted July 14, 2024 57 minutes ago, Wizb0y said: Did some testing, it seems that you need an API-key to get subtitles from opensubtitles.com. But you can't enter it in the emby... VERY IMPORTANT: In HTTP request must be both headers: Api-Key and Authorization stoplight.io doesn't allow to use in shown example both headers Tested this with: Login: curl --request POST --url https://vip-api.opensubtitles.com/api/v1/login --header 'Accept: application/json' --header 'Api-Key: xxxxxxxxxxxxxxxxxxxxxx' --header 'Content-Type: application/json' --header 'User-Agent: <<emby v4.9.0.26>>' --data '{ "username": "xxxxx", "password": "xxxxx" }' result: {"user":{"allowed_translations":10,"allowed_downloads":989,"level":"VIP Member","user_id":xxxxx,"ext_installed":false,"vip":true},"token":"xxxxxxxx the token xxxxxxxxxxxxxxxxx","status":200,"base_url":"vip-api.opensubtitles.com"} Get subtitle: curl --request POST \ --url https://vip-api.opensubtitles.com/api/v1/download \ --header 'Accept: application/json' \ --header 'Api-Key: xxxxxxxxxxxxxxxxxxxxx' \ --header 'Authorization: Bearer "xxxxxxxxxx got from login xxxxxxx' \ --header 'Content-Type: application/json' \ --header 'User-Agent: <<emby v4.9.0.26>>' \ --data '{ "file_id": 123 }' result: {"link":"https://www.opensubtitles.com/download/29B68F0E03D36CA9473DB442C17FB3495D5222245198FD188092A7D54C9436965C355301917FE2347416684F4FDCFE4555883D7FD1C55584F81C43836C2623F360A30F3792B8EEF60369162445DAEAD5634B39E13AD1022EEF44C719D5AD8D229D2053C419E304076104D38D6B15E697E3CCDBB6C97E13197159444559289210B2408/subfile/castle.rock.s01e03.webrip.x264-tbs.ettv.-eng.ro.srt","file_name":"castle.rock.s01e03.webrip.x264-tbs.ettv.-eng.ro.srt","requests":1,"remaining":988,"message":"Your quota will be renewed in 8 hours and 27 minutes (2024-07-14 23:59:59 UTC) ts=1720971127 ","reset_time":"8 hours and 27 minutes","reset_time_utc":"2024-07-14T23:59:59.999Z","uk":"count_uid_xxxxxx","uid":xxxxxx,"ts":1720123127} I will assume since you are VIP you need to follow this topic as it is a different issue then the NotAcceptable error.
Wizb0y 1 Posted July 14, 2024 Posted July 14, 2024 You'r right. i'm VIP and the error is unauthorized. I'll post it there.
Luke 42255 Posted July 15, 2024 Posted July 15, 2024 Hi, please try again and let us know how things compare. Thanks.
eddfish0409 0 Posted July 16, 2024 Posted July 16, 2024 17 hours ago, Luke said: Hi, please try again and let us know how things compare. Thanks. 3u i wil try btw i wanna ask ,emby support dobly vision?
Luke 42255 Posted July 16, 2024 Posted July 16, 2024 9 hours ago, eddfish0409 said: 3u i wil try btw i wanna ask ,emby support dobly vision? HI, yes it depends on the device you're playing from.
eddfish0409 0 Posted July 17, 2024 Posted July 17, 2024 2024 年 7 月 15 日凌晨 12:44,Happy2Play 说: 我假设由于您是 VIP,因此您需要遵循此主题,因为它与 NotAcceptable 错误是不同的问题。 您好,您能告诉我们更多关于如何以及在何处输入此命令行的信息吗?
Happy2Play 9814 Posted July 17, 2024 Posted July 17, 2024 17 minutes ago, eddfish0409 said: Hello, can you tell us more about how and where to enter this command line? Sorry I don't follow as the only think you need to do is enter your OpenSubtitles.com username and password into the plugin. If you are still having issues you will need to ensure to post a new server log.
eddfish0409 0 Posted July 17, 2024 Posted July 17, 2024 2 hours ago, Happy2Play said: Sorry I don't follow as the only think you need to do is enter your OpenSubtitles.com username and password into the plugin. If you are still having issues you will need to ensure to post a new server log. it's work thanks!
