Masterchops 1 Posted July 6, 2024 Posted July 6, 2024 Hello, i'm also getting an error "NotAcceptable" I'm open to suggestions on how to resolve this issue. Have a great day :)
Q-Droid 1011 Posted July 6, 2024 Posted July 6, 2024 Might this have anything to do with yesterday's update of the plug-in?
TXTECHIE 5 Posted July 6, 2024 Posted July 6, 2024 (edited) Yep same here. Can not download any sub now after that update today. get this Errors NotAcceptable. . was working yesterday. Edited July 6, 2024 by TXTECHIE
Happy2Play 9814 Posted July 6, 2024 Posted July 6, 2024 (edited) 22 minutes ago, TXTECHIE said: Yep same here. Can not download any sub now after that update today. get this Errors NotAcceptable. . was working yesterday. I am not seeing an issue at least manually downloading subs with new OpenSubtitles 1.0.56. But if you truly think it is the update go the catalog and install previous version and restart, note plugin auto update will happen but just don't restart again Emby. This will allow you verify a plugin change caused the issue or not. Edited July 6, 2024 by Happy2Play
Happy2Play 9814 Posted July 6, 2024 Posted July 6, 2024 1 hour ago, Q-Droid said: Might this have anything to do with yesterday's update of the plug-in? Would appear so as you mentioned in other topic search works but download does not.
Q-Droid 1011 Posted July 6, 2024 Posted July 6, 2024 2 minutes ago, Happy2Play said: Would appear so as you mentioned in other topic search works but download does not. Same for you then?
Happy2Play 9814 Posted July 6, 2024 Posted July 6, 2024 Downgrading give the same error so I will guess issue is not Emby again. 1
TXTECHIE 5 Posted July 7, 2024 Posted July 7, 2024 I tried that downgrade too right away it did the same. Maybe it Open-subtitles trouble. hours later testing it again now it say.. No results found..
sn0pzer 2 Posted July 7, 2024 Posted July 7, 2024 Same for me, getting a "NotAcceptable" error. Downgrading the plugin does not solve the issue.
luser 37 Posted July 7, 2024 Posted July 7, 2024 +1 2024-07-07 12:03:52.732 Error Server: Error processing request *** Error Report *** Version: 4.8.8.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux Framework: .NET 6.0.25 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/lib/emby Application path: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: NotAcceptable at OpenSubtitles.OpenSubtitleComDownloader.DownloadSubtitlesToString(String id, OpenSubtitleOptions options, CancellationToken cancellationToken) at OpenSubtitles.OpenSubtitleComDownloader.GetSubtitlesInternal(String id, OpenSubtitleOptions options, CancellationToken cancellationToken) at Emby.Providers.Subtitles.SubtitleManager.DownloadSubtitles(BaseItem item, String subtitleId, LibraryOptions libraryOptions, CultureDto[] searchedLanguages, CancellationToken cancellationToken) at Emby.Api.Subtitles.SubtitleService.Post(DownloadRemoteSubtitles request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost httpHost, IServerApplicationHost appHost, IRequest httpReq, IResponse httpRes, IStreamHelper streamHelper, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: OpenSubtitles TargetSite: Void MoveNext()
ryanzb111 4 Posted July 7, 2024 Posted July 7, 2024 Unable to login at https://www.opensubtitles.com/
Happy2Play 9814 Posted July 7, 2024 Posted July 7, 2024 (edited) 15 minutes ago, ryanzb111 said: Unable to login at https://www.opensubtitles.com/ Not having that issue as I just logged in looked at history. But still get 406 error on downloads in Emby. @Lukedon't know if this is new or not but does the plugin account for download delays? Unless this is only a web site as you have to click download wait 10 seconds and click download again. But at the same time everything I have seen on the 406 error is a quota limit reached even though that has not happened per the on screen image showing 2 of 20. Or is there a disconnect with user login and their quotas? Edited July 7, 2024 by Happy2Play
TXTECHIE 5 Posted July 7, 2024 Posted July 7, 2024 9 hours ago, TXTECHIE said: I tried that downgrade too right away it did the same. Maybe it Open-subtitles trouble. hours later testing it again now it say.. No results found.. I uninstalled plugin an reinstalled it now back to NotAcceptable error still. search works that it.
Luke 42255 Posted July 7, 2024 Posted July 7, 2024 Is there anyone here having this issue who does not have Emby Premiere?
Q-Droid 1011 Posted July 7, 2024 Posted July 7, 2024 23 minutes ago, Happy2Play said: Not having that issue as I just logged in looked at history. But still get 406 error on downloads in Emby. Does your history on OS .com show downloads from the new API? The .org site showed history for my Emby activity but the new .com site doesn't.
Happy2Play 9814 Posted July 7, 2024 Posted July 7, 2024 4 minutes ago, Q-Droid said: Does your history on OS .com show downloads from the new API? The .org site showed history for my Emby activity but the new .com site doesn't. It shows 2 previous tests via Emby and two manual from site today.
Edrock200 53 Posted July 7, 2024 Posted July 7, 2024 Is it possible they are enforcing these limits now? Are vip users getting the error to? https://www.opensubtitles.com/en/support_us
chief2810 5 Posted July 7, 2024 Posted July 7, 2024 16 minutes ago, Edrock200 said: Is it possible they are enforcing these limits now? Are vip users getting the error to? https://www.opensubtitles.com/en/support_us I’m VIP and getting the error. 1
Q-Droid 1011 Posted July 7, 2024 Posted July 7, 2024 1 hour ago, Happy2Play said: It shows 2 previous tests via Emby and two manual from site today. Mine only shows manual downloads and I use the search and download from ATV app frequently.
Q-Droid 1011 Posted July 7, 2024 Posted July 7, 2024 54 minutes ago, Edrock200 said: Is it possible they are enforcing these limits now? Are vip users getting the error to? https://www.opensubtitles.com/en/support_us OS VIP and Emby premiere. The limits on the OS site for my account are correct. 1
Kerdogz 0 Posted July 8, 2024 Posted July 8, 2024 I'm an Emby Premiere client. Receiving the "Not acceptable" error when attempting to download subs. I have created and can log into my OpenSubtitles.com account. I have the same user and password setup on Emby for OpenSubtitles.com When searching for subs for a movie I'm presented with choices from Opensubtitles.com But selecting and downloading returns "Not acceptable" error Running ver 1.0.56.0 of OpenSubtitles plugin This problem seemed to occour after the OS change to .com from .org Please advise
remigius 0 Posted July 8, 2024 Posted July 8, 2024 (edited) 1 hour ago, Kerdogz said: I'm an Emby Premiere client. Receiving the "Not acceptable" error when attempting to download subs. I have created and can log into my OpenSubtitles.com account. I have the same user and password setup on Emby for OpenSubtitles.com When searching for subs for a movie I'm presented with choices from Opensubtitles.com But selecting and downloading returns "Not acceptable" error Running ver 1.0.56.0 of OpenSubtitles plugin This problem seemed to occour after the OS change to .com from .org Please advise Exactly the same as me. Except i have a vip account at opensubtitles.com Edited July 8, 2024 by remigius
